View Poll Results: GA Fall leaf thing location
McKinney Campground 4 36.36%
GA Mountain Fair Campground 7 63.64%
somewhere else!! 0 0%
Voters: 11. You may not vote on this poll
Old 09-27-2006, 08:51 AM   #309
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by ALANSD
thanks for that offer! The coffee pots and all are great ideas...
We expect to arrive Friday at 7 or so, but we are not red - meat eaters.....
I am sure others will be glad to take up that stew offer.. Maybe we can all share a dessert that first night or some after dinner drinks. Getting closer
Maybe they could fix some "RV Stew" for you guys. You know, no meat, just organs!
I thought most Brunswick Stew was made with Chicken.
Family of Disney Fanatics
WBCCI# 4821
Old 09-27-2006, 09:09 AM   #310
McLogger's Avatar
Columbia , South Carolina
Originally Posted by Happycampers
I have a set of new 1000 lb spring bars, if anyone is interested let me know and I will bring them if I don't hear from anyone I will leave them home.
Yes, I am a newbie! What is a or what are you calling a spring bar??
Happy Camping
McLogger, AIR # 16452
McLogger is offline   Reply With Quote
Old 09-27-2006, 09:44 AM   #311
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Hi Mcogger, They are the weight distributing bars that go on your hitch, the ones with a chain on the ends. I don't think you would need them with a 27' but that is up to you. You woulld need around 800 lb.
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 09-27-2006, 09:49 AM   #312
2006 30' Safari
Orlando , Florida
I think you need them on any size of Airstream except maybe Bambis. But based on the tongue weight of my 30' Safari, I can't imagine not needing them on anything more than 22' for handling. But then again, I haven't towed anything other than my 30' and things like ski boats that don't need them for sure.
WBCCI# 4821
Old 09-27-2006, 10:10 AM   #313
1979 30' Argosy
M M, Sorry, I dinn't make myself clear. I didn't mean that he didn't need any bars at all. I ment that he doesn't need 1000 lb. bars for a 27ft.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 09-27-2006, 10:16 AM   #314
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
while on this subject the bars seem to hang pretty low, is that ever an issue goinh over driveway ramps or? Seems like I should not install mine until I am out in the street where its flatter.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-27-2006, 10:23 AM   #315
1979 30' Argosy
Alan, I have never had that happen I have a pretty good drop coming out of my driveway. Sometimes the bottom of the shank drags if I don't go out on an angle, everytime that happens I think I will cut the bottom off of it then after I get gone I forget it till the next time.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 09-27-2006, 10:51 AM   #316
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
thanks, mine is not a big drop but my motorhome hitch used to scrape, and the trailer seems close but not hitting. I bought the linch pins at Ace Hdware
and ready to roll. Thanks to ClancyBoy for the bars!! I painted em up & they look great.
I am new to using the bars also, have put them on but not towed yet with them. Hope to on this coming Saturday...
AIR #005
retired!
Old 09-27-2006, 11:06 AM   #317
2006 30' Safari
Orlando , Florida
I'm sorry, I was the one that misunderstood. I have 1,200 # bars on my 30' and everyone thinks that is too much. I have that heavy so I can carry heavy, up to 1,000#, loads in my truck while I tow my Airstream. If I didn't carry any extra load, I would have gone with 1,000# bars.
There is a lot of debate, however, on whether too big is good or bad. Some think it is better to undersize and others think it ok to oversize the bars. I think it depends on the brand of weight distribution system and bars you have and how they are designed to work. I am less familiar with the traditional spring bar system that uses chains than I am with the Equal-i-zer brand of system that I use. I know the principle of how they work is the same, just a little different in how the achieve the same results.
All that I have read for the traditional chain and bar type system such as the Reese and other similar systems says that the spring bars should be adjusted so that the bars have a slight upward bend. I have the Equal-i-zer brand that has 2" sqaure solid steel "spring bars" that are not going to have any bend, slight or otherwise, unless I have grossly overloaded the system.
Initially I had some problems with the rig meandering all over the road at highway speeds. I contacted Equal-i-zer and they told me it is better to oversize their bars than to undersize them. They also said that the 1,200# bars are not compatible with the 1,000# hitch. The customer service rep told me how to determine if an adjustment in weight distribution is needed and how to adjust for temporary increases in load in the bed of my truck and temporary decreases in load. He also told me how to adjust for permanent increases and decreases in load. The adjustments equate to the "add a link, subtract a link" method for temporary adjustments for the chain systems and the same "add a washer, subtract a washer" method for adjustments to the hitch head for permanent adjustments. As it turned out, the problem I had encountered was simply not enough air in the front and rear tires of my truck. Once I aired up the tires, my handling problems disappeared. I can now handle my truck and trailer combo with two fingers at highway speeds. From a handling stand point, you truely cannot tell it's back there. Word to the wise when purchasing a new 3/4 ton vehicle: dealers let some of the air out of the tires to make them ride softer while they are on the lot so you need to check that first thing when you buy one. It will ride harder, but you will have more control.
I always get a little confused when talking about the chain links and spring bars since most of that conversation is about other brands of hitches. I have to remind myself that the Equal-i-zer brand accomplishes the same thing through a slightly different design.
I hope I haven't added to the confusion.
WBCCI# 4821
Old 09-27-2006, 11:30 AM   #318
McLogger's Avatar
Ok! I have them and and I call them stabalizer bars. Thanks.
Happy Camping
Old 09-27-2006, 12:13 PM   #319
1979 30' Argosy
Change of subject... Fabric
Hello everyone.. this is Annie and I would like to know if anyone knows of any fabric discount stores near where we will be or on route to Fla thru Georgia.. Thanks
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 09-27-2006, 04:44 PM   #320
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Yes you can visit a WWW.JOANN.COM STORE THERE ARE MANY NEAR the highways.
AIR #005
retired!
Old 09-27-2006, 06:17 PM   #321
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Brunswick Stew
Hi Group,
As I attempt to make it, the stew consists of Stew Beef, carrots, celery, potatoes, and onions. I am sure it could be made with chicken instead of red meat just as easily. I also enjoy preparing Hobo stew. It is also made with stew beef and is loaded with veggies. Both are good choices for an easily prepared one course meal. These are great comfort foods for cool fall evenings.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 09-27-2006, 08:03 PM   #322
GoNomad's Avatar
1975 Argosy 28
Anderson , South Carolina
Annie(Happycampers), My wife Holly is a fabric fanatic and you two should talk once you get here. Our favorite fabric store in Wahala SC is closing after 50 plus years in business. He was not sure when they would close their doors so we will call.
Is it time yet??????
Nick & Holly
1975 Argosy 28 Rear Bath 1963 Shasta Airflyte
2008 Toyota Tundra Double Cab SR5 5.3L 4x4
"We've got PBS minds in a MTV world" J.B.
GoNomad is offline   Reply With Quote
