Old 01-18-2010, 07:22 PM   #1
2007 19' Safari SE
San Clemente , California
AC and Heat pump not working
I have only used my AC twice since I have owned my coach. I bought the coach brand new so it has no history. One trip I was on it was rather hot so I decided to run the AC. Right after I turned the unit on I smelled a burning smell while the unit seemed to struggle to run. I shut the system down and didn't try to run the AC again that trip. It was my last trip of the summer so didn't think much about the AC much after that trip. My next trip was during cold weather. I switched the thermo to heat pump and waited for the unit to run and start heating. The unit ran but no heat came out. I also have attempted to run the AC again. The unit did not produce any cold.
I have no idea what could have happened but fear the worst, an expensive repair. If anybody has experienced a similar situation a little guidance would be appreciated.
BigPlay is offline   Reply With Quote
Old 01-18-2010, 07:58 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
The Start capacitor or the control board burned up. Low voltage, too small cable, too long a cable can cause hard/no starts.
Michelle TAC MT-0
Sarah, Snowball
Old 01-18-2010, 08:19 PM   #3
2007 19' Safari SE
thanks for the reply, is this an expensive fix?
Old 01-18-2010, 08:23 PM   #4
Ottawa , ON
Shouldn't be...
Old 01-19-2010, 07:47 AM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Check to see if you have one of the carriers that have a recall notice out.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
2007 bambi
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Heat Pump? gaylejoe Furnaces, Heaters, Fireplaces & Air Conditioning 17 12-25-2009 11:44 AM
Heat Pump Problem Rugger Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-20-2009 07:47 PM
Heat Pump Question jeff4506 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-24-2008 04:38 PM
should i get the a/c with the heat pump?? evelitalian Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-22-2008 06:17 PM
