09-12-2019, 02:33 PM
2024 23' International
South of Austin
19CB Owners ( 2018 ) - What is your standard cold tire Air Pressure?
What do you all run in the 19CB for tire air pressure?
I'm wondering if it may affect some of the road rash damage I'm seeing inside where the fridge has come loose or stove etc.
I've been starting with cold tire pressure of 73.
After driving in the heat in TX, tire pressures on my TST tire monitor gradually increase to the mid 80s.
Recently on a trip to WY a few weeks ago, I saw 88PSI after everything heated up, so I dropped a couple PSI on the way home before things heated up.
I'm probably in the 4300LB Range on weight. I have not checked it, but we dont pack a bunch of stuff. So I would be surprised if I was up to the 4500 Gross rating.
I need to get a scale.
But anyway, what do you all run on your 19CB's ?
09-12-2019, 06:11 PM
2019 25' Flying Cloud
Hendersonville
, North Carolina
TP fpr 19'
Get all loaded up for travel. Go to the CAT Scale. See what each tire on the trailer is supporting. Go to the inflation chart for your tires. (assuming you have GY Endurance tires) Inflate to 5 or so pounds above the minimum recommended PSI. Should get you close.
If your experiencing stuff breaking and general dishevel after towing you might look at your WD setup. Some WD hitches have more flex and provide a softer ride for the trailer. Over stiff WD bars? Transferring to much weight back to the steer axle? What kind of tow vehicle do you have? Is the rear axle to stiffly sprung? Lots of things can contribute to a messy trailer after towing. Consider looking at all angles to get that perfect setup.
09-12-2019, 06:17 PM
South of Austin
Thanks for the suggestions. My profile has a pic of my setup.
09-12-2019, 08:11 PM
2022 25' Flying Cloud
NCR
, Ontario
56 lbs cold for a 22fb sport bambi with 16" Michelin tires
they can go up to 70 lbs hot
still under the 80 lbs max for the tires
09-13-2019, 04:04 AM
South of Austin
I'm only looking for tire data on the 19CB.
09-13-2019, 05:23 AM
2017 16' Sport
N/A
, N/A
I get my tire information what’s embossed on the tire, never had any such problems with inside trailer upsets refrigerator or elsewhere. I do travel on paved decent roads when it’s bad roads I slow way down. Camco sells adjustable bars for inside of the refrigerator to hold items back from toppling over.
09-13-2019, 06:12 AM
South of Austin
Right. I know what the tire says. Max 80psi. But Wonder what everyone runs for cold pressure on their 19cb.
09-13-2019, 07:05 AM
2017 16' Sport
N/A
, N/A
It’s possible you may have to look at other dynamics to correct problems you wrote about in your original post. It’s normal for PSI to increase as tires heat up from road friction, this is taken into account from cold pressure values.
09-13-2019, 07:42 AM
South of Austin
Of course. Though my main question is what others are using for a typical PSI.
09-13-2019, 03:17 PM
2018 19' Flying Cloud
2018 Basecamp
Charleston
, South Carolina
19cb Tire PSI
The side sticker on 2018 19CB states 80PSI. Should we ignore this recommendation from Airstream?
09-13-2019, 03:42 PM
South of Austin
If you are always at max Gross, 80 works.
But I am not.
09-14-2019, 02:41 AM
2018 Basecamp
Charleston
, South Carolina
Maybe I am missing it but I do not see those limits stated on the sticker.
10-03-2019, 06:29 PM
2007 19' Bambi
Glen Mills
, Pennsylvania
I run 70lbs cold on my 2007 19CB. It heats up to 75-76 on warmer days. By weight, I could probably go lower, but I have had no issues at that pressure.
10-03-2019, 08:30 PM
South of Austin
Thanks. i was running 75 cold. And thinking i should run closer to 70 myself.
10-08-2019, 04:24 AM
2017 19' International
2018 25' Flying Cloud
Monrovia
Look up on the Goodyear web site the tire pressure weight rating for your tires. Based on weight the pressure is considerably less than 80psi. There are a few trade offs to lower pressure, softer ride, higher rolling resistance, lower mileage, higher running temperatures. Ours are set at 70psi.
10-08-2019, 01:50 PM
South of Austin
Right thats why I was posing the question on what folks are setting theirs to. If the trailer was loaded to max, then closer to 80 would work but then again, PSI and temp increases as you roll down the road.
10-08-2019, 02:09 PM
Newport
I have a 2018 19' FC with the same tires as yours. I'm pulling it with a Dodge Ram 2500 which is typically lightly loaded so somewhat stiff in the knees. Equalizer hitch with 400 lb bars.
The first two seasons we towed the Bambi I ran the tires at 80lbs cold per my dealers instructions. Never had a problem, although on hot summer days at freeway speeds I saw tire temps getting quite high and pressures pushing 100 psi.
Then mid-season last summer I dropped to 65 cold based on numerous comments on this forum and my concerns about the high pressures on hot days. Same roads, same destinations, same speed, same TV. I started experiencing AC vents falling out and screws loosening up, so earlier this year I bumped the cold pressure back up to 70.
And no I have not put the trailer or TV on a CAT scale. We live about 61 miles from the edge of the earth so it's a very long drive to the nearest scale.
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
10-08-2019, 02:42 PM
South of Austin
I have 8K rated bars on my hitch, so I dont think it would be bad idea to consider the lower rated bars, on my end as a side note to this.
When I started out, I was at 75PSI and after a long trip recently where I saw 88PSI I decided to start dropping cold PSI to 72.
My fridge has come loose twice since it was new in 2018 and I've been wondering if My tire PSI Was too high, contributing to it or/and crappy roads .
So, I was thinking about dropping it more to around 70 for a while cold and go with that.
So, so far most of us are at the low 70 range which seems to confirm my idea that the slightly lower PSI is probably good idea.
10-08-2019, 03:03 PM
Tallahassee
I was running 80 pounds but after I popped a couple of interior rivets I knocked it down to 75 pounds cold (it is possible, of course, that the rivet-popping was unrelated to tire pressure).
I live in the South, and in the summer the tires heat up and the pressure runs up there quite a bit, but I don't let out air.
Keep and eye on quick changes in temp and pressure via the tire monitoring gizmo.
10-08-2019, 03:50 PM
Berkel-Enschot
, Noord-Brabant
By higher outside temp the pressure can go up that high. And " comfort" then is low.
But maybij it can be safely lower.
Give this " pigheaded Dutch selfdeclared tirepressure- specialist " the needed data of TT and tires, and I will calculate for you.
