Old 05-08-2015, 09:53 PM   #21
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Please do not tow more than a 19 with a 4 runner. It has the power but not enough weight. We lost our 20 when a big tanker truck doing 90 bumped our trailer with his rig. I almost lost my life as well. I was in the hospital for a month. We had a Hensley hitch but when the trailer swung over by the bump it took the 4 runner with it. The 4 runner just wasn't heavy enough. We rolled over. We had at least 30.000 miles without any issue at all until the accident happened. We tow our 22 with a Sequoia now but wouldn't go a foot bigger with the Sequoia.
mhilley is offline   Reply With Quote
Old 05-09-2015, 06:46 AM   #22
PaulG_4307's Avatar
2012 22' FB Sport
Yikes! What year/model was your 4runner? 4 wheel drive? The Hensley hitch transfers sway to the tow vehicle. Do you feel a Sequoia will avoid rollover in another tanker truck hit?
PaulG_4307 is offline   Reply With Quote
Old 05-09-2015, 07:47 AM   #23
richw46's Avatar
Lexington , Kentucky
Toyota has changed the 4Runner dramatically over the years. 2003 was the first year they offered a V8 but initially they had only a bumper hitch with a 5,000 lb. capacity. Starting in late 2003 MY and through 2009 (but '09 V8s are rare, only a few were sold) the tubular frame hitch was installed and towing capacity was 7,300 (2WD) 7,000 (AWD). Maximum tongue capacity is 700 lb. If you're looking at a 2003, make sure it has the tubular frame hitch.
The 5th generation, starting in MY 2010, offered only the V6 and 5,000 towing. The current generation reduces that even further, now down to 4,700 towing. In my opinion, they've pretty much gutted it as an SUV.
The Sequoia now offers the same capacities that the V8 4Runner did but with additional HP and torque. My 2004 V8 has no trouble with my 2006 23' Safari but if I were buying a new TV today, I'd opt for the 5.7 L Tundra or the Sequoia. (Probably the Tundra so we can go for a 25-27' AS ).
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 05-09-2015, 12:35 PM   #24
PaulG_4307's Avatar
2012 22' FB Sport
I'm getting Tundra envy....put a 4000kw propane generator in the back and boondock with Air Conditioning....tempting.
Old 05-09-2015, 04:30 PM   #25
mhilley's Avatar
2000 23' Safari
Paul, the 4runner was a 2008 w/o 4 wheel drive. The a/s was a 20 foot Bambi. The Hensley was a cub. I have a 23 Safari now and tow it (very carefully!) with a 2010 Sequoia 5.7. The Sequoia is much heaver than the 4 runner, has a longer wheelbase, and has a wider track. Remember all, always expect the unexpected.
Old 05-10-2015, 09:17 PM   #26
2005 19' Safari
Chico , California
Well we went for it and pulled the trigger on a fine certified 2012 4Ruuner SR5 4WD. What a great SUV! The Aistream guys in Paso Robles tell me I should be fine towing our 19' 4400# Bambi with it. Will stay with Equalizer. Does anyone with a Gen 5 4Runner have a photo of where your brake controller is mounted? Mine's a Tekonsha Prodigy.
richcrest is offline   Reply With Quote
Old 05-12-2015, 01:20 PM   #27
2017 25' International
2014 16' Sport
Cardiff , California
2013 4Runner Brake Controller location
Here is where I put mine. It is out of the way of the airbag and my legs. 1st attempt at a photo so.. maybe this will work. Looks like I get to vacuum after work today.
armstrs is offline   Reply With Quote
Old 05-13-2015, 11:31 PM   #28
2005 19' Safari
Chico , California
Dear RFR36--Do you lock out the overdrive using Sport Mode when you tow? What about turning Eco off? Thanks.
