Old 05-25-2017, 07:57 PM   #61
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by SilverLife View Post
Rob;
Yes I have installed many sets of soss hinges, from extra large in hidden library doors to tiny ones in jewelry boxes. Firstly, ash is a dense fairly heavy wood, depending on species, moisture content and final thickness. You will need to have a fairly close weight of the table when finished, at hopefully less than 20% kiln dried. Given the weight, the hinges are sized accordingly. You want to select the SMALLEST size hinge to handle the weight. < snip >
Thanks so much for your guidance and insight!
I should have done a better job of describing the material(s) that I'm thinking of using for the table top. If I eventually do this, I'll almost certainly use Baltic birch for the table top with the 'mounting edge' made from ash; 3/4" X 3/4". I'll join the edge to the table top with biscuits or a tongue and groove joint that I'll make on the router table. That way I get the screw holding power of ash without having the weight of an "all ash" table.
I've build many projects using that very approach, but was never concerned about weight.... so, you may have a [much] better suggestion, and I'm certainly open to that.
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 07-09-2017, 07:59 PM   #62
SilverLife's Avatar
2017 22' Sport
Aptos , California
ID:	289092Click image for larger version
ID:	289093Click image for larger version
Using 8'6" Eureka aluminum poles to secure the awning in the down position and to attach an additional 11'6" x 9' fly to. The bungee snugs over the top of the pole to hold down the tarp and the hook end locks the pole cam in the up position.
"If you donít know what else to do, drink beer."-Wally Byam
SilverLife is offline   Reply With Quote
Old 07-09-2017, 08:10 PM   #63
waninae39's Avatar
2017 22' Sport
NCR , Ontario
does anyone have plans/details for addressing the wasted space in the 22FB bathroom?
Just to the right of the sink is a small opening. it does not hold much
there is a ton of space under the counter and to the right of the sink, My wife wants me to add more space. So far i have added the IKEA mirror to the wall next to the battery/grey/black level monitor.
I would like to build a small cabinet to the right of the toilet , right of the sink and under the counter
Also, how do you remove the counter?
waninae39 is offline   Reply With Quote
Old 08-24-2017, 05:38 PM   #64
2011 22' Sport
Portland , Oregon
I just wanted to say thanks for sharing all of this great info, you also saved me some money as the fact that you took a brand new AS and found so many things that needed correcting pushed us to look for a used model. We will likely apply some of your changes, or ones influenced by yours, to our 2011 22FB.
The dinette pedestal has got to be one of the worst things ever "designed", it is wholly inadequate. The two most significant flaws are, as you noted, that you sleep with a "hump" in the middle of the bed...and the other is that the pedestal itself is garbage.
In our case I couldn't get the pedestal to lower more than 1 segment (the upper one), it wouldn't budge at all...I tried and tried, even with all of my body weight it wouldn't move. I forced the thing apart and found that they use these tiny little screws on the bottom of the collapsing segments to keep them from over-extending and falling apart. Well somewhere in the last 7 years one of those screws loosened, as AS obviously knows nothing about thread lock or adequate thread bite (as you noted on your tail light install)...and the screw had embedded itself into the aluminum tube. The problem had obviously progressed for a while was there was shavings of the aluminum tube and a nice "trail" about 1/16" deep carved into it before the screw head deformed enough that it just bonded and wouldn't move.
I find it amazing that this dinette is still put into trailers, our family had a SOB TT and overhead camper that were built in the 70's and I swear they had a better dinette conversion than brand new AS. I could possibly overlook the pedestal itself if the bed was remotely useable, but that nearly 1" hump is inexcusable and will be one of the first modifications I have to seek on the trailer (other than electrical upgrades that are already in progress).
SilverHouseDreams is offline   Reply With Quote
Old 08-26-2017, 11:40 AM   #65
Boxite's Avatar
2008 22' Sport
We made our dinette into a permanent bed and to rid ourselves of the "hump" we used the gray/rubber/foam soft-floor-mats sold by Harbor Freight for walkways. They are cheap, 1/2" and interlocking. Doubling them (one on top of the other) brought the lower seating surface up to par with the table top. We put our mattress (ordered from foambymail.com ) on top of that and enjoy a sweet slumber now.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 08-28-2017, 11:18 PM   #66
waninae39's Avatar
2017 22' Sport
NCR , Ontario
led added under the seats
i added these LEDS lights
now we can see under the seats
http://www.airforums.com/forums/f295...ea-172034.html
Old 08-28-2017, 11:27 PM   #67
waninae39's Avatar
2017 22' Sport
NCR , Ontario
you can get the hinges form Lee valley
http://www.leevalley.com/en/hardware...=3,41241,62129
Old 08-29-2017, 09:16 PM   #68
waninae39's Avatar
2017 22' Sport
NCR , Ontario
replaced some AS cheap outlet with outlets with 2 USB
i have replaced some out the 115 15V outlets with "power2U" outlets.
they hahe
2x 115V 15A
plus
2x USB 2A
they have a door in-front of the USB. when its closed, the outlet used ZERO power ( for the USB)
only when the door is open, it does give usb power
this is want to looks like under the table in the kitchen area on our as 22FB
i added it when i added the LED lights to the LEFt or RIGHT area under the seats
ID:	293541   Click image for larger version
Name:	power2u-under kitchen desk.jpg
Old 08-29-2017, 10:54 PM   #69
2011 22' Sport
Portland , Oregon
they hahe
2x 115V 15A
plus
2x USB 2A
The LED storage lights are a great touch.
