Old 04-21-2018, 07:53 PM   #1
2018 22' Sport
Springboro , Ohio
22 FB lug nuts
1 week old 22FB ang getting ready for first trip. I wanted to torque the lug nuts, but read that they probably have lug nut covers on them. Never ran into those before. Ordered a lug nut cover puller wrench, but it wonít fit in the tight spot. So now Iím questioning whether these are plain lug nuts, or nuts with covers. Can anyone shed light on this? I believe they say Mcgard on them.
Rubeyjj is offline   Reply With Quote
Old 04-21-2018, 08:06 PM   #2
mojoe7009's Avatar
Green Cove Springs , Florida
If they say McGard on them then they are probably solid lug nuts. McGard doesnít make lug nuts with covers as far as I know.
Breathe In, Breathe Out, Move On
mojoe7009 is offline   Reply With Quote
Old 04-21-2018, 09:50 PM   #3
2017 22' Sport
2018 26' Flying Cloud
Brighton , Michigan
My '17 22FB had solid lug nuts, no caps on them. 110 ft lb torque and 65 psi is what I ran with zero issues.
Rivet Rocket is offline   Reply With Quote
Old 04-21-2018, 11:47 PM   #4
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
To clarify, the covers are part of the nut. The cover is a chrome plated sheetmetal covering that is form fitted and fused to the center steel nut. It is not removable, but may fail. If they fracture, you may need a smaller socket to remove the nut. Pat
Old 04-21-2018, 11:58 PM   #5
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
There are a couple of recent threads where people talk about the sheet metal caps on the lug nuts. They have pictures of them splitting. Search lug nuts, or look for a posting from me in a lug nut thread.
Matti
Mattirs is online now   Reply With Quote
Old 04-22-2018, 06:20 AM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Those in the picture are solid lug nuts. They don't have the non-removable shell on them that has been discussed previously. Use your 13/16" socket, and torque them to 110 foot pounds.
Old 04-22-2018, 11:50 AM   #7
2018 22' Sport
Springboro , Ohio
awesome info, thank you all for helping out the newb!
Old 04-22-2018, 12:05 PM   #8
Mollysdad's Avatar
I thought Airstream stopped using the lug nut covers in about 2015.
Old 04-22-2018, 12:45 PM   #9
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
My stream did have the covers and of course they cracked. I replaced them all with McGard lug nuts. Problem solved.
TinCan
graysailor is offline   Reply With Quote
Old 04-22-2018, 02:46 PM   #10
Holly Springs , Mississippi
I believe Airstream started using solid lug nuts sometime during the 2017 model year. If yours has the two-part lug nut, be sure to (1) use only a six-point socket, (2) be certain the socket is pushed as far in as it will go before applying torque to it and (3) replace them all with solid nuts as soon as practicable.
You can easily tell if your lug nuts are solid or two part, by removing one and looking at the base of the lug nut. You'll easily see the hydroformed stainless steel shell if it's two parts.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 04-22-2018, 07:36 PM   #11
Something Shiny
2017 27' International
Mosinee , Wisconsin
Our 2017 International Serenity 27FB was built in Aug.'16. It had the chrome cover capped lug nuts, which I replaced with solid stainless steel lug nuts purchased at a NAPA store. (Lots of options for solid stainless steel lug nuts are available on the market.) I took the easy route and had the NAPA guy look at ours; he verified the diameter and thread pitch of the factory nuts, which we replaced.
Don't forget to re-torque the new nuts upon replacement after 50-100 miles, especially on aluminum wheels. Your owners manual will provide the proper torque spec.
Mark & Gina
160W Solar roof mount + 160W Zamp portable
ProPride hitch, 1400#
2018 Ford F250 Platinum 6.7L Diesel
Pongo is offline   Reply With Quote
Old 04-26-2018, 12:57 PM   #12
Msherw's Avatar
2018 22' Sport
Forestburg , Texas
...unless you have the newer Goodyear Endurance tires then you want 78-80psi in them. They stopped with GYM and put the GYE on all 2018 22FB Sports as I understand it.
M!ke
2018 Sport 22FB / Toyota 4Runner 4.0L
WBCCI 18673 Heart ❤️ of Texas
Ham Radio Call sign NO5Y
Msherw is offline   Reply With Quote
Old 04-26-2018, 01:29 PM   #13
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
Most of mine are cracked on our 2015 International 19. Called the local airstream dealer and they have solid lug nut replacements in stock so Iíll probably go get some this weekend. Click image for larger version
Leilanisteve is offline   Reply With Quote
Converting from lug bolts to studs and lug nuts tim781996 Wheels, Hubs & Bearings 7 11-22-2014 10:23 AM
Nuts on lug nuts Steel rim spare tire!y Griff Wheels, Hubs & Bearings 4 02-13-2014 09:51 AM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 03:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 10:41 PM
lug nuts bambi david h Axles 2 02-10-2003 09:59 AM
