Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2005 Safari
Old 12-11-2008, 06:39 PM   #379
SafariSS's Avatar
Profile:  2005 30' Safari
Houston Texas , Texas
...the shaft..
Well Tom, not to be pessimistic, but I suspect we get the shaft!
Look forward to meeting you guys at the CanOpener (I am in 121),how many bunkhouses, just two?
SafariSS is offline   Reply With Quote
Old 12-11-2008, 07:15 PM   #380
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Yeah, I would not hold my breath for a warranty replacement either.
Wish I could make it three bunkhouses at the Can Opener but this year we'll be on the opposite side of the country.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
rluhr is offline   Reply With Quote
Old 12-11-2008, 11:03 PM   #381
Commercial Vendor
Profile:  Corona , California
Originally Posted by Minnie's Mate View Post
What does that mean for the rest of us? Do we get warranty replacements? Extended warranties on the original axles at no cost? Obviously, it was an error in design if the axle should have been the 5,500 LBS. axle.
I don't believe Airstream's posture would be anything but "you overloaded your trailer."
That being the case, a warranty issue would not come into play.
All we can do is to identify the problem, and come up with a fix.
The problem has been clearly identified.
Next step is the fix.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-12-2008, 09:18 AM   #382
Commercial Vendor
rluhr's Avatar
2005 30' Safari
Let's not panic. As Andy notes:
Originally Posted by Inland RV Center, In View Post
...bunk house owners may have a forth coming axle problem, depending on use and loading.
(Emphasis mine.)
Given that we kept our Airstream fully loaded for three years, lived in it full-time, and towed it over 60,000 miles, it's not surprising my trailer shows more wear and tear than the average.
So far, I've only seen one other bunkhouse that showed an axle angle that suggested a possible issue. The others appear to be within specs. So most of you probably don't have anything to worry about. And if you do have a problem, a fix is readily available.
Old 12-12-2008, 09:28 AM   #383
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Anybody have a real world weight on these trailers?
Marc
Old 12-12-2008, 10:22 AM   #384
Commercial Vendor
rluhr's Avatar
2005 30' Safari
We've weighed ours at CAT scales several times. In 2005 we recorded a weight of 7,040 lbs on the axles. (Tongue weight was additional but doesn't show up directly on the weight receipt, because tongue weight sits on the truck.) In 2006 we recorded a weight of 7,320 on the axles, and that's probably the heaviest we've ever been. We always weighed with full water in the fresh tank and full propane. We have never towed overweight, so I assume it was the heavy use that stressed our axles.
Old 12-17-2008, 03:18 PM   #385
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I'll post my axle weights when I get home. I weighed mine a few months ago and was below the max that Airstream had posted on their website for our trailer and are in the '05 book. Unfortunately, my brief case got stolen with my '06 brochure in it, but I doubt there is any difference in the limits.
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Old 03-14-2009, 04:57 PM   #386
Heavily Armed
Austin , Texas and Colorado...ish
Bunkhouse questions
I may well be posting this incorrectly, if so my apologies. In any case, I recently purchased my own 2005 bunkhouse. I know diddly about rv's, and would like to ask anyone and everyone what modifications they would suggest I make now, before things go badly wrong. Bigger axles? Bigger hot water heater (I have a wife who likes her hot water)? Twin turret roof mounted belt fed machine guns? If anyone's been itching to share their insights with a grateful new owner, now's the time.
Mirthless is offline   Reply With Quote
Old 03-14-2009, 05:05 PM   #387
Commercial Vendor
If you will travel with consideable weight, you can upgrade to a higher axle rating, if you so choose.
Many things can be added, depending on your wishes, within reason.
Andy Rogozinski
Inland RV Center
Corona, CA
Last edited by jcanavera; 04-05-2009 at 04:13 PM. Reason: removed link to inland site
Old 03-15-2009, 03:24 PM   #388
Andy has addressed the axle issue for you. The twin turret roof mounted belt fed machine guns really sound cool, but might get in the way of some low hanging tree branches.
As far as larger hot water heaters, sorry, but you are stuck with the six gallon size unless you do major remodeling. There just isn't room for a larger unit.
If you read through this thread you will find some of the ideas folks have put into their 30' Safaris. There is also a thread, sorry can't remember the name, about a multitude of improvements that have been made to a Classic model. We have found our 30' Safari to be very serviceable just the way it came from the factory. The only changes we have made is the bed spreads. We didn't like the ones that came with ours and they were too heavy so my wife found some that matched (twins and a queen) and altered them herself to match the curves of the mattresses.
WBCCI# 4821
Old 03-15-2009, 03:40 PM   #389
Amsterdamer's Avatar
Caledonia , Michigan
We love our 30’ BH. “The only three bedroom Airstream”
Here are a few tips specific to your new AS. The forums are a great resource for advice that will apply to all models.
I think you'll find the water heater to be adequate, but you might want to carry a couple (A93866) thermal cutoffs incase you need a new one. When they go bad, the heater won’t work anymore.
It’s important to have this camper leveled correctly, to insure that your shower drains, since the drain plumbing wraps all the way around the back.
Your front storage compartment door will get dinged up if you let it hit your torsion bar clamps.
Make sure to secure the bedroom door before you hit the road or it will come off its track.
Don’t open the window over your couch/chairs (depends on model). The entry door will hit an open window.
Watch out for your holding tank drain. It’s way out back and kind of low. A few owners have broken it when exiting steep driveways, or going on rough roads.
You have a big awning. Make sure to drop the back down a bit to encourage water runoff and avoid breaking a support rod.
If your fantastic fan vents close when they sense moisture, they will open again when it’s dry, so be sure to turn them off when they are closed.
Read Rich Luhr’s blog at AirstreamLife.com. He and his family went full timing in a 30’ BH just like yours and encountered and overcame many challenges.
Amsterdamer is offline   Reply With Quote
Old 03-15-2009, 03:47 PM   #390
Oh yeah, one more thing, welcome to the club.
WBCCI# 4821
Old 03-15-2009, 03:55 PM   #391
Commercial Vendor
Please read poast # 377 above.
We suspect far more owners will share the same problems as Rich Luhr has with the axles on that model.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-16-2009, 11:49 AM   #392
Roamin' Cat's Avatar
Profile:  2008 25' Safari
Quiet Green , Connecticut
Rivet Congrats!
... I recently purchased my own 2005 bunkhouse.
Hi Mirthless,
Congrats on the "new" bunkhouse! So psyched for you and your family
I was down at Colonial Airstream recently, dropping my 25'FB off for service, and hoped to take a look at one on their lot, but it had just sold. I'm guessing that might have been you?
One of these days I'll get to see the inside of one! I'm sure the pics don't do it justice
Enjoy!!!!
Cats
The New England Unit
"I paint to make myself happy. Color delights my spirit. I search for it everywhere, and surround my life with it always."
http://beverlyamitchell.com/home.htm
One of Beverly's gorgeous paintings is my avatar :-)
Roamin' Cat is offline   Reply With Quote
Motorhome club name 1985air345 Airstream Motorhome Forums 9 06-09-2009 08:18 PM
2003 Safari 25 Melvin P. Thorpe 2003 Safari 24 09-15-2007 11:53 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 08:07 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
