01-11-2014, 09:27 PM
#21
Tom and Phyllis
2018 30' Flying Cloud
Tuscaloosa
, Alabama
My thoughts on a trailer-tow vehicle like this is one I use in real life with different utility trailers. A road test.
Does the tow vehicle have the power to move the vehicle, even up a reasonable incline?
Can the tow vehicle stop the trailer within a safe distance?
When hooked up does the headlights still light up the highway or does it shine up into the trees? (this may take a night-time test) This lets you know if there is too much weight on the rear axle of the tow vehicle.
Remember a safety tip! If too much emphasis is put on balancing the load front to rear, then you may not have enough weight on your rear axle to prevent a jack-knife. When the rear axle is where loss of traction is during a panic stop, then a jack-knife condition is imminent. During a hard stop weight will shift to the front axle so keep the rear axle heavier.
01-29-2014, 04:02 PM
#22
Jack Dog in So Cal
2013 16' Sport
Orange
TV Vehicle
We tow our 2013 16' Bambi with a 2010 Jeep Liberty 4x4 with a posted 5000 pound tow rating.
We use the Prodigy 2 brake controller with a equalizer hitch and sway control bars. I suggust not towing with either.
The Jeep 3.7 has only 210 hp so it does ok on heavy grades so I assume you're BMW with more hp and torque should do even better.
Recently we stopped at a commercial weigh station and the Bambi with full LP tanks, half tank of fresh water and our stuff was just over 3,300 pounds.
We're upgrading to the Grand Cherokee with the new six so that should solve our lack of performance towing the AS.
Jack Dog in
So Cal
01-29-2014, 05:32 PM
#23
St. Catharines
, South Western Ontario
Jack, you are almost a ton under the Jeeps tow rating and you are towing one of the most towable trailers on the market. What seems to be the problem? Or do you think the Jeep is over rated??
01-29-2014, 06:10 PM
#24
2007 23' Safari SE
Central
, Connecticut
To be fair, JackDog going from the Liberty (which doesn't really handle that well and has a lump of an engine) to the Grand Cherokee (handles better, and the V6/8spd combo is very, very good at towing) seems to be a solid move forward.
I was very, very impressed at how well a 2014 GC V6 towed my 23' trailer. Not as fun as the Hemi/8spd or the EcoDiesel, both effortless towers, but very capable all the same.
Tom
Now: 2007 Safari SE 23' "Anne" towed by 2011 Dodge Durango "Herman"
Before: Argosy Minuet and T@B, towed by various Honda Odysseys
01-30-2014, 11:51 AM
#25
Jack Dog in So Cal
2013 16' Sport
Orange
Jeep Liberty
The V6 in the Liberty isn't really the problem; the major hamstring is the antiquated 4 speed automatic. Even with the tow/haul button locking out the OD the transmission hunts and seeks and will overrev when pushed. I had my transmission guy install a trans cooler and a shift kit which has helped but he told me that he gets alot of these into his shop with blown seals and other maladies.
As far as handling with my hitch setup and the excellent road manners all AS's have I've been able to stay on the road even in extremely high cross winds when traveling through the Mojave desert when everthing else has had to pull over and wait out the winds.
I love everything else about my Jeep, looks, size, great foul weather / off road performance. I've even ecked out 15.5 mpg on several occasions.
It's sad that Jeep instead of upgrading this vehicle and making it better decided to go with a Fiat car based SUV with bizarre styling and minimum towing and off road capibilities; a Jeep in name only!
Hopefully this time next year I'll be able to tackle those pesty grades with the Grand Cherokee. I love the hemi and if I was towing one of the larger AS's I'd go with the V8 but the new Pentastar V6 should be more than enought to tow the Bambi. Oh by the way on my previous post I meant to say that I would not tow a trailer without the aid of sway bars and a equalizer hitch.