I just got a few outlets with USB ports too, but also to get tamper resistant outlets to make it a bit more child proof. Did you install outlet boxes too?
Old 08-30-2017, 06:40 AM   #70
waninae39's Avatar
2017 22' Sport
NCR , Ontario
yes i did add then.
not shown , one is behind the USB outlet and powers the Left and right storage area LED
this weekend i will add LED light to the exterior storage box
another deep dark location. the AS installed single led on the ext wall is neither strong enough nor sufficient
Old 08-31-2017, 10:02 AM   #71
2017 22' Sport
North Bay , California
Images: 11
yes i did add then.
There is a switched light in the exterior storage space on my 2017. It's not obvious, but it's in there.
The step light, I agree, is meager.
ohmman is offline   Reply With Quote
Old 08-31-2017, 10:51 AM   #72
waninae39's Avatar
2017 22' Sport
NCR , Ontario
I will be adding LED strip light to the roof of that area There is a removable panel under the bed. I will try to connect that to the existing meager light in that area. that way I keep that light and its switch will control the "roof light". There is a wall to the right with a pass thru. one of the LED panel will light up this area
Old 09-01-2017, 09:41 PM   #73
Boxite's Avatar
2008 22' Sport
I replaced the silly little step light with an ordinary License plate light fixture. MUCH BETTER!
I also added a "scare light" above the step light at eyelevel. It is on the same supply circuit but has a dedicated switch so that if the step light is illuminated, an additional switch turns on the scare light. Simple and very useful.
Rambox
Old 09-02-2017, 12:43 AM   #74
2011 22' Sport
Portland , Oregon
Would you share a photo of these? Trying to figure out what to do about that sad little light myself.
Old 09-02-2017, 03:00 PM   #75
waninae39's Avatar
2017 22' Sport
NCR , Ontario
lagum table added to replace sliding factory mode
see here for the lagum table
easily to modify with no tools
http://www.airforums.com/forums/f295...ml#post2003042
Old 09-02-2017, 03:05 PM   #76
waninae39's Avatar
2017 22' Sport
NCR , Ontario
add LED trips the external 22FB storage area
now we can see
http://www.airforums.com/forums/f295...ml#post2003047
Old 09-02-2017, 04:05 PM   #77
Boxite's Avatar
2008 22' Sport
Click on an image below to enlarge,...then you can "scroll" thru them all in a more viewable format.
The LED license plate lite brand was "Blazer" and bought at Tractor Supply for about $6. The RV wall switch from an RV outlet for $12, mounted it onto a removeable panel intended to service the shower faucet. I used that panel because it was easy to get to and directly behind where I mounted the scare light. I routed the wire by removing the original step light and running wire up inside the wall, into the interior space to get around a bulkhead, and then to the switch, which supplies power to the scare light from the step light. In other words, if the step light is ON...the scare light switch has power to it, if I wish to turn on the scare light. (We might leave the trailer for a walk at night and the original step light was poorly designed as it blinded you instead of directing light down onto the step. The little Blazer light only shines downward onto the step.)
The "scare light" was $4 from etrailer (an ordinary 4" fixture which I placed aluminum-foil tape inside for increased reflectivity) and the chrome surround also from etrailer, about $5. (I originally had installed an all-LED light fixture but didn't like it as it was too narrow-beam. In this ordinary fixture I used an ordinary incandescent GE-1156 backup lamp because it gave more generalized lighting to the entire area outside the trailer.)
I wired it with 14 ga stranded wire, and since it's on the original step light circuit no further fusing was required.
ID:	293871   Click image for larger version
ID:	293873   Click image for larger version
Rambox
Old 09-02-2017, 10:09 PM   #78
Surgpsych
surgpsych's Avatar
Burleson , Arkansas
Love this mod! When you have the chance, could you post a night shot with bother the step light AND scare light on? Also, thanks for listing the wire gauge and components. Big help! Keep em comin!
surgpsych is offline   Reply With Quote
Old 09-03-2017, 03:04 AM   #79
Boxite's Avatar
2008 22' Sport
I doubt a photo would reveal the true usefulness of the mod. Suffice it to say that it's impressively useful and illuminates the step completely... and the scare light illuminates the entire yard out beside the AS.
Rambox
Old 09-04-2017, 11:00 AM   #80
waninae39's Avatar
2017 22' Sport
NCR , Ontario
new drawer added to as 22FB bedroom area
i added a new drawer to the 2017 AS sport 22FB bedroom area
it uses BLUM full extension drawer slide system
you need a good wood workshop, be proficient in cabinet making and know how to design and build with BLUM h/w to do this job.
it took about 2 days after work to cut build and install this drawer
http://www.airforums.com/forums/f295...ml#post2003865
2017 Airstream Walk Through & Model Year Improvements Colonial Airstream Commercial Listings 23 06-28-2016 12:30 PM
Frig Shelving improvements. Mariner Refrigerators 2 07-03-2004 11:19 PM
minor improvements nwclassic Our Community 0 09-17-2003 02:27 PM
Top 10 improvements for MHs ViewRVs Airstream Motorhome Forums 11 03-09-2003 08:53 PM
Interior improvements PeterH-Airstreamer Airstream Motorhome Forums 18 04-02-2002 01:27 PM
