Clint,
One thing not to do or let any tire shop do. Don't put a jack under the axle tube to lift the trailer. That is the black square tube that goes across the trailer. It's not for lifting.
Make sure what ever you use can't slip from the lift point. Personally I use a jack from a 1 ton full size pick up and they have a floating saddle, holds nicely on the frame for me on my 30'.
But you are ahead of the game figuring this out before hand.
Gary
