Old 07-10-2016, 12:16 PM   #1
2016 16' Sport
Longwood , Florida
15 Amp Shore Power
We just purchased a 2016 Sport 16. During our our orientation, the dealer said we can plug into a 15 amp circuit at home and run the AC unit if we had the furnace and refrigerator turned off. Does this sound right? Has anyone tried it?
fdelle is offline   Reply With Quote
Old 07-10-2016, 12:47 PM   #2
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Check your owner's manuals (one for the Dometic AC should be in there) for the spec sheet on current draw (amperage) for the unit.
That disclosed, I wouldn't.
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Old 07-10-2016, 01:17 PM   #3
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
All thing being reasonable and normal, it should work fine!
Old 07-10-2016, 01:28 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would not do it. You could slowly cook the outlet you are plugged in. Along with the 15 to 30 amp adaptor. Not to mention causing permanent damage to the A/C.
Old 07-10-2016, 01:46 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I had a licensed electrician install a 30 amp line at my home to code. My AC would not run on 15 amp. Nice to have full hookups available at the house.
MICHAEL
Old 07-10-2016, 01:48 PM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
The AC manufacturer's spec's says to use a 20 amp circuit, minimum.
The AC might start and run on a 15 amp, but sooner or later damage will occur.
But, before you decide what to do, check the breaker for the receptacle where you plan to plug in, it could be 20 amp. The receptacles in my garage are on a 20 amp breaker. If you use a 20 amp receptacle you must keep the power cord short and/or use the correct gauge wire. Do not use extension cords that are to light.
I do this occasionally on my 25' when I have a task to do inside the trailer on a hot day. I do not leave the unit running for hours and hours. I use one 25' 10 ga extension cord connected to the power cord on my trailer.
Careful though! If the receptacle is to distant from the breaker/power supply or the receptacle itself is not properly rated or it the adapter is not properly rated, there may be too much current loss even with a heavy cord.
add edit:
You will need to turn off the refrigerator and the converter. The furnace is 12v, so not an issue (and it should not be running when air condition is need).
Instead of worrying about individual appliances, I turn off all of the breakers except two, the main and AC.
Old 07-10-2016, 02:24 PM   #7
Gainesville , Florida
Is it an 11000 unit. If so it might run on 15 amp probably 20.
Old 07-10-2016, 02:48 PM   #8
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
It's perfectly OK as long as you're not trying to use more than 15 amps, and as long as you use an adequately sized (10 or 12 gauge) extension cord, that is not too long.
So, if you need some lights to work, or maybe to pre-cool the fridge on electric before a trip, you'll be OK. If you try to run the big stuff--air conditioner being the worst offender--you'll overheat something. Hopefully, the house circuit breaker trips before any real damage is done, but an AC will try to run with insufficient current and burn itself out.
All electrical equipment should have a label on it somewhere that tells you how many watts the thing needs. A watt is a volt times an amp, so 15 amps x 120 volts gives you 1800 watts at best. Motor driven appliances require much more current to start them than they do once running. Treat the power you have available like a bank account, and don't overspend.
What I'm trying to encourage here is called load management Get familiar with the load each item in your trailer puts on the electrical connection. Know what you can run with 15 amps, with 20 amps, and with the full 30 amps available. Some load managing is still needed even with 30 amp power. AC, plus microwave usually doesn't work. Hair dryers are another heavy load item.
Old 07-10-2016, 03:04 PM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
Your first consideration is what is on the circuit in the house, how long is the run to the panel, and what type of wire is feeding the receptacle.
You are about as close to the edge as you could get and no dealer ever told the truth.
2004 Excursion 4x4
Old 07-10-2016, 03:04 PM   #10
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
This is a link to your AC specs. It clearly tells you the power requirements.
http://www.dometic.com/QBankFiles3/E...I-AC_17729.pdf
Old 07-10-2016, 05:00 PM   #11
Long Island , New York
Welcome to the forum!
Please ask the dealer to put the 15 amp circuit being OK in writing.
Please read the Dometic specs brochure just posted by A W Warn, which says a 20 amp circuit is required.
Using a 15 amp circuit, assuming the circuit breaker does not trip, would harm your A/C over the long run IMO, even if you use the correct #10 or #12 extension cord.
Old 07-11-2016, 11:16 AM   #12
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I tried running the a/c on a regular wall socket.
It fried the receptacle.
I have since had an electrician install a 50 amp plug and shut-off.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-11-2016, 12:54 PM   #13
2016 30' Classic
Rocklin , California
If you really think about it ,installing the correct amps is cheap insurance on your investment. Also, the purchase of a surge protector is a really good idea. Consider the cost of replacement of the electrical systems in your trailer. It is a no brainier.
Gamehawkers is offline   Reply With Quote
Old 07-11-2016, 01:15 PM   #14
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The AC unit will run on a 15 amp circuit and will slowly but surely destroy itself. Perhaps not in an hour or two, but you are inevitably damaging your AC unless you are hooked up to a 30 amp circuit (actually, a 25 amp circuit would probably be fine but they do not exist.) Ignore your dealer.
Bob Martel
WBCCI# 5766
Shore power but no battery power RogerLG Lights - Interior & Exterior 6 09-28-2012 01:53 PM
shore power/battery power wiring NavyDavesCvl Electrical - Systems, Generators, Batteries & Solar 0 10-13-2010 06:32 PM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Converting from 30 amp to 50 amp shore power blkmagikca General Motorhome Topics 8 03-28-2006 01:20 PM