Jack Dog in
So Cal
01-30-2014, 11:52 AM
#26
2013 30' Classic
Greenwood
, Mississippi
The Jeep Liberty is actually a strong tow vehicle, but a gas hog, also.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
01-30-2014, 12:35 PM
#27
Jack Dog in So Cal
2013 16' Sport
Orange
Liberty MPG
You are correct about the MPG on the Liberty. I'm a featherfoot driver and in regular driving w/o the trailer the best I've been able to do is 15 city / 21 hwy!
I think most people in this forum will agree when towing a trailer you can acutally get better MPG towing with a more powerful TV since your not overstressing the motor and constantly pushing the rpm levels up.
Maybe I should keep the Liberty and dropping a hemi drivetrain into it! Ummmm....
Jack Dog in
So Cal
01-30-2014, 01:27 PM
#28
1984 34' International
Toronto
, Ontario
You don't need all that much power to tow an Airstream.
I measured hp output (at the wheel) of my own vehicle (a Honda Odyssey) and the highest I could get it was 148hp when accelerating from a standing start up a sizeable hill. On an average day on the highway there are very few times when the rig demands more than 50-60hp to keep things moving at 60mph.
Average rpm at that speed are 2300, the Ody's engine is a V6, delivering a max of 240hp. Gas consumption is around 16mpg at that speed.
I tow a 1984 34' International, it weighs in at around 7000lbs.
01-30-2014, 01:46 PM
#29
2011 28' International
Chatham
, Ontario
Jack Dog in
So Cal
That's not been my experience.
I average between 12 and 13 mpg over the year with my Toyota Sienna (3.5l 260hp) towing my 7,000 lb 28' International. From the reading I've done here that's pretty much the same for the majority of tow vehicles, regardless of their size.
Where smaller vehicles have the distinct advantage over their bigger cousins is when NOT towing.
01-30-2014, 03:42 PM
#30
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Dear Andy - Our Guru in Canada
Dear Andy, half of Canada seems to come to Virginia Beach on vacation. Most stay at Holiday Trav-L Park. Therefore I hold out the hope that you will be visiting us here sometime. I don't know if you've ever visited our fair city, but if you do plan to, please call me or PM me, I'd like to thank you personally for all of the good things you do for the Airstreaming community.
Sincerely Paula Ford
01-30-2014, 04:06 PM
#31
2001 25' Safari
London
, Ontario
Not meaning to nit-pick, but that's not my experience. I don't disagree that as far as MPG is concerned, smaller displacement gas engines don't perform any better than larger displacement gas engines when it comes to towing duties.
The difference with a small displacement aspirated gas engine is that it needs to rev much higher than a larger displacement engine to achieve optimum torque. It has been my experience that anyone used to towing with large-displacement engines tend to get un-nerved when towing with small-displacement engines because they aren't used to hearing the engine at high RPM's and assume the engine is going to break and the gas mileage is going to pot.
The fact is that smaller-displacement engines ARE DESIGNED to run continuously at higher RPMS and can deliver essentially the same MPG as their larger displacement cousins. It's not intuitive, but that's what I have observed.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD • Hensley • DirecLink • McKesh
Set-up by Can-Am RV
01-30-2014, 04:19 PM
#32
2012 25' Flying Cloud
Battle Lake
Originally Posted by Lucky Tom
. . . Remember a safety tip! If too much emphasis is put on balancing the load front to rear, then you may not have enough weight on your rear axle to prevent a jack-knife. When the rear axle is where loss of traction is during a panic stop, then a jack-knife condition is imminent. During a hard stop weight will shift to the front axle so keep the rear axle heavier.
That kind of goes against traditional weight distribution thinking of returning at least the original load to the front axles, and in some cases of heavy tongue weight maybe more.
During a panic stop I think the attached trailer will also shift weight forward keeping the truck's rear wheels on the ground. I've had a few of these stops using good weight distribution and everything stayed in line.