Old 06-29-2015, 12:36 AM   #29
2014 19' Flying Cloud
Eugene , Oregon
Our 2013 Highlander tows our 19 FC effortlessly. We were going with the 4-Runner, but changed to the Highlander for the lower aspect, style we prefer, and gas mileage. It runs a 3.5 V-6. We concluded that the "big truck syndrome" has some false assumptions in practice, and is a source for over powering ASs. We climb steep grades (5-6 percent on the passes) easily on most trips, finding smooth slowing and stopping power on the way down. Curiously, our 2008 Highlander 3.2 was rated at 5,000 GVW for towing. Our 2013 3.5 is rated the same (?). The 4-Runner should be a gem of a tow vehicle for a 19.
Dave-Nancy is offline   Reply With Quote
Old 06-30-2015, 10:10 PM   #30
2007 19' Safari SE
Los Gatos , California
My wife has a 2010 4-runner and I have a 2011 Tacoma, both 6-cylinder models, and both tow our 19' Bambi very well. 4-runner has automatic transmission and my truck has 6 speed manual, and again both work just fine for towing.
RyeL is offline   Reply With Quote
Old 07-01-2015, 01:04 PM   #31
2005 19' Safari
Chico , California
When towing with your Gen 5 4Runner, do you use overdrive, or shift into Sport mode? Do you turn off the Econ mode?
Old 07-01-2015, 06:12 PM   #32
PaulG_4307's Avatar
2012 22' FB Sport
My 2010 Limited runs on H4F - Everything is automatic with the 5speed transmission and overdrive. Only change for offroad to H4L or L4L. Limited is AWD.
Old 06-25-2017, 08:37 AM   #33
larry9000's Avatar
2006 16' International CCD
Steamboat Springs , Colorado
Tongue weight is a key issue
I'm updating this thread with my observations. We are new AS owners, hauling a 2006 16' Bambi with our 2016 SR5 4runner, with the 4L V6 engine.
First, someone made the comment of how 16' Bambi increased in weight by 800# between 2006 and 2007. I studied this before we got our Bambi, and the answer to this riddle is in the AS fine print. 2006 lists the AC and furnace as options, while 2007 onward these were standard. AS quotes the dry weight without any options, so of course 2006 was lighter without AC and a furnace- even though I'm sure everyone included them. The plaque in the wardrobe shows the actual unloaded weight of the AS with the actual factory options. According to the plaque, with full fresh water tank, LP, and empty black water tank the AS weight was 3423, just 77 pounds shy of the 3500# GVWR. In another thread I satisfied myself that the GAWR was the critical spec and I had some significant leeway due to the amount of weight on the hitch that went elsewhere than the Bambi axle. I upgraded tires to D rated GY Endurance to get added margin. In any case, I estimate that I may be carrying 3700#, still well within the 4runner 5000# carrying capacity.
But the tongue weight is more problematic, and something I am still studying. Toyota specs the max hitch weight as 500#. Using the lever method in the AS manual, I measured the actual tongue weight of the Bambi as 495# versus a stated 430. The difference is the full propane tank, the weight due to options (My Bambi had solar, AC, and the furnace). And the fresh water tank was about 40% full with an empty black tank. Refrigerator empty and none of our clothes packed.Almost certainly we would exceed the 500# limit when packed, and clearly would be the case if we added a second battery on the hitch.
The question is what limits the hitch to 500#, and what can be done about it? Studying the 4runner forums on another site, I learned that 4th generation 4runners (MY 2003-2009) had two tow ratings, one for the V6 and one for the V8. The V6 rating was 500/5000, and the V8 rating was something like 700/7000. But, and this is key, the V8 tow package included a different hitch, that bolted to the frame directly near the outside of the vehicle. The V6 hitch bolts on a bumper cross member that itself is bolted to the frame. I read in the 4runner forums, but have not verified independently, that 4th generation V6 4runners were not compatible with WD hitches. Apparently the torsional forces on the bolt on crossmember could cause the member to twist. The V8 version solved this by attaching to the frame directly.
