Old 07-20-2011, 03:09 PM   #29
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
Bash 3.0 is on the calendar. We had fun at Bash I and II. I'm sure that Bash III will be no exception. Are we getting the big field on the other side of the lake? If I recall, there were not many trees over there. Could be a hot one.
http://e-rock53.blogspot.com/
TAC#: OH-13
erock53 is offline   Reply With Quote
Old 07-20-2011, 03:46 PM   #30
Baltimore , Maryland
Eric, we will have fully shaded sites in the area called The Island. Most of the rest is partial shade/sun. There are some, that actually prefer full sun. Just look at this a new venue. You will just have to trust your Hosts to provide you a third killer time and venue.
I was working on one of the musical entertainments just today. Hope we can nail this act down. I am also hoping we can get Dancin Hansen and his band to play for us.
Will you be bringing along a rocket built over the winter months?
Old 07-20-2011, 04:12 PM   #31
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
put us on the list
we plan to be in that general area about that time next year on the way to maine and parts thereabout...sounds like fun
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 07-20-2011, 07:41 PM   #32
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
Frank,
The kids are already talking about building more rockets. They had a blast with the ones we made at this years Bash. You could not have asked for a better place to launch them. I'm sure that the clown that parked me this year will set me up with a great spot next year. I'm not worried about it. I have been wanting to put some solar on my roof, now I have a perfect excuse. Do you think I can sell it to the wife?
Eric
TAC#: OH-13
Old 07-20-2011, 07:52 PM   #33
airstreamhobo's Avatar
I have the above cpap machine. During Bash I, I had full batteries when I went to bed. With heater on in the AM the batteries were down to 1/2. I ran the generator for 2 hours each morning. This I did for 7 days and made it. I believe if your batteries are good shape, you should be able to make it without problems. We even shared generators during the Bash I.. Just my experience. Obie
AirstreamHobo
Lancaster Co. Pa.
1999 28' Excella
Ford Diesel Van "The Obie Van"
WBCCI #2590
TAC PA-2
http://airstreamhobo.blogspot.com/
airstreamhobo is offline   Reply With Quote
Old 07-20-2011, 07:55 PM   #34
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Obie, you must have an inverter... if you have a heater... the cpap will run on 12V but the heater is 110v only. By my calcs, the machine and humidifier would use 200AH for 8 hours of use. I would prefer that it would run longer than 8 hours. Not that I get that much sleep while at the Bash, but there is nothing worse than wakening because the air you breathe has been shut off.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 07-20-2011, 08:12 PM   #35
Steve, I do have an Inverter , a small converter I plug into 12volt outlet then plug the cpap 120 plug into it. and the heater is on all night. Obie
AirstreamHobo
Lancaster Co. Pa.
1999 28' Excella
WBCCI #2590
TAC PA-2
Old 07-21-2011, 05:51 AM   #36
1966 17' Caravel
Bethel Park near Pittsburgh , Pennsylvania
Send a message via Skype™ to aceflys
The Set Up
This is the Amanda setting up the group photo at The Bash II.
She is luking on the forum. Great Job for a 16 year old Airstreamer
(1) Click image for larger version
(2) Click image for larger version
(3) Click image for larger version
aceflys is offline   Reply With Quote
Old 07-21-2011, 06:37 AM   #37
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Based on Steve's numbers for current on the heater (2.5 amps at 120 volts)
I come up with the same results.
It would be interesting if some one would actually measure the current as I have found most name plates are much on the high side when they list
wattage. Probably to allow for start up load which motors and cold heating elements have
300 watts seems like a lot of power for the heater . That is what a refrigerator draws and look how hot they get boiling ammonia.
Any one got a Kill a watt meter and one of these devices that could get a real number?
This is all theory for me as I have never used one of these. In fact I don't think I have ever seen one which should qualify me as an engineer in this area.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-21-2011, 02:07 PM   #38
VinFan
vinfan's Avatar
1984 27' Airstream 270
First capital , Ohio
Amanda you did a great job at Bash I and now BashII.
We arrived to late for overhead Bash I photo and somehow we missed the group shot for Bash II ! Amanda 2, Margaret and Gang 0! We will try again at BASH III
We always have a great time.
vinfan is offline   Reply With Quote
Old 07-21-2011, 02:36 PM   #39
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Bash III Is On The Calendar
We've got Bash III on the 2012 calendar.
We used our generator to top off the batteries in the morning and give the lovely ladies enough 110V to blow dry and curl their lovely locks.
I was thiking about shutting down the generator while they were in the middle of their rituals...but I thought better of that idea!
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 07-21-2011, 03:17 PM   #40
pintoman's Avatar
2015 25' FB Flying Cloud
Greensburg , Pennsylvania
Count us in for Bash 3!
pintoman is offline   Reply With Quote
Old 07-21-2011, 03:18 PM   #41
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
I am hoping to make it for Bash III....
GREENovaters is offline   Reply With Quote
Old 07-23-2011, 04:07 AM   #42
1967 28' Ambassador
1970 29' Ambassador
Rick... you are right. I reality, for many folks, the draw would not reach the max. For the cpap, the power usage is dependent on the pressure requirements of the individual. Most machines can be set for pressures between 4-20 cm H2O... so the range is 5 fold. The heater would be dependent on the ambient temps... so in the summer, it would likely not fire up as much if you are starting with room temp water.
I hope this info helps any folks that have a concern.
Steve & the crew
Formula One (F-1) Austin, Texas 2012 ZoominC6 On The Road... 22 10-03-2014 12:12 PM
Went to buy 2011 27FB, ended up with 2012! 18driver 2011 - 2015 International 71 06-21-2013 03:22 AM
2012 Airstream current available models and Floor Plans Colonial Airstream Commercial Listings 11 10-08-2011 08:24 AM
TAC : GA-TAC 2012 Stone Mt. Park Rally Poll Silverexpress Other Rallies & Events 36 08-08-2011 03:24 PM
Ultimate 4th of July Stay-Cation mimiandrews Airstream Lifestyle 3 07-04-2011 09:16 PM
