Old 06-15-2004, 09:25 AM   #1
DEO
DEO's Avatar
West of Boston , Massachusetts
First (very short) trip in new unit
Took the new trailer out last weekend to do an initial shake out and see if all the systems worked when hooked up. I know some people were interested in hearing about any quality issues encountered on a 2005 so here is my report so far. For the most part as I said to my wife "this trailer tows like a dream compared to the Bambi". It really was smooth. Maybe it was because I did a better job installing the anti-sway hitch this time. It sure took less time than the first time (two hours instead of about 8) experience is a wonderful thing. The only "defects" we have to report thus far is that we noticed that underside one of the panels is loose and some insulation is hanging out. I intend to get under there today and figure out how to secure it. The only other little thing is that one of the speakers is buzzing and will have to be replaced. One other thing and maybe it is an adjustment or something is that the hot water heater doesn't sound smooth... almost like the fire in there is flickering a bit.. Is there a way to adjust this? It worked fine but just sounds a bit off. All in all a very sucessful trip and I am very satisfied with the new unit. My biggest problem is finding time to get out but I am working on that.
DEO is offline   Reply With Quote
Old 06-15-2004, 09:41 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
The water heater can be adjusted. There is a shutter that you can move to change the amount of air mixed into the LP.
On the burner tube that comes off the gas valve look for the slotted round fitting. There should be a screw. Loosen the screw while the heater is running and slide the shutter in or out. You will hear the noise the burner makes change. The flame should be mostly blue with a small orange tip. If you run it too quiet it will soot.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 06-15-2004, 10:10 AM   #3
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
was it windy in your campground? I've noticed that my water heater makes that kind of noise if it's on the leeward side of MH or in a strong crosswind.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Longest Trip in a Classic AIRSTREAM Motorhome winner Airstream Motorhome Forums 17 01-26-2005 09:11 PM
15k BTU A/C unit info Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-21-2003 03:17 PM
A/C unit size input.... Silvertwinkie Our Community 4 09-04-2003 07:05 AM
Removing the Armstrong AC unit FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 11 08-02-2002 12:10 PM
Took Globetrotter on first real trip Jim Clark On The Road... 4 07-01-2002 10:41 PM
