Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Safari > 2005 Safari
Old 11-09-2008, 08:21 AM   #365
serial airstreamist
wheel interested's Avatar
Profile:  2005 28' Classic
Lapeer , Michigan
Images: 117
How often do new Airstreams need their axles replaced? Now that you have new axles Rich (and howdy Terry!) will you and the gang at Inland Andy be able to determine why they failed?
CJ
The future belongs to those who believe in the beauty of their dreams.-Eleanor Roosevelt
It is never too late to be who you might have been.-George Eliot
wheel interested is offline   Reply With Quote
Old 11-09-2008, 05:16 PM   #366
Amsterdamer's Avatar
Profile:  2005 30' Safari
Caledonia , Michigan
It looks like our height to the wheel well is between 25" and 25 1/2". It's difficult to tell, since I have it parked on dirt/grass and it is not level. I took some pictures and it looks very similar to the others that have been posted: An appearance of slightly beyond optimal angle under load.
On the Inland RV site, Andy has a nice diagram indicating starting and normal load of a Henshen axel.
Making Henschen Axles Tour
Notice that there is a taper from the axel mount to the wheel mount, so the pictures actually show that the load that the wheel is placing on the axel is within the normal load range.
The center of the wheel hub is still near the bottom of the axel.
Yes, there is a little snow falling.
ID:	71139   Click image for larger version
Amsterdamer is offline   Reply With Quote
Old 11-10-2008, 11:27 AM   #367
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
I'm with Carol, how soon should the axles need replacing?
Inquiring minds want to know!
Anyway, it seems that there are tons of vintage Airstreams that have their original axles (most need them replaced long ago) but some have made it for 25-30 years or more with the originals. I know InlandAndy once said that he has seen others that needed replacing within a short time after manufacture. It seems that something was going on with Rich's...maybe from a bad batch or could it be that the earlier models had a lighter duty axle than the later models? He stated that the frame for the 30' Safari was the same as for the 30' Classic, did they not use the same axles as the 30' Classics? Should they have used the same? Did they use the 30' Classic axles on later 30' Safaris. Just pondering out loud here. It seems that one axle being flawed from the factory on his trailer is understandable, but both axles on the same trailer being flawed? Unless there was a whole bunch of axles that were flawed at the same point in time...maybe bad batch of rubber rods?
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Old 11-10-2008, 12:18 PM   #368
Commercial Vendor
Profile:  Corona , California
Rich Luhr's original axles.
One end of one of the axles is being shipped to Henschen today. Sending a complete axle is not necessary.
It will be pulled apart and examined in their laboratory, hopefully answering, "why did it fail" question.
We will learn the results of those tests, at a later date, which could take about 4 weeks or more.
Once we have the data, we will post it accordingly.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 11-10-2008, 12:31 PM   #369
Thanks Andy. Looking forward to reading the results here.
WBCCI# 4821
Old 11-11-2008, 09:10 AM   #370
SafariSS's Avatar
Houston Texas , Texas
Manufacturer...?
Andy, what brand of axles did you guys put under Richs Bunkhouse?
SafariSS is offline   Reply With Quote
Old 11-11-2008, 09:40 AM   #371
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Rich requested, and got, Henschens. 5,000 pound capacity, up slightly from his OEM 4400's. He has detailed his experiences with the new axles compared to the old ones in his blog.
(No Longer at Inland RV)
Old 11-11-2008, 11:54 AM   #372
Commercial Vendor
rluhr's Avatar
Profile:  1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I've heard from four other Bunkhouse owners at this point. Only one (RossFam05BH) has provided a picture that indicates torsion arms outside the "normal" range as depicted on Inland's website. The rest seem to be within normal operating range as far as I can tell from the photos.
So in my opinion we can't yet conclude that there was a bad batch of axles. But as to the cause of this, and whether my axles should have lasted longer, I can't say.
I can say that I already like the 5000# axle upgrade, because of the slightly higher clearance (3/4" at the wheels in our case), and the increased shock-absorption I'm seeing in my sideview mirror during turns. I may eventually go to Load Range E tires as well, just because I've had several belt failures in tires over the past year (with all brands of tires!)
As always, "your mileage may vary." Remember, we averaged 20,000+ miles per year. With that kind of heavy use, my tendency is to over-maintain the trailer rather than wait for things to break. Those original axles probably had many miles left in them, but for our situation I felt it was time to go for the upgrade.
WBCCI #9990 | Former full-timer | AIRSTREAM LIFE magazine | Tour of America | Man In The Maze
rluhr is offline   Reply With Quote
Old 11-30-2008, 10:17 PM   #373
SafariSS's Avatar
Bunkhouse bummer..
