Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 2005 and newer - Bambi all models
Old 06-30-2014, 01:41 PM   #1
Bend , Oregon
22' Sport table lubrication
I have a 2013 22 Sport. The telescoping table post for the dinette I think could use some lubrication. Anybody have a suggestion?
chaeha is offline   Reply With Quote
Old 07-10-2014, 04:57 AM   #2
2013 22' FB Sport
Wichita , Kansas
No mattet what you use to lubricate it, the lubrication will likely get on your pant lega when they hit the table leg, so I wouldn't lubricate it unless you just have to.
tallen5 is offline   Reply With Quote
Old 07-10-2014, 05:41 AM   #3
Retired.
. , At Large
A dry lube like spray silicone would probably work best. Anything at all that leaves any residue will quickly turn everything into a mess.
Old 01-15-2015, 12:57 PM   #4
I had the same problem with my trailer table. I used Boeshield T-9 on the the pole under the table. It is clean, effective and easy to use. Best part is there is no oily residue that will stain. Good luck!
22fbsport is offline   Reply With Quote
Old 01-16-2015, 05:19 AM   #5
'15 Flying Loud 20' Bambi
renderit's Avatar
2014 16' Sport
2015 20' Flying Cloud
2021 25' Globetrotter
small city outside a big one , south of most, north of some
Try waxing it with Nu-Finish. Orange bottle in automotive. Then use some on your windows. I use it on everything.
renderit is offline   Reply With Quote
Old 01-16-2015, 08:47 AM   #6
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
Try Pledge furniture polish. No residue. I also spray it on a damp cloth to clean vehicle interior. Works great on the plastic over the instrument cluster or plastic eyeglasses. I also use it on my table saw, band saw, jointer, and planer tables. Makes the wood slide easily with no residue. Do not use on a surface that is much below freezing -- makes a mess.
Sam
samb is offline   Reply With Quote
Old 01-17-2015, 06:58 AM   #7
renderit's Avatar
2014 16' Sport
No worry about Nufinish below freezing. We also use a paste wax on our counter tops in the house, I am sure that would work fine as well.
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
Hitch Lubrication? AndyPenny Hitches, Couplers & Balls 13 11-21-2007 02:59 AM
Stabilizer lubrication? Fyrzowt Jacks, Stabilizers, Lifting and Leveling 14 09-16-2006 05:08 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 09:51 PM
Hitch ball lubrication Kistler Our Community 9 05-12-2003 12:48 PM
