Old 06-01-2004, 09:09 AM   #1
DEO
DEO's Avatar
West of Boston , Massachusetts
Spare Tire
I was suprised when I looked under my trailer and noticed that a spare is not standard equipment. In any case I now need to purchase a spare tire and rim. I found the tire at The tire rack but my question is do I have to buy a special rim?
DEO is offline   Reply With Quote
Old 06-01-2004, 09:58 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Spare Tire
Greetings DEO!
Yes, there are special considerations when purchasing a rim for your Airstream's spare tire. The main one is weight carrying capacity. Generally, the advice is to look for a weight carrying rating of at least 2,600 pounds. My tire dealer was able to order rims of the proper size, weight rating, and designated for trailer use when he ordered my Marathon ST tires several years ago (1995). At that time, the rims were $49.00 each. Inland RV is one of the sources for the correct wheel on the Internet.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 06-01-2004, 10:07 AM   #3
Penguin's Avatar
Where do I store that spare?
While we're on the spare tire topic, where do folks store theirs? The best place I can think of is the bed of the truck we are towing with. We have a 24-foot Trade Wind so there's not too much in the way of "spare" ( ) room.
Connie
Penguin is offline   Reply With Quote
Old 06-01-2004, 10:19 AM   #4
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Spare Tire
Greetings Connie!
Connie
I believe that the original mounting spot for the spare tire on your '66 may have been the same as that used on the '64 Overlanders (when the original owner ordered the spare wheel/tire and mount). On the '64 the original mount was on the "A"-frame hitch behind the LP tanks against the front wall. Since I changed to 40 pound LP tanks, it has limited space to the extent that I am not planning on trying to use that location on the Overlander. My Airstream dealer has advised that it would be possible to modify the current under-coach mount to the Vintage coaches - - it mounts under the coach behind the hitch in a recessed compartment (requires modifying the bellyskin to create and seal opening).
On my Minuet with its smaller 20 pound LP tanks, I am planning to have a local welder build a spare tire/wheel carrier to mount behind the LP tanks which was the factory location for the spare tire/wheel on the Minuet 6.0 Metre according to my information.
The only thing that I know that I would suggest avoiding is the temptation to use a rear bumper mount for the spare tire/wheel. This was a dealer added accessory on my Overlander shortly after its purchase by the original owners. It was a big contributor to a rear separation issue that was an expensive repair a few years ago.
Good luck with finding a good spot for your spare tire/wheel!
Kevin
Kevin D. Allen
AIR #827
Old 06-01-2004, 10:28 AM   #5
Penguin's Avatar
Tongue is OK?
I knew the rear bumper is prohibited, seen that on the posts. So I will examine the tongue closely and see if it can ride there. Currently we don't even have a spare, but it doesn't matter because we aren't going anywhere til we get our axles. But after that happens and we are road-worthy, we are going to be very interested in a spare. I guess I thought the tongue was also prohibited. Good news for me! I didn't want it wrapped up in a tarp in the living room!
Connie
Old 06-01-2004, 11:47 AM   #6
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
this is how they did it in the '70's. this pic is looking aft at the underside of the trailer from the front streetside corner. just outside the pic to the left, there is a handle that bends upward, and connects to a bracket on the underside of the a-frame. you can see the skin has been removed from this section to create a cavity in which a tire can fit.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 06-01-2004, 01:40 PM   #7
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
tongue mounted spare
Here's the mount on my Caravel. Very simple and convenient.
Of course not all trailers can accomodate this type of mount.
Name:	tire mount.jpg
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 06-01-2004, 01:41 PM   #8
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Spare
The tire on the Caravel just rides in the U-shape there behind the tanks?
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-01-2004, 02:32 PM   #9
Rog0525's Avatar
Images: 11
Yep. I use a vinyl coated cable and padlock to secure the tanks and tire to the tongue.
Rog
Old 06-01-2004, 04:46 PM   #10
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Mine is similar to what Chuck has... I agree it would be easier wher Roger's is located...but I'd have to give up my dual battery box!
spare tire? Chas Tires 14 07-04-2005 08:09 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 10:00 AM
Spare Tire? jdleezer Tires 21 07-10-2003 08:50 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 05:40 PM