Doug and Cheryl
02-11-2014, 09:02 PM
#33
sport 16 and vw touareg
we are very happy with the touareg as tv with our new 2014 sport 16. the tv is overkill and even use weight distribution.... tv with diesel doesn't know the trailer is behind regardless of hills, etc.
02-16-2014, 07:09 AM
#34
Milton
, Georgia
Can't wait to hear how it turns out. I'm new here and we have yet to purchase a Bambi, but are hoping to pull it with our BMW X5 xdrive30i. Need to research how to get it done, as I really don't want to buy another car either!
02-16-2014, 11:43 AM
#35
Vancouver
, British Columbia
Originally Posted by Drivera
...hoping to pull it with our BMW X5 xdrive30i. Need to research how to get it done, as I really don't want to buy another car either!
You may want to check out xoutpost.com for BMW X5/X3 specific towing info, including various receivers and installation instructions. WDH info is more complete here.
Jeff
02-16-2014, 03:37 PM
#36
2008 16' International CCD
Brattleboro
, Vermont
Originally Posted by wrlwnd
HELP! We just bought a 16' Bambi and it has sat in the driveway now without moving 1" for over 4 months and no hope in sight. We have a BMW X3 that should tow it fine, but....BMW says you can't use a weight distribution anit-sway system; the Bambi dealer says don't tow without it. I installed a tow package on the X3. Dealer told me that included trailer brake control...not true! So now I've bought a wireless trailer brake control box. Everything we do goes round and round and everyone we talk to tells us something different. DOES ANYONE TOW A 16' BAMBI WITH AN X3? From reading, I've learned a Rav and 4 Runner will. They must not have a unibody frame, but must have a solid frame? DOES ANYONE TOW WITHOUT THE ANTI-SWAY WEIGHT DISTRIBUTION? HAS ANYONE USED A WIRELESS BRAKE CONTROL? I don't know what to do! I'm looking at Tacomas and Ford 150s now but that expense was not factored in when I bought the Bambi. We're about ready to throw in the towel, forget the whole thing, and sell it. Any insight...anyone?
We have a 16' Bambi and tow with a Land Cruiser using a Reese weight distribution sway control hitch. I suppose you could say the LC is overkill but we just like the LC. kimball
02-16-2014, 03:59 PM
#37
2014 16' Sport
Chicago
We will be towing our 2014 16' Sport with a 2013 Volvo XC70 T6 AWD. We feel that with the prodigy rf brake control and the fast way hitch setup that our AS dealer recommended that we should be able to tow without issue. Stay tuned!!
03-02-2014, 08:45 AM
#38
2014 16' Sport
Alliance
, Ohio
Hi,
I have been keeping up on the thread but am still so confused. What is the smallest GVWR I should look for in a tow vehicle. I am looking at a Chevy Traverse (5,500 GVWR) but would like to go with an Equinox (3500 GVWR) if I can get away with it. It's just me, my husband, and 2 dogs.
Thanks so much for any help
03-02-2014, 05:24 PM
#39
'15 Flying Loud 20' Bambi
2014 16' Sport
2015 20' Flying Cloud
2021 25' Globetrotter
small city outside a big one
, south of most, north of some
If the manufacturer says 3500 and you want to tow a 16' Bambi, you are within the limits I suppose. I could do 5000 with my FJ Cruiser, but I wouldn't. I do a 16' 3500# Bambi and really would not want any more in back of it, partially because the tranny is not really aligned for towing (rock crawling is more like it). But also because the weight to TV weight should make you think twice in a stopping situation.
Also as stated above the high RPM's do make me think twice as ultimately the number of RPM's will determine when engine components fail. Higher RPM, more revolutions, more wear, less mileage before rebuild (or failure).
03-03-2014, 07:39 AM
#40
2008 22' Safari
Oracle
Nonsense, look in the Honda Ridgeline owners forum and you will find many of us with over 180k and not looking to rebuild anytime soon. Also look to see what engine is used in the Brickyard race.
