Old 07-12-2011, 07:22 PM   #15
WineStream's Avatar
2005 30' Safari
Pleasanton , California
Images: 24
Self-containment
Hi Frank and Bash planners for 2012:
This is the conservationist / environmentalist side of me speaking.
Taking power from "the grid" is far more efficient and less "carbon footprint" than running generators. I am assuming that after attending this year's Bash (2011) that we will be on the other side of the lake next year since you are talking of no elec.??? If there is any way to hook up those in need (medical) at night and pass around the "3-amp" connection via extension cord during the day to recharge everyone else, I would greatly suggest this. I will volunteer to be the electric czar if one is required. Less noise and less emissions...in my mind, always a better choice.
WineStream is offline   Reply With Quote
Old 07-12-2011, 07:39 PM   #16
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Frank,
What state is Coopers Lake located?
Michelle TAC MT-0
Sarah, Snowball
Old 07-13-2011, 02:59 AM   #17
Baltimore , Maryland
Jason, we are turning lemons into margaritas here....
I understand your concern. The first Bash had no hook ups and we did just fine. Most people that needed all night electric got together and shared the ultra quite type generators. It worked just fine. We plan to do the same with this one. The improvement we will make is to construct a room to muffle the noise. I imagine the ambient noise from I79 will be greater.
There is just no grid power. We are in negotiations already with a generator dealer to come out and show all of us how well their product works. Even if that does not pan out, we will make due.
We are Airstreamers and Airstreamers make it happen.
If someone wants to come that just cannot be liberated with boondocking, there will, as this past year, be full three point hook ups just up the hill.
Old 07-13-2011, 03:15 AM   #18
Originally Posted by thecatsandi View Post
Frank,
Cooper Lake is just North of Pittsburgh PA.
The photo in their banner is a view of where we will be. Just picture beautiful shiny silver bullets in that photo and you have it.
Everyone will have an awesome campsite I promise. We have full sun, part sun, total shade. We have water front, lake view, meadow, and timbered sites.
Old 07-13-2011, 04:57 AM   #19
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
No electric- No problem. Rarely camp anywhere with electric
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-13-2011, 09:02 AM   #20
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
Bash electic and Medical needs
I am assuming ( possibly incorrectly) most power required for “medical needs” would be to run a CPAP machine.
The link below will provide some info on the power required. It appears that many of the modern machines have 12 volt capability.
How to Camp with your CPAP on Battery Power
I recently had a friend with a 120 volt machine actually measure the current draw using a “Kill a watt” meter. The results were 28 watts on startup and a running load of 13 watts.
Allowing for inverter inefficiencies this would translate to about 1.25 amps at 12 volts or about 10 amp hours for an 8 hour night. Slightly less than running an 1141 auto bulb for the same time period. This is a relatively light load.
This means that you should be able to run a CPAP for multiple nights on a trailer battery, depending on what else you are using. Certainly there should be no need to run a generator at night if the CPAP is the only concern.
Charging can be done during the day. Of course there may be other needs that would require more power
I hope this info is helpful to some concerned about power availability at the Bash and has not strayed too far off topic
13 Ram 2500 TD
Old 07-13-2011, 11:03 AM   #21
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Added to the Master Calendar
Hope to be there for III.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-13-2011, 11:45 AM   #22
oleschool's Avatar
1973 31' Sovereign
chapin , South Carolina
Electric at this years Bash was a pleasant surprise, all we used it for was to run a fan to help cover some noise in the mornings...but only a jet engine could cover up Obie and his Mega phone...
watching the stars through the vista view windows= priceless
TAC# SC-2
AIR# 41283
oleschool is offline   Reply With Quote
Old 07-19-2011, 09:07 PM   #23
Whirlism's Avatar
2013 25' Flying Cloud
Hermitage , Pennsylvania
Nora and I really enjoyed the Bash II and the people we got to meet and to know, so....... we broke down and bought an Airstream! Next year's Bash III dates are already marked off on our calendar!
Whirlism is offline   Reply With Quote
Old 07-19-2011, 09:49 PM   #24
airstreamhobo's Avatar
WFW...Welcome Aboard!! Glad we showed you how we have FUN!! There are plenty of campouts to come!! Obie
AirstreamHobo
Lancaster Co. Pa.
1999 28' Excella
Ford Diesel Van "The Obie Van"
WBCCI #2590
TAC PA-2
http://airstreamhobo.blogspot.com/
airstreamhobo is offline   Reply With Quote
Old 07-19-2011, 09:58 PM   #25
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Rick, you are correct for a bare cpap, but many folks use a heated humidifier attached to their cpap. These use an electric resistance heater which draws way to much for a normal RV battery to handle.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 07-20-2011, 05:04 AM   #26
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I was not aware of that. Is it part of some CPAP machines or a seperate unit? Any idea of the current draw on 120 volts?
13 Ram 2500 TD
Old 07-20-2011, 07:17 AM   #27
1966 17' Caravel
Bethel Park near Pittsburgh , Pennsylvania
Send a message via Skype™ to aceflys
Welcome Back
Hey Bill and Nora
Welcome back to airstreaming. I know you have owned a AS in the past. So us at the bash can't take all the credit. I'm sure glad to take some. If you want to show off that new Flying Cloud in the fall. We will camping at Penn Wood AS campground. They have a "Fall Colors Rally" in Oct. I know that many of your new friends are going to be there. Hope you can make it.
Ace in PA
aceflys is offline   Reply With Quote
Old 07-20-2011, 12:34 PM   #28
1967 28' Ambassador
1970 29' Ambassador
Looks like most range from 1.8-2.5 amps at 120V
Steve & the crew
Formula One (F-1) Austin, Texas 2012 ZoominC6 On The Road... 22 10-03-2014 12:12 PM
Went to buy 2011 27FB, ended up with 2012! 18driver 2011 - 2015 International 71 06-21-2013 03:22 AM
2012 Airstream current available models and Floor Plans Colonial Airstream Commercial Listings 11 10-08-2011 08:24 AM
TAC : GA-TAC 2012 Stone Mt. Park Rally Poll Silverexpress Other Rallies & Events 36 08-08-2011 03:24 PM
Ultimate 4th of July Stay-Cation mimiandrews Airstream Lifestyle 3 07-04-2011 09:16 PM
