Old 07-02-2019, 11:44 AM   #1
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
22FB meets a Semi
This happened yesterday in Ft. Worth, TX. A 22FB was rear ended by a semi. Rolled and tucked the back end neatly into the bathroom. But, it looks to still be towable. Just not livable...
Msherw is offline   Reply With Quote
Old 07-02-2019, 11:46 AM   #2
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
Attachment 345186
Wow! So sorry to see...what happened? Is this yours?
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 07-02-2019, 12:12 PM   #3
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
The trailer probably saved the tow vehicle occupants . . .
Mike G is offline   Reply With Quote
Old 07-02-2019, 12:23 PM   #4
Long Island , New York
21 hours ago:
https://twitter.com/dfwscanner
https://www.thelegaladvocate.com/new...heritage-trace
"Officials have indicated that major injuries were suffered by at least two victims involved who were quickly rushed to a nearby trauma center for immediate medical care. No further details have been made available as this story is still developing and being investigated by DPS."
The Airstream probably softened the blow, but a semi going highway speed can cause some bad whiplash IMO.
Prayers for the victims.
Peter
Old 07-02-2019, 12:32 PM   #5
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
No. Not ours. Just reporting what others saw.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign K5FT
Old 07-02-2019, 12:32 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
A colleague of mine happened by before the semi was removed and sent me this. Oh, and it's not towable, you can see in the first photo (without the semi) that the tanks and the aft part of the frame are sitting on the ground and I'm guessing the a-frame is torqued WAY to the street-side direction.
— David
Old 07-03-2019, 09:10 AM   #7
2019 25' International
Washington , Washington, D.C.
If the owners were towing with their propane on to keep frig cold, couldn't an impact like this blow up the Airstream?
PatLee is offline   Reply With Quote
Old 07-03-2019, 09:46 AM   #8
2018 27' Globetrotter
Mesa , Arizona
I was told many years ago that it is against the law to drive with your propane tanks open. For this reason, I always turn mine off and run the fridge on battery while towing.
dgutwein is offline   Reply With Quote
Old 07-03-2019, 09:48 AM   #9
Box Elder (formerly of Center Moriches, NY) , South Dakota
Ouch........
NY24 is offline   Reply With Quote
Old 07-03-2019, 10:28 AM   #10
Not unless there was a catastrophic propane leak and a spark to start the fire IMO. If a propane line was ruptured, it is likely that the propane regulator's safety feature [which shuts off gas flow, in the event of a sudden drop in pressure] kicked in. The propane tanks do not appear to have been damaged IMO.
I don't think this is accurate . . . could you please provide a citation for a law like this?
Peter
Old 07-03-2019, 10:57 AM   #11
DKB_SATX's Avatar
1976 Argosy 28
1) there are a few places in the US where this is true... some tunnels and ferries come to mind. Otherwise this is false.
2) Unless you've replaced your refrigerator, battery power provides no cooling in a 2018 Airstream trailer's refrigerator.
— David
Old 07-03-2019, 11:00 AM   #12
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Looks like the semi company just bought those folks a new Airstream. I hope the owners do not have long lasting injuries and are well compensated. If not, I would be out for blood.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-03-2019, 11:05 AM   #13
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Peter
I think you're right, Peter. This has come up on other discussions. Other than on some ferries and in some tunnels, I haven't ever seen anyone able to provide evidence of an actual law prohibiting driving with a propane fridge on.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper (65avion.home.blog)
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 07-03-2019, 11:56 AM   #14
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
Have read that the propane fridge is prohibited in enclosed tunnels and only in certain states.
I do wonder if the propane fridge is a problem when I go to refuel the TV. But it is a passing wonder since I continue to do it.
Back to the collision. Had the semi hit an SOB, the wood and debris would have been all over the road...likely only the trailer frame would have survived. See how neat the AS is. Like stepping on an aluminum can.
But it is till a total loss and I too hope the owners are faring well and can get a new one to replace it.
M!ke
250 meets 250 meets 250... "made for Germany" in Germany split window Classic Motorhomes 27 11-29-2016 11:44 AM
trailer meets a tree stump tornado-bait Ribs, Skins & Rivets 7 09-07-2006 06:40 AM
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 12:05 PM
Any rallys or meets coming up in Canada? Wolf WBCCI Rallies & Events 5 08-02-2003 09:48 AM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 02:49 AM
