Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2005 Safari
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 04-28-2008, 01:42 PM
  #253
Minnie's Mate
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville, Georgia
Any body know if plumber's putty or silicone tape would work?
Family of Disney Fanatics
WBCCI# 4821
Old 04-29-2008, 05:44 PM
  #254
AZstreamin
AZstreamin's Avatar
Profile:  2005 30' Safari
Chandler, Arizona
most plumber's putty should not be used on plastic. the oil in the putty breaks down the plastic over time.
I had the same leak problems when I first purchased my BH. must have been a sleepy line worker.. the nylon compression fitting ring was just stuffed in the pipe sideways and the pipes under the sink were screwed together loose.. it was an easy fix and haven't had a problem since...
AZstreamin
goin' where the weather suits my clothes....
Charter Member FCU
Old 04-29-2008, 07:01 PM
  #255
rluhr
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
1953 21' Flying Cloud
2005 30' Safari
Somewhere, Roaming America
Our experience has been like Rick's: once a small leak, and since being tightened it has never happened again. We've towed close to 60k miles at this point.
Krista, don't get paranoid about what the dealer said. Crumbs of food down the drain are not a problem. You can do your dishes without fear. Just don't dump large quantities of food down the drain like you might with a household "Insinkerator" disposal unit.
In any case, a little enzyme-type ("green" or "formaldehyde free") black tank chemical down the sinks once in a while is a good idea -- it helps digest any food particles that get into the gray tank.
WBCCI #9990 | VAC | Full-timer | AIRSTREAM LIFE magazine | Tour of America weblog
Get rid of these ads... register today, it's FREE
Old 04-30-2008, 07:45 AM
  #256
Minnie's Mate
Digest-it was recommended to us by a fellow camper. It is difficult to find, though. But I was told we should put it in the black tank and in the gray as well to break down grease.
Also, I was told that if you hook up to sewer and leave gray valve open, the grease will coat the bottom of the tank and create problems. Not sure about that piece of advise, though. Seems the grease would either coat the bottom or coat the sides a la bath tub ring. If you put the enzyme type treatment in there with a little gray water and travel with it for a while, the enzyme will get stirred around evenly, or at least will swim around to all parts of the tank submerged in the water and eat away at whatever is in there. I generally try to leave a few gallons in the gray tank for this purpose and to keep the seals from drying out.
WBCCI# 4821
Old 04-30-2008, 08:17 AM
  #257
rluhr
Commercial Vendor
rluhr's Avatar
2005 30' Safari
WARNING: Do not read while eating!
Our experience has supported that theory about problems resulting when the gray valve is left open. For two years we closed the gray valve and only used it for dumping. This left the pipe pretty clean after dumping.
Then we stopped for three months and lived in the Airstream with the gray valve mostly left open. A disgusting slime mat built up in the dump pipe and hose. (The slime mat is a layer of bacteria that is feeding on organic material.)
We have been using enzyme-based tank chemicals to encourage the breakdown of this mat, and have resumed our practice of closing the gray valve except to dump, but progress has been slow. After a month of use, the pipe is just now coming clean again.
There's no question in my mind that prevention is far better than cure in this case. I agree with the advice to leave the gray valve closed rather than letting it run for long periods of time, and to keep some chemical/water mix in the tanks to help organic material break down inside them when the trailer is stored.
Old 04-30-2008, 10:09 AM
  #258
Minnie's Mate
Originally Posted by FORTSTANLEY
Hey Minnies Mate-
Got some Georgia questions for you, if you don't mind. Or anyone else whose been down this way. We are heading to Orlando shortly from Charleston, and there are a couple of places about 1/2 way- Jekyll Island or St. Marys. Both sound very interesting and wondered if you had any personal experience at either place. Thanks!
Krista
Jekyll Island is a beautiful and quaint little island full of rich, and I do mean rich, history. It is one of Georgia's five Golden Isles.
The island was purchased in the late 19th century as a private retreat for America's wealthiest upper crust to escape the New England winters. While most of the members of the exclusive Jekyll Island Club stayed in the main lodge during their stay, several members built beautiful "cottages" on the mainland side of the island in what is called "millionaire's village". Such cottage owners were the Macy's, the original owners of the dept. stores, the Van der Bilts, the Astors, the Pullitzers, the Firestones, and the Cranes (of Crane bathroom fixtures), and others. These Victorian jewels are open to the public for a small tour fee for self-guided tours. The main lodge is now a luxury hotel in the Westin chain, I believe.
Most of the cottages (mansions by today's standards) have been fully restored. One of the most spectacular restorations is the chapel with its dark stained Victorian/Gothic revival interior and stunning stained glass window. Try to visit it in the morning as the window deliberately faces east and is simply gorgeous with the sunlight streaming through. The very first transatlantic telephone call was made from Jekyll Island in the early 1900's.
The state recently completed a wonderful suspension bridge to Jekyll Island that is work of art in itself. The design has one awards and has been featured in many commercials and movies because of its design.
The island was purchased by the State of Georgia shortly after WWII. There were German U-boat sightings and more than one ship torpedoed off the shore of the island during the War and the members no longer felt safe so participation dwindled so the club closed and sold the island to the State with certain provisos. While there are a number of homes on the island, none are built on private property; they are all built on leased land. There are only a few lodging options and one campground as I recall on the island but a number of restaurants and two or three golf courses. Because of the State's tight building regulations (at least until now) nearly all of the beaches are pristine and undeveloped. They are as they always have been. Unfortunately, the State is planning to open the entire island up for redevelopment that will end its current state of natural appeal.
I am less familiar with St. Mary's. I know that St. Mary's is experiencing quite a renaissance recently with wonderful salt-marsh developments and new golf courses and is becoming not only a tourist destination for the golf and access to both the inter-coastal waterway and direct access to the Atlantic, but as a vacation home resort as well. There is a Naval Base with one of America's main submarine bases on-site and there are lots of deep-sea fishing opportunities as well.
Of the two, I would highly recommend Jekyll Island for the history, natural beauty, and tranquility. The only caveat I can add is that there can be tons of mosquito's at certain times of the year (other times not) and 30 years ago, the shrimp boats often came too close to shore and would stir up the bottom of the ocean floor and cause the water to be murky on the windward side of the island. Not a place for snorkeling, but a nice beach for sun bathing.
WBCCI# 4821
vB code is On
Pingbacks are On
2003 Safari 25 Melvin P. Thorpe 2003 Safari 24 09-15-2007 10:53 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 07:07 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 11:34 AM
Motorhome club name 1985air345 Airstream Motorhome Forums 3 03-28-2002 07:50 AM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
