Old 07-15-2009, 11:21 PM   #1
2007 19' Bambi
Las Vegas , Nevada
Question Adjusting Water Heater Temp?
Greetings all,
First post, so please forgive any mistakes in protocol I might make.
I read through the owner's manual (maybe too quickly) but recall nothing about how to adjust the water heater. Is it possible? It's too hot!
We have a 19' Bambi.
Thank you,
Gastrolith
in Las Vegas
Gastrolith is offline   Reply With Quote
Old 07-16-2009, 12:28 AM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
My thought on this.
Welcome to the forum.
Hi, I could be wrong, but I don't think you can adjust the water heater on newer model Airstreams. As for being too hot, it depends on the temperature of the outside water coming in. And in your case, [Nevada] I bet it's fairly warm to begin with. Even in my home I have to turn my faucets farther to the hot side during the winter and more toward the cold side during the summer. In the cold icey campgrounds my trailer's shower has to be almost as hot as it will go. And in the hot areas my shower is turned very close to the cold side. Both of my sink faucets seem to be fairly normal, but the shower control is pretty sensitive.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-16-2009, 12:36 AM   #3
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
HI,
Welcome to the forums Gastrolith.
I have a 2005 Bambi. The stock water heart does not come with an adjustable thermostat. However, you can buy an adjustable thermostat from Atwood and install it yourself. These are available online. I have done this myself and it works.
jd
JDL is offline   Reply With Quote
Old 05-04-2010, 06:40 AM   #4
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Were you satisfied with the adj. thermostat?
David
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 05-05-2010, 11:29 PM   #5
2007 19' Bambi
Las Vegas , Nevada
I've learned to deal with the temperature. Not so bad. Unfortunately, I don't take the AS out often enough be bothered by the temp. Thanks for the follow-up.
2007 bambi
Water heater - can't find temp control dano Water Heaters, Filters & Pumps 6 05-04-2010 06:36 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
adjusting flame on Water Heater joe3957 Water Heaters, Filters & Pumps 2 09-26-2008 06:23 PM
Adjusting water heater pilot? glacierrunne Water Heaters, Filters & Pumps 2 06-09-2008 05:29 PM
Adjusting flame on water heater Dan S Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-30-2007 06:37 AM