But I have a 5th generation, which started with MY 2010. There are no V8 options, and my 2016 came with the standard tow package of 500/5000. I crawled under the back to look at the hitch. It appear that the crossmember is now actually part of the frame. There are no bolts, just a big welded "tube" going around the back as part of the frame. The receiver is bolted to this tube. I contacted Toyota, and got an affirmative reply that I could use a WD hitch, at least for my 2016. This gets back to my original question, what is the root cause of the 500# tongue weight limit, and what can be done about it?
My hunch, and it is only that, is that the 500# limit has to do the short wheelbase of the 4runner and the lighter weight of the V6. It appears to be a similar hitch mounting scheme to the earlier V8s, and may actually be better since the crossmember is now part of the frame. Put on 500#, no WD, and the front wheel wells point upwards pretty high. I'd hate to drive it that way for any distance more than positioning it in a campsite. The front wheels must have much lower weight on them, which reduces stability greatly. While you may say that no one would drive it without WD, apparently that was the specified configuration for 4th generation V6s.
But I don't haul it that way- I use a WD hitch of course. The front wheel wells are only 1/4" raised with the WD hitch, and the combo drives nicely. I live in Colorado, and have taken it into the mountains. I keep it out of overdrive (I cruise with the S4 gear selected), and will downshift for significant grades. I may be slow in some cases, but the 4runner hauls it up. I have a Prodigy P3 brake controllers and set the boost at 1. This seems like a good combination. I had tried boost #2 coming down Rabbit Ears pass, which is 7% grade for 7 miles, and it was almost too much breaking by the AS, so I dialed back to boost #1.
My question to others is my logic: That there is some margin above the 500# tongue weight limit when using a WD hitch. As far as I can tell, it has an equal hitch or better than the 4th generation V8s that spec'd 700#. In the meantime I'm researching this more, and looking at what aftermarket hitches, if any, are available.
larry9000 is offline   Reply With Quote
Old 06-29-2017, 10:01 PM   #34
2005 19' Safari
Chico , California
Thanks Larry9000 for the detailed post. You have looked beneath the surface on a number of key variables. Mine is a 19' Bambi, GVW around 4400#, hitch weight ~490# with full tanks. Can you open your 4Runner clamshell door with the AS hitched on, standard shank? Mine looks like it might hit the jack post. And what about a trans fluid auxiliary cooler? From where I live there are steep grades in several directions. What kind of mileage numbers does your rig post? Thanks!
Old 06-30-2017, 12:19 AM   #35
Eugene , Oregon
No Tow Problems with a 3.5 L 2013 Highlander and FCl-19.
Originally Posted by norcal bass View Post
Does anyone out there tow their 16 or 19 bambi with a Toyota 4 Runner? Just curious if it's within legitimate weight rating and, if so, how it handles.
Thanks.
Seems odd to have the "reply" be "Quote" ... Hope this goest through (?).
As I have written before in this forum; our Highlander V-6 with 5000 tow rating and the OEM Towing Package has no issues with up-down-hils-braking-etc. I hardly notice that I am towing my 4000 lb AS, most of the time.
Where we like to go the most has an 2500 ft elevation rise over the 2-hr span of driving. We average 16 mpg going up. My heat gauge never moves. I keep it between 50-55 mph, intentionally.
We have a professionally adjusted Equalizer hitch set-up.
I solved my only real concern, with this set-up, by adding a Voyager rear view camera. I have it monitoring-on all the time. Now, I change lanes, and check for the occasional highway racer, while knowing the real story behind me. Side mirrors just don't do the trick.
Dave in Oregon
Old 06-30-2017, 12:23 AM   #36
Eugene , Oregon
Dave in Oregon
Old 06-30-2017, 09:05 AM   #37
Thanks.
