Old 04-06-2008, 10:18 AM   #43
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
It is the aliens...
Originally Posted by Stefrobrts
I don't know what it is about Trout lake, but once you've been, you can't NOT go back...
Steph,
I am sure it is the alien influence... they have reprogrammed our little brains! It will be great to see you guys again! Glad you will make it!
Mrs. NorCal Bambi ~ traveling in S. Tardis from the Great State of Jefferson
Resistance.... is futile....
CaddyGrn is offline   Reply With Quote
Old 04-06-2008, 02:43 PM   #44
Alumicult in Oregon
edgeman's Avatar
1981 27' Excella II
Seaside , Oregon
Talking
Did the Aliens bring the lake back yet?
edgeman is offline   Reply With Quote
Old 04-06-2008, 04:26 PM   #45
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Good, we get to meet Alki and Barclay.....and Steph, from what I'm understanding, in some senses you are going to be at something that gets pretty close to a 4H session - what with aliens and all.
Janet - Any suggestions as to what we should bring for the food component? Having not attended one of these before we aren't sure what would work.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 04-06-2008, 04:34 PM   #46
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
This place is in the middle of nowhere -so you will need to pack in almost everything you want. Running out to the store is not in the picture. tehre is a tiny gas station not too far away... they sell milk and butter.
We have a few community meals planned - see post 2. you are on your own for the rest. You will also have to pack out garbage. there is no dumpster, no trash can, no campground services. There are however, fire wood, a babbling stream, great views and fun folks.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 04-06-2008, 04:43 PM   #47
safari57's Avatar
1960 24' Tradewind
West Coast , BC
For Friday night we'll bring a dessert and for Saturday night a green salad. Also some kind of buns - Donna seems to veer towards the bakery every time we hit a store so we may as well take advantage of that.
Qty suggestions?
Barry
Barry & Donna
Old 04-06-2008, 06:02 PM   #48
Darol Ingalls's Avatar
Airstreams and Food - amazing, isn't it??? Darol
Darol Ingalls is offline   Reply With Quote
Old 04-06-2008, 06:16 PM   #49
1979 25' Tradewind
conway , Washington
'airs', food, music, and friends; ahhhhhhh
paisanochic is offline   Reply With Quote
Old 04-06-2008, 10:39 PM   #50
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Very amazing!
It is amazing Darol! And we always seem to go away from these events hungry! Oh dear, another 5 pounds....
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson
Old 04-07-2008, 03:41 PM   #51
acgypsy's Avatar
Western , Washington
MIT tin foil hat study
On the Effectiveness of Aluminium Foil Helmets:
An Empirical Study
Ali Rahimi1, Ben Recht 2, Jason Taylor 2, Noah Vawter 2
17 Feb 2005
1: Electrical Engineering and Computer Science department, MIT.
2: Media Laboratory, MIT. Abstract
Among a fringe community of paranoids, aluminum helmets serve as the protective measure of choice against invasive radio signals. We investigate the efficacy of three aluminum helmet designs on a sample group of four individuals. Using a $250,000 network analyser, we find that although on average all helmets attenuate invasive radio frequencies in either directions (either emanating from an outside source, or emanating from the cranium of the subject), certain frequencies are in fact greatly amplified. These amplified frequencies coincide with radio bands reserved for government use according to the Federal Communication Commission (FCC). Statistical evidence suggests the use of helmets may in fact enhance the government's invasive abilities. We speculate that the government may in fact have started the helmet craze for this reason. Introduction
It has long been suspected that the government has been using satellites to read and control the minds of certain citizens. The use of aluminum helmets has been a common guerrilla tactic against the government's invasive tactics [1]. Surprisingly, these helmets can in fact help the government spy on citizens by amplifying certain key frequency ranges reserved for government use. In addition, none of the three helmets we analyzed provided significant attenuation to most frequency bands.
We describe our experimental setup, report our results, and conclude with a few design guidelines for constructing more effective helmets.
Experimental Setup
The three helmet types testedThe ClassicalThe FezThe Centurion
We evaluated the performance of three different helmet designs, commonly referred to as the Classical, the Fez, and the Centurion. These designs are portrayed in Figure 1. The helmets were made of Reynolds aluminium foil. As per best practices, all three designs were constructed with the double layering technique described elsewhere [2].
