Old 07-05-2019, 07:31 PM   #1
ijoe13's Avatar
Seattle , Washington
AC - Central vs Ducted
Iíve tried to do some searching on YouTube hoping to find a comparison video of the noise level produced by both the central and ducted air conditioning in the new Caravel and Bambi lines. I realize these are brand new models and are just beginning to ship, but hoping someone can share a comparison.
ijoe13 is offline   Reply With Quote
Old 07-05-2019, 08:06 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Ducted units are noted for being much quieter.
Dept of ďOverKillĒ
GMFL is online now   Reply With Quote
Old 07-05-2019, 08:17 PM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Will your local Airstream dealer let you listen to AC in trailers on the lot?
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-05-2019, 09:44 PM   #4
Wconley's Avatar
2018 28' International
Renton , Washington
The new ones are a game changer. The TV was almost impossible to watch and it was very difficult to sleep with the central air turned on. But with the ducted air you can carry on normal conversations, watch TV, eat dinner and sleep in comfort.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 07-05-2019, 11:19 PM   #5
ijoe13's Avatar
I presume the cooling efficiency is the same or better with the ducted system?
Old 07-05-2019, 11:36 PM   #6
Wconley's Avatar
Renton , Washington
No idea really but I can rationalize that cold air pouring directly out of the box into the trailer is about as efficient as possible but it’s not distributed very well. With outlets throughout the trailer, including the bathroom, overall temperature consistency is drastically improved even if there are some efficiency drops because of the ducting.
Walt
2013 F150 Ecoboost
Old 07-06-2019, 12:05 AM   #7
ijoe13's Avatar
Makes sense. I plan on taking a look at and testing the AC units in both types of setups to fully understand the sound and efficiency difference.
Old 07-06-2019, 04:05 AM   #8
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
People went through all of this a few years ago when the bigger trailers went ducted. I even know people who sold their relatively new trailer just to upgrade to ducted air. No doubt the ducted air is better, mostly. I also know one owner who had a roof leak and the ducting has made it impossible, so far, to find the source.
As the owner of an older trailer, I found that the addition of a sound bar to the TV has overcome the noise objection of watching TV. I would go with ducting if I had a choice, but I am not buying another one of these.
Larry
lsbrodsky is offline   Reply With Quote
Old 07-06-2019, 06:59 AM   #9
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Iíve had both. Ducted is far superior. The old style is like a jet engine over your head - you canít have a conversation, you have to blast the TV, it wakes you up at night and itís just generally unpleasant to be in the trailer when itís running.
Ducted does not cool quite as well - so make sure you get a unit with 2 ACs / 50A service and this solves for the efficiency loss.
wulfraat is offline   Reply With Quote
Old 07-06-2019, 08:07 AM   #10
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
My same exact experience and the same advice I would offer. Currently in 90 degree Kansas heat and no shade. Dual A/C's keeping it comfortable and ducted air much quieter.
The ability to follow instructions is highly underrated.
hhendrix is offline   Reply With Quote
Old 07-06-2019, 08:45 AM   #11
Wconley's Avatar
Renton , Washington
One thing I will add is that while the ducting distributes airflow throughout the trailer we find that in our 28RBQ that when I get up early if I close the partition in the bedroom so my wife can sleep, the bedroom will overheat compared to the living area (we’ve never needed AC in the morning). We have gone so far as to close the outlets in the bedroom as much as possible and warm air comes out the air return grills in the bedroom and it still overheats. This happens using either or both heat pumps. I’ve taken to using a space heater in the living area when I get up to avoid making the bedroom uninhabitable. Even so, I’d never go back to the central unit.
Walt
2013 F150 Ecoboost
Old 07-06-2019, 09:21 AM   #12
ijoe13's Avatar
The 20í AS only comes with a since AC unit, but I presume it would do a good enough job to keep it comfortable on moderately warm days (80-85)? We would likely go with one of these single axel models and at this point, the new Caravel 20FB is looking to be the one for us. I was waiting to see the 20FB Bambi, but doubt the central air they have in there is any quieter then the Sport.
Old 07-06-2019, 09:44 AM   #13
369goose's Avatar
2014 25' Flying Cloud
1987 29' Sovereign
1977 31' Sovereign
Tampa Bay , Florida
Larry
We listen to the television thru the Airstream speakers which helps, slightly, if you sit under the speakers at the dinette. But we've been wondering if a sound bar might make it possible to actually hear the TV over the AC. Mind sharing which sound bar you use?
☘ 369goose
"The world is a book and those who do not travel read only one page.Ē Ė St. Augustine
369goose is offline   Reply With Quote
Old 07-06-2019, 09:47 AM   #14
Rgentum's Avatar
2016 27' Flying Cloud
Woodinville , Washington
The swivel grills at the outlets of our ducted A/C seriously restrict airflow, so removing them results in substantially more airflow and better cooling.
Alta & Richard, Seattle area --- WBCCI 8873
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
"BigDog": M Harlequin Great Dane, 150 lb
WL7Z --- NAUI --- WSBA
Rgentum is offline   Reply With Quote
Ducted AC?- Crazy idea? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 60 07-26-2014 12:50 PM
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
Ducted AC chetos Furnaces, Heaters, Fireplaces & Air Conditioning 19 12-13-2011 09:29 PM
Cool air ducted from below trailer truckasaurus Roof Vents, Skylights & Fans 8 03-05-2009 09:35 AM