We managed to take a week for the Thanksgiving week to travel this year. We decided to travel the Natchez Trace and take it easy, hiking and dry camping along the way. We did have two nights of rain and on the way home I had to tow through rain about three hours worth however. In the back of my mind I am always thinking about leaks, you always read about people with leaks and rotten floors you kinda expect it if a leak is let go. So....I always find myself looking under cabinets, inside plumbing chases, feeling around windows to the point my kids think something is wrong with me! Well, this time I found a leak. Most bunkhouse owners have dealt with or will deal with the front storage box access door issue, I dealt with mine under warranty and chose to replace the front panel with a solid piece to eliminate a leak point and I was planning on putting two more drycells in there anyway.
After my tow in the rain, I notice a damp pillow on the front bedroom bed. I once dealt with this issue and it turned out to be the polyurethane at the base of the black frame window was not there. This time I think it was being force into the drain hole at the bottom of the Hehr window as I could see the spray from the hole on the window screen. I started to poke around and decided to pull the bedpanel up and look at the floor. Bummer, I felt damp carpet, so I proceeded to pull back the carpet to look at the sub-floor and yest it was wet. Then I removed the pop-riveted panel from the previous access panel to see what it looked like from the inside...
I found damp insulation at the bottom as well as the top. The top would be attributed to the window, but the bottom upon further inspection could have been leaking from the bottom. It appears the bottom channel that the bolts go thru the trailers frame have been leaking from either under or above the exterior beltline. This beltline was replaced when my previous repair was made and the Acrly-r was new. I have included another pic that shows the sealant with a "crack" in it, I find it amazing that if that layer of sealant is all that keeps the water from finding its way in? Furthermore, I wonder why this area seems to get so much flex. My original access door cracked on either side in less than 7k miles of towing, which also would be a sign of movement. I wonder what a non front storage aluminum frame has up there, do they flex? I do tow with a 3/4 ton but the ride is very nice, not harsh. Comments??
Old 12-01-2008, 04:05 PM   #374
Comments??
Bummer. Could it be leaking where the old hinge was at the lower location? I can't tell but it looks like it may be there in the exterior photo. It is probably glare, though.
WBCCI# 4821
Old 12-11-2008, 10:03 AM   #375
Antique Pedaler's Avatar
Profile:
Did you ever get a response? We have a Bunkhouse in family.
Antique Pedaler
'10 Flying Cloud FB
'05 GMC Pickup
X '99 27, X '05 19, X '07 23
Santana, and Ventana Tandem bicycles
Hobie tandem Kayak
Antique Pedaler is offline   Reply With Quote
Old 12-11-2008, 11:04 AM   #376
Commercial Vendor
Henschen has received one end of Rich Luhr's axle.
As of today, no report yet.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-11-2008, 04:22 PM   #377
Commercial Vendor
Bunk house axles.
We replaced Rich Luhr's axles, since his originals, played out.
The original weight rating was 4400 pounds each, as specified by Airstream.
In Rich's case, the torsion arm angle went beyond zero degrees.
We replace Rich's axles with 5000 pounds. That corrected the poblem and raised his trailer as he previously reported.
We cut the old axle in half and sent that half to Henschen for lab tests.
We now have the lab tests.
Since the axle had a zero weight load for about one month, the starting angle returned to near normal.
The durometer tests showed the rubber rods to be within specs.
The overall answer, was no defects, of any kind.
Conclusion: It's now obvious that the original axle rating, as chosen by Airstream, namely 4400 pounds, was inadequate.
The 1200 pound increase on Rich's trailer showed a considerable improvement, even with a starting angle of 22 1/2 degrees.
We will get together with Henschen next week, and see if we can have a special "axle" for the bunk house owners.
We will look into 5500 pound axles, with a 35 degree starting angle.
We will post the results of our inquiry in a few days.
It appears then, that all the bunk house owners may have a forth coming axle problem, depending on use and loading.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-11-2008, 06:00 PM   #378
What does that mean for the rest of us? Do we get warranty replacements? Extended warranties on the original axles at no cost? Obviously, it was an error in design if the axle should have been the 5,500 LBS. axle.
WBCCI# 4821
Motorhome club name 1985air345 Airstream Motorhome Forums 9 06-09-2009 08:18 PM
2003 Safari 25 Melvin P. Thorpe 2003 Safari 24 09-15-2007 11:53 AM
Safari owners Jerry Sulkin 1969 - 1973 Safari 30 02-20-2006 08:07 PM
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 12:10 PM
Where do you suppose they put the antenna jack -73 safari ? Chuck 1969 - 1973 Safari 14 06-13-2002 12:34 PM