A radio-frequency test signal sweeping the ranges from 10 Khz to 3 Ghz was generated using an omnidirectional antenna attached to the Agilent 8714ET's signal generator.
The experimental apparatus, including a data recording laptop, a $250,000 network analyser, and antennae.
A network analyser (Agilent 8714ET) and a directional antenna measured and plotted the signals. See Figure 2.
Because of the cost of the equipment (about $250,000), and the limited time for which we had access to these devices, the subjects and experimenters performed a few dry runs before the actual experiment (see Figure 3).
Test subjects during a dry run.
The receiver antenna was placed at various places on the cranium of 4 different subjects: the frontal, occipital and parietal lobes. Once with the helmet off and once with the helmet on. The network analyzer plotted the attenuation betwen the signals in these two settings at different frequencies, from 10Khz to 3 Ghz. Figure 4 shows a typical plot of the attenuation at different frequencies.
A typical attenuation trace form the network analyserResults
For all helmets, we noticed a 30 db amplification at 2.6 Ghz and a 20 db amplification at 1.2 Ghz, regardless of the position of the antenna on the cranium. In addition, all helmets exhibited a marked 20 db attenuation at around 1.5 Ghz, with no significant attenuation beyond 10 db anywhere else. Conclusion
The helmets amplify frequency bands that coincide with those allocated to the US government between 1.2 Ghz and 1.4 Ghz. According to the FCC, These bands are supposedly reserved for ''radio location'' (ie, GPS), and other communications with satellites (see, for example, [3]). The 2.6 Ghz band coincides with mobile phone technology. Though not affiliated by government, these bands are at the hands of multinational corporations.
It requires no stretch of the imagination to conclude that the current helmet craze is likely to have been propagated by the Government, possibly with the involvement of the FCC. We hope this report will encourage the paranoid community to develop improved helmet designs to avoid falling prey to these shortcomings. Acknowledgments
The authors would like to thank Andy (Xu) Sun of the MIT Media Lab for helping with the equipment, Professor George Sergiadis for lending us the antennae, and Professor Neil Gershenfeld for allowing us the use of his lab equipment. (Please direct any queries to the authors, NOT these folks) There's also an informative video, courtesy of Discover Channel's Daily Planet.
An Empirical Study
17 Feb 2005
Introduction
Experimental Setup
Conclusion
acgypsy is offline   Reply With Quote
Old 04-07-2008, 04:37 PM   #52
aluminauti
whitelight's Avatar
Where we , Park it!
Here comes Our Gussy
If our aluminum helmets don't fail us , we will be at Area 33!
Don't know about the, but we drink wine!!!
Will bring something vegetarian of interest . . .
. . . . and the instruments
Gerry & Carolyn
whitelight is offline   Reply With Quote
Old 04-07-2008, 05:01 PM   #53
_
pour me a glass of whatever jeff and these guys from mit are smoking...
u and the peasant chic have got me very very worried.
cheers
2air'
Old 04-07-2008, 05:04 PM   #54
1979 25' Tradewind
conway , Washington
welcome 'whitelight' to our rally; it will be great to meet you...or have we already met?
two Carolyn's....an unusual circumstance; and as far as I know, friends, Patsi and Gerry of 64lawncondo, will be coming too. The carolyns and the gerrys may have to come up with alias'
Where's home for you now?
Caio,
Carolyn
Old 04-07-2008, 05:12 PM   #55
1979 25' Tradewind
conway , Washington
oh, don't worry 2air; just enjoy.....have another glass!
Caio
Old 04-07-2008, 06:16 PM   #56
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Ok everyone ~ are you all up on your current shots for this toxic area?
2008 31' Classic / 2008 Silverado 2500 4x4 duramax ddarr2 Member Introductions 19 03-09-2010 12:14 PM
2008 Cayenne Wayward Tow Vehicles 4 03-24-2008 10:35 AM
Towing 2008 19' Bambi with 2008 Toyota Highlander JDBfreeheel Tow Vehicles 1 03-08-2008 09:27 PM
2008 Tundra & 2008 Land Cruiser TV advice Ray Eklund Tow Vehicles 2 02-21-2008 07:49 PM
Christmas 2008 SRW Off Topic Forum 2 11-18-2007 03:26 PM