Have 19 foot Bambi andTV 2011 4 Runner...I have had this combination for 5 years and about 25,000. 4 Runner is equipped with factory tow package. I would not tow without tow package. 2011 has 5,000 mile tow capacity and we use an equalizer hitch. This combination has worked very well traveling all over the west. Perhaps a little slow on steep grades. I use manual shifting both up and down grades. Most highway driving in 5 gear. Mileage has averaged at about 14 mpg. I love my 4th 4 Runner but would probably not tow anything larger. Tailgate opens when hitched but that is due to a 10 reach on hitch..the distance between number and ball. The 2008 Bambi weighs 3700 lbs. and try not to exceed 4500lbs.
RFR36 is offline   Reply With Quote
Old 06-30-2017, 11:11 PM   #38
larry9000's Avatar
I just got back from pulling my 16' Bambi up to Trappers Lake, CO, 9800' with my 2016 4runner. I got 12 mpg going up, which is a 130 mile trio from where I live in Steamboat Springs, CO. I normally get 13 or so average, which is what I got for the whole trip when returned. The 2016 4runner has the factory tow package as standard, including wiring for a brake controller, a receiver for a hitch, and an auxiliary transmission cooler.
The 4R was able to pull the Bambi up, though I would need to manually downshift to keep the power needed in a climb. I would often just go slower in a lower gear, but with the 4R revving nicely. In the final climb to the campground on a steep gravel road, I put it into 4WD just to prevent slipping. I used 2nd, and even first for a while to go up steep gravel road sections.
In general, I think you should downshift to whatever gear gets you 3K-4K RPM and that speed is the result you get. Period. And, under those constraints, that Toyota engine will crank you up a mountain.
That said, I was surprised how going downhill on gravel my brakes would lock up on the Bambi first. I have a Tekonsha P3 set at boost level 1. This happened numerous times. I changed the P3 to Boost off, and then relied on the 4R in 4WD to supply more engine braking. This was a great improvement, and then changed back to a Boost 1 on firmer road, even packed dirt road.
Oh, I have an Equalizer hitch, and the 4R hatch doesn't clear the hitch height. It's enough to sneak some things out when it's partially open though.
Old 07-01-2017, 12:34 PM   #39
Eugene , Oregon
Interesting that one person with a 4-Runner and 16-ft Bambi slows down on steep hills, where my 3.5 Highlander rarely does (?). It may be the OEM towing package transmission (?). Yesterday, I spoke with the Toyota dealer rep. I asked why the 4-Runner has the same towing capacity as my Highlander (5000). They "suggested" that it is because the 4-Runner is a bit more "top heavy." Now, that comment might cause some literature ... Ha! I do wish that Toyota hadn't up-sized all their models, over the past few years. I do like my larger Highlander (we have had two of them). But, I would have purchased the 4-Runner, if it wasn't so darn tall and generally larger than the older models. That being said, I am totally sold on Toyotas. What do you think? Dave
Old 07-02-2017, 09:42 AM   #40
larry9000's Avatar
One reason why I may be slowing down with my 4R more than you do Dave is that I live at 6700' and our last trip was taking the Bambi up to 9800' on top of a steep gravel road. There is significant difference is power between high altitude and what I experience when below 3000' on the west coast.
That said, I agree that the 4R has grown in size over the years. So have Ford Explorers and Nissan Pathfinders, which we have previously owned. The 4R was on the limit for size when we were shopping a year ago. I would have preferred a V8, but didn't want to go even larger with the Sequoia. We chose the 4R before we considered a trailer, so we wanted a light Bambi when we started looking at trailers.
Toyota 4runner and 19' safari bebelee Tow Vehicles 5 02-14-2009 03:49 PM
Another 4runner question mffjm8509 Tow Vehicles 24 02-13-2009 05:25 PM
Toyota 4Runner TV ? OhScottyOh Tow Vehicles 22 04-30-2008 11:47 PM
Side Mirrors for 4Runner kitchenclose Tow Vehicles 6 01-21-2007 07:26 PM
4Runner tow vehicle inflt 1997 - 2004 Bambi 24 05-18-2005 11:15 AM
