Old 03-13-2007, 12:59 PM   #155
Certifiable
mistral blue's Avatar
Originally Posted by balrgn
Are we still doing a Beef Stew Dump Friday and Pot Luck Saturday... Or have the rules changed?
Rules?!? You guys have rules? You don't need no stinkin rules!
mistral blue is offline   Reply With Quote
Old 03-14-2007, 01:06 PM   #156
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Weathah
Now this is getting rediculious!
Forcast is getting worse by the day....
Playing it by ear. Not looking to drive north in winter conditions....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 03-14-2007, 01:50 PM   #157
rgesch's Avatar
1956 26' Cruiser/Overlander
1967 17' Caravel
Newport , New Hampshire
Images: 18
I'm goin' if I hafta crawl! I'm goin' if I hafta leave tonight!
KB1UFH
KB1UFI
"Reality Is The Leading Cause Of Stress"
"There are only five great men in the world and three of them are hamburgers."
rgesch is offline   Reply With Quote
Old 03-14-2007, 01:55 PM   #158
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Same here!!!!!!!!! Leaving around noon Friday...maybe sooner
balrgn....love your websight!!! it's got all the info goin' on!
plus now I'm addicted to ZUMA!!!
NH Weather Data
Ann & Eric
WBCCI 6274
TAC CT-4
NEU
enduroryda is offline   Reply With Quote
Old 03-14-2007, 02:01 PM   #159
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Saturday, Freedom, NH
Saturday night, freedom, NH
30% Friday for snow showers and/or flurries! The hills should be slick for tubing! Have fun. The way things are going Chilli Man will have snow!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-14-2007, 02:09 PM   #160
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Ahhhhhhhhgggggggggg
http://www.intellicast.com/IcastPage...p&prodnav=none
www.balrgn.com
Old 03-14-2007, 02:15 PM   #161
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
NH Weather Data
Thanks. I like having my own domain, too many hobbies
Isn't Zuma KOOL!
www.balrgn.com
Old 03-14-2007, 03:05 PM   #162
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Only NONE left
We'll be going takng the last remaining cabin!
Woooooooooo Hoooooooooooo
www.balrgn.com
Old 03-15-2007, 02:27 PM   #163
rgesch's Avatar
1967 17' Caravel
Images: 18
Thank Goodness can't be without the Antigravity Salad don't care what color it is. We need bread for stew. Kathi won't be coming so no homemade biscuts. Should I pick up French Bread? Where is the nearest Panera?
RG
KB1UFH
KB1UFI
Old 03-15-2007, 02:40 PM   #164
2005 22' Safari
1960 24' Tradewind
French Bread
"A crisp, crunchy crust and slightly chewy center make this bread as traditional as the breads served in France."
Original recipe yield:
2 large loaves
PREP TIME 25 MinCOOK TIME 40 MinREADY IN 2 Hrs 40 Min6 cups all-purpose flour
  • 2 1/2 (.25 ounce) packages active dry yeast
  • 1 1/2 teaspoons salt
  • 2 cups warm water (110 degrees F/45 degrees C)
  • 1 tablespoon cornmeal
  • 1 egg white
  • 1 tablespoon water
DIRECTIONS
  1. In a large bowl, combine 2 cups flour, yeast and salt. Stir in 2 cups warm water, and beat until well blended using a stand mixer with a dough hook attachment. Using a wooden spoon, stir in as much of the remaining flour as you can.
  2. On a lightly floured surface, knead in enough flour to make a stiff dough that is smooth and elastic. Knead for about 8 to 10 minutes total. Shape into a ball. Place dough in a greased bowl, and turn once. Cover, and let rise in a warm place until doubled.
  3. Punch dough down, and divide in half. Turn out onto a lightly floured surface. Cover, and let rest for 10 minutes. Roll each half into large rectangle. Roll up, starting from a long side. Moisten edge with water and seal. Taper ends.
  4. Grease a large baking sheet. Sprinkle with cornmeal. Place loaves, seam side down, on the prepared baking sheet. Lightly beat the egg white with 1 tablespoon of water, and brush on. Cover with a damp cloth. Let rise until nearly doubled, 35 to 40 minutes.
  5. With a very sharp knife, make 3 or 4 diagonal cuts about 1/4 inch deep across top of each loaf. Bake in a preheated 375 degrees F (190 degrees C) oven for 20 minutes. Brush again with egg white mixture. Bake for an additional 15 to 20 minutes, or until bread tests done. If necessary, cover loosely with foil to prevent over browning. Remove from baking sheet, and cool on a wire rack.
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 03-15-2007, 02:41 PM   #165
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
We are going to be there too. Most likely we will be getting in later (like 7:30pm).
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 03-15-2007, 05:01 PM   #166
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Originally Posted by rickandsandi
French Bread
2 large loaves
  • 1 egg white
DIRECTIONS
Rick's bringin the Bread!
www.balrgn.com
Old 03-15-2007, 05:03 PM   #167
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
RG
The contaiment field is holding! No worries. Man you shoulda seen the flash it made when it touched to bottom of the salad bowl!
Got some Nukie fuel from work, all is well
www.balrgn.com
Old 03-15-2007, 05:17 PM   #168
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cake
Oooooooooooooooo
We're bringing
GREEN cake? Who's bringing Ice Cream????
www.balrgn.com
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
your tow rig john hd Off Topic Forum 25 01-14-2003 09:49 PM
withdrawl symptoms-how to survive the winter without your Airstream bhsl8 Our Community 16 11-06-2002 05:28 AM
winter camping murphy Our Community 1 10-27-2002 06:31 PM
Winter in an Airstream ????? Boris Carlove Our Community 9 08-04-2002 07:58 AM
