Old 10-31-2008, 05:19 PM   #449
Judy Barde's Avatar
1960 24' Tradewind
pittsburg , Kansas
Would like some info about polishing. You all saw the stage that I am at. I used Nuvite Grade 7 what grade should I use next? Or if anyone has a better product? Also I have a porter cable buffer and need to order some new pads???? Suggestions and where to order them. SOMETHING THAT IS A QUICK FIX HA. I have done 3 passes on the trailer so far.Thanks Judy B. Loved all the photos and Thanks Steve you did a great job. Beautiful family.
S. Silver
Judy Barde is offline   Reply With Quote
Old 11-01-2008, 05:07 AM   #450
Natchitoches , Louisiana
WOW! Sounds like you did the right thing taking the scenic route and taking your time getting home. ....... "Not only is the destination to be enjoyed but the journey as well!"
As some of you know I am on the executive staff of the Sheriff's Office and my "late return" to my jurisdiction was a topic of discussion amongst the Chief Judge, District Attorney, and Sheriff with myself in the middle. Despite my brilliant argument justifying my little jaunt through southwest Missouri and all of Oklahoma, I was found in "contempt of vacation" and sentenced to infinite duty in the courthouse so one of our two judges could go to Wyoming, the DA could go to who knows where, and the Sheriff could go up to Mena Ar to ride horses. Despite my punishment I kind of enjoyed being the courthouse czar for a few days. But now I need another vacation so I think we will take that proposed trip to New Mexico and Arizona after all. Payback is gonna be tough though, I'll probably be officially grounded for a couple of months after that............JD
jdthor is offline   Reply With Quote
Old 11-03-2008, 05:56 AM   #451
1969 31' Sovereign
1951 21' Flying Cloud
Alex , Oklahoma
Hey Steve, James and I worked this past weekend on fixing our spots where our A/S was bubbling, during the pressure test. As far as the tail lights go, James said there is no way to seal the inside, because of the can that holds the light bulb. He still has all the running light to do. Hope when we test again in Feb (Texas Rally) we will have less bubbles.
1969 Sovereign
1951 Flying Cloud SS#7062
AIR #18751
CJ of Okla is offline   Reply With Quote
Old 11-03-2008, 08:01 AM   #452
76sovereign's Avatar
1976 31' Sovereign
ozark , Missouri
James ...Did you take any close up pictures of the Vulkem application? I would like to see them and how you cleaned up the mess if any.
I'm on my way to clean the walls with TSP in preparation of some possible painting, while the weather stills holds.
76sovereign is offline   Reply With Quote
Old 11-03-2008, 11:02 AM   #453
1969 31' Sovereign
Alex , Oklahoma
Kani/Jack,
I put 1" painters tape parallel to the seam and or trim. Left a small gap between the tape and seam, put on the Vulkem. I pressed it into the seam with my finger. Took lacquer thinner and paper towels and cleaned the trim where it smeared. After the vulkem set for a little while, I pealed off the blue painters tape. Made the prettiest straight line I have ever seen. You are going to have it on every finger no matter how careful you are. CJ
1969 Sovereign
AIR #18751
Old 11-03-2008, 12:32 PM   #454
soldiermedic's Avatar
Florissant , USA
CJ,
We should be set for doing the test in February. I am hoping to get confirmations of people getting the test done. I am looking at over $600 to make the trip, and need to cover my expenses. If anything, I will do it next time we meet if I can't make it, but I plan to be there. I would also suggest looking at your door gasket on the left side. There was alot of air coming from that area.
On a side note, this is how I do vulkem application.
1. Place a piece of blue painter tape directly over the seam where you are sealing.
2. Using a razonr knife, cut along the seam through the tape (Gentle now)
3. Squeeze your vulkem or parbond over the slit in the tape.
4. Use a gloved finger and smear the vulkem into the seam.
5. Pull off tape for a perfect line.
CJ's works just as good for non seam areas.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 11-03-2008, 03:22 PM   #455
1969 31' Sovereign
Alex , Oklahoma
Steve, the door gasket was put on new at the same time we did the windows. We checked it yesterday and it appears to be in good shape. If you can't make it to Texas in Feb, we will catch up with you at another rally.
1969 Sovereign
AIR #18751
Old 08-04-2009, 05:31 PM   #456
bill almond's Avatar
1965 26' Overlander
winfield , Kansas
my wife has some concerns about the chili cook off. well not the cook off it self but the 5 hour ride home on sunay!! no this is not a lol shes series.75mph down the interstate wiht the windows up makes for a long trip. SO SIGN ME UP!!!
bill almond is offline   Reply With Quote
branson, chili, fall, rally, cook off
NWS : NW Forum rally in the fall 2airishuman Forum Rallies & Meet Ups 18 05-03-2009 01:05 PM
SoCal : CA Streamers Fall Fiesta 2008! BamCamper Forum Rallies & Meet Ups 450 10-24-2008 09:16 PM
AIR Midwest : Branson 'Spring is in the Air' Rally soldiermedic Forum Rallies & Meet Ups 708 04-21-2008 07:53 PM
AIR Midwest : October Branson Forums Rally soldiermedic Forum Rallies & Meet Ups 897 01-15-2008 03:53 PM
SoCal : California Streamers Fall Rally Kevbo10 Forum Rallies & Meet Ups 1311 11-09-2007 11:27 AM
