Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Extreme makeover - hmmmm that would be really cool - think we can do it? Anyone want to volunteer their trailer ?? Hee Hee....
I'll certainly volunteer mine -- and the "demolition" phase has already been done, thanks to Mr Ray "Hot Shot Express" Reavis.
The frame has been redone, but other than that the trailer is as naked as you can get. Interior skins off, no electrics/plumbing/tanks, nada. We would love help with the bodywork (Aerowood has very kindly offered to source materials for us and fabricate a few things), running electric & plumbing lines and installing tanks (we've rehabbed a couple of houses but have zero experience with trailers), and getting the interior skins back up. We're willing to put in long hours and supply lots of food and beer!
Then it would at least be usable -- even if we were just sleeping on air matresses and using a cooler, at least we could get to a few more rallies this year!
(BTW, I sent in our application for the FCU via the main WBCCI website -- I hope that was the right way to do it.)
Corraleno,
Normally, applications are sent to the Unit. An exception would be if someone wanted to join the WBCCI as a Member At Large, MAL, with no unit affiliation.
OK, I just went to the FCU website linked in your signature, and printed out the application form. Who do I make out the check to, and do I send it to the address on the form (Glendale, AZ)?
Hi Jackie and welcome. Make the check out to Four Corners Unit and send to me, Brad, at the address that's listed on the form. Hopefully its the Port Au Prince address.
Thanks and I look forward to meeting you.
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
__________________ http://www.airztream.com
Ken, do you need to be a member of the WBCCI to participate in this rally. It is exactly what I'm looking for. I have a 72 Soveriegn that needs a lot of work. It has a lot of new replacement features. Heater, AC,hot water tank, but needs alot of repair work. Hope to be able to make it .
I don't have first hand experience on removing silicon. I'm going to get some because I have some on my trailer. What I understand it is very tedious work with popcicle sticks and even peanut butter. In my case it seems to have hardened and just picks off.
I have used a 3-M product, oddly enough it's called "indoor outdoor caulk remover". It comes in a 8oz plastic bottle with a red and yellow label, and looks like white glue.
I had great success with it.
You apply it in a thick layer, completely covering the bead of caulking. Let set for at least 2 hours - I let mine set overnight.
I used a plastic putty knife to get the end loose, then the old caulk peeled off like a long worm. Almost no clean-up required.
Great stuff IMO.
Good luck, sounds like a great rally and a great theme.
Dave
Thought I'd post a few photos of Bambi's problem spots... I need to gather a list of supplies I must bring in order to make these repairs. Olympic Rivets? Aluminum (thickness?), Vulkem, etc. etc.
There is the belly belt. This needs to be removed in order to get the belly pan off.
Then there is a crease in the belly pan under the doorway. Probably just a patch or mucho vulkem..
Then there is the rip by the wheel and the detachment of the pan from the wheel well. When driving through water it just gushes up into the pan and who know where else.
These are but a few of the issues to deal with in regard to the belly pan. Particularly worried about where the belly pan connect directly to the frame without the belly belt in between
This is a 1961 remember. Much different from the 70's units.
Let's see some other projected projects
__________________ May your Travels be Many
In the Journey that is Life
I would be curious what Aerowood has to say - If the belly is in otherwise good condition, I would tend to try and make a nice patch first. As far as the wrap goes - I would wrap a sheet of new metal over the old if thats possible - I would have to look at it - I also can't tell if you need a new piece of molding to go all around the wheel well without looking at it. On the wrap, you could remove all the rivets along the rivet line and slip a new piece of metal under the upper sheet then rerivet with olympics since you cannot get behind the sheet to use buck rivets. I would use as few olympics in that area as possible though...
