Old 02-27-2019, 09:48 PM   #1
Boise , Idaho
About to make the investment.
Hello everyone! My girlfriend and I have decided that we are going to make the investment in a new 2019 Airstream Sport 16RB. To be honest we have butterflies making such a big purchase as a young couple, but we have done a lot of research and are really excited!
One of my main questions that I wanted to ask AS owners, is how they do on washboard dirt roads? I live in Idaho, and a lot of the dirt roads I am hoping to travel on are pretty bumpy. Will the vibrations rattle a lot of things loose?
Any other helpful information for the purchasing process is appreciated. Thank you! And I look forward to frequenting this website.
James3344 is offline   Reply With Quote
Old 02-27-2019, 10:09 PM   #2
2007 27' International CCD FB
San Diego , California
Washboard roads are hard on any vehicle, and probably extra hard on trailers, with Airstream being no exception.
That said, I've done it and there are strategies to manage it.
A good tow vehicle that has supple suspension will help. Preferably not a 3/4 or 1-ton truck that will beat up the trailer, even on road.
The same tried and trued strategy that has been used with off-road vehicle can be applied to the trailer. Air down to something ~50% of the on-road air pressure.
Upgrading to taller trailer tires to increase clearance and sidewall aspect ratio (taller sidewalls) can really help.
I have a built in on-board air compressor on my tow vehicle so I don't have to think twice about airing down the tow vehicle or trailer tires.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is online now   Reply With Quote
Old 02-27-2019, 11:55 PM   #3
1980 24' Caravelle
vallejo , California
welcome to the forums, as pteck stated slow down and air down tires. i boondock and most roads are dirt/gravel.all mt single axle trailers bounced up and down more than my twin-axle trailers. go slow and enjoy! kurt
ke6gkv is offline   Reply With Quote
Old 02-28-2019, 08:05 AM   #4
Boise , Idaho
Ok thank you for the information. Doesn't sound like it will be to much of a problem! I'm really excited to take it out for the first time, already have a list of campsites to hit this summer.
Old 02-28-2019, 08:11 AM   #5
2019 25' International
Providence , Rhode Island
Welcome aboard....my wife and I are the same as you, in the process of acquisition. Our starts building March 13, so we understand what you're feeling!
Lots of info here although a PITA to find certain things......but have a good long look around and ask away, lots of helpful people here.
kittmaster is offline   Reply With Quote
Old 02-28-2019, 08:32 AM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Look into a cushioned hitch ball extension - the hop of the tow vehicle rear axle transmitted down the hitch A-frame can fatigue structural fastening points over time - on vintage trailers the 3/4 & 1 ton tow vehicles can/will seek to separate the front of the shell shell from frame.
https://shockerhitch.com/
https://airsafehitches.com/receiver-hitch/
Whats a few sheared rivets, oh, think of all the enlarged 'give' downstream from the damage even after the missing/visibly loose rivets are replaced...
Yeah, there may be other brands, but if I had a late model trailer I'd be hitching my wagon to one of them.
And to misquote Andy - running gear imbalance can get telegraphed to focus 12, 15 feet or more from the axles as oscillations set in, damaging stanchion points, making black-ring rivets and loosening cabinets; it'd be the same for hammering frame/shell through exuberant wash-board road travel..
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 02-28-2019, 09:01 AM   #7
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
BTW, the Sport trailers don’t have shock absorbers like the larger AS trailers.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 02-28-2019, 10:41 AM   #8
The Silver TARDIS
Kevinshortnh's Avatar
2018 30' Classic
Gray Court , South Carolina
I recommend you also get a set of Rock Tamers to avoid damage from rocks flying up from your rear tires.
Kevin Short
2018 Classic 30RB Twin -- "The Silver TARDIS"
2014 RAM 2500 Cummins Diesel
BlueOx SwayPro 1506
Kevinshortnh is offline   Reply With Quote
Old 02-28-2019, 10:57 AM   #9
Boise , Idaho
Thank you! So for a 2019 Sport, do you think that getting the shocker hitch would make a significant difference?
Old 02-28-2019, 11:04 AM   #10
I forgot to mention that the Sport trailers also don't have segment protectors, which may be available at a significant cost.
Ray B.
Old 02-28-2019, 11:09 AM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Buy a preowned unit if you can. The cost difference between new and even a year or two old is going to be significant. If I could go back in time to late 2003, I might have done just that.
There are some inherent issues with Airstream trailers and one that has been out there for at least a year will have some of the items shaken out and if for some reason the dreaded fillform corrosion issue is going to appear, it will have started in most cases within a year or two. In that year or two, you could be talking thousands of dollars that will not have evaporated out of your wallet.
Old 02-28-2019, 11:46 AM   #12
Boise , Idaho
Yeah the dealer said that the segment protectors run about $750 each! Ouch!
Does anyone have any recommendations for a good drop hitch brand? My hitch sits about an inch to high on my truck currently.
Old 02-28-2019, 02:24 PM   #13
Cloudland2
davidrrand's Avatar
2016 25' Flying Cloud
Trenton , Georgia
After one destructive washboard encounter at 11 Mile SP in CO I have learned to avoid at all cost washboard roads with my 25FC. Doors under kitchen sink and bath sink pulled loose at hinges, microwave came very close to fully dislodging from the cabinet and loose drain plumbing under the sinks. No permanent damage fortunately but tightened every screw in the trailer and repaired those that pulled loose with glue and tooth picks. Paved roads are tough enough on these babies! ��
davidrrand is offline   Reply With Quote
Old 02-28-2019, 04:18 PM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Etrailer..or amzon
Enough interest to make an investment? rvk Community Polls 8 01-17-2012 02:49 PM
Investment Advice! 345bill Off Topic Forum 14 10-22-2008 06:59 PM
Electric cooling fans - worth the investment? abridges01 Mechanics Corner - Engines, Transmission & More... 6 06-02-2008 12:38 PM
Great eBay investment! markdoane Off Topic Forum 10 01-01-2005 12:17 AM
