Old 12-03-2009, 11:36 AM   #1
carson city , Nevada
Question creak/squeak in floor
I am looking to purchase a 2005 Safari 28 with the slide out. It is in good shape overall but I recall from research on these fourms that some came with a quirk/creak in the floor. This is near the rear of the hallway under and just forward of the privacy curtain. It is covered with wood or vinyl and not carpet so I am reluctant to get under the covering on something I don't own. Is this creak normal for Airstream floors or should I be concerned with dry rot underneath. Any ideas or suggestions will be appreciated. Thanks.
jmtandem is offline   Reply With Quote
Old 12-03-2009, 11:44 AM   #2
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I have that same squeak in my 28 SO too. It's been there since day 1 when I purchased it new. 3 and a half years later it hasn't gotten any better or worse so I've just lived with it.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 12-03-2009, 02:09 PM   #3
_
common issue, not confined to slide models...
scan any of the Q threads and this issue is a recurrent annoyance mentioned across the models (except 16s)
http://www.airforums.com/forums/f44/...oor-48941.html
but this issue is buried in LOTS of threads and subfloors.
cheers
2air'
Old 12-03-2009, 05:38 PM   #4
thanks, I guess it is just one of the Airstream quirks. I am still learning coming from three cabover campers and one 30 foot travel trailer.
Old 12-03-2009, 06:33 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
I opted for no carpet and all-linoleum floor when I ordered my 2006 Safari. It takes some observation but I know where the seam between plywood sheets is located. Yes, there is a bit of creak at odd times. I agree that it stays stable and I'm not inconvenienced. A creaky day airstreaming beats a medium day AirForums'ing...
5 meter Langford Nahanni
Old 12-03-2009, 09:38 PM   #6
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Creaks and squeaky doors......I leave 'em be. Tells me when someones a sneaking up on me.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 12-03-2009, 10:13 PM   #7
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Hi jmtandom,
My 2000 Safari has the squeek also, just forward of the bathroom/privacy curtain.
Welcome to the forums!
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-11-2018, 05:14 AM   #8
JRM
2004 25' Safari
Hernando , Florida
I had the same problem there was a couple of screws on the inside behind the furnace cover
that needed to be tightened down on the floor took care of the problem
JRM is offline   Reply With Quote
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 21 11-09-2020 03:47 AM
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
Trying to decide on floor insulation or none at all perryg114 Repairing/Replacing Floor &/or Frame 1 09-20-2011 01:52 PM
No Factory Floor Covering Intrepid Repairing/Replacing Floor &/or Frame 2 09-20-2011 07:48 AM
Mismatch of floor and outrigger width MtnMDStan Repairing/Replacing Floor &/or Frame 3 06-19-2011 02:44 PM
