Old 03-19-2008, 09:28 AM   #1
Yamaha 1000 Propane Conversion - URGENT
My carb has been converted by US Carburetion and ready to ship back to me. They are asking what diameter hose to ship to me. I haven't a clue.
Since their conversion includes a regulator, I assume I'll have to connect at the tank, rather than after the switch-over regulator (which I had hoped).
So what size hose do I need? What size tee? How many quick disconnects?
Thanks for your help.
Neil Ervin, Sequim, Washington (on the north edge of the beautiful Olympic Peninsula)
neil.ervin is offline   Reply With Quote
Old 03-19-2008, 10:54 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
When I ordered mine they only asked about the length hose I wanted. The diameter is bigger than the hoses on my Safari's tanks. I bought a quick disconnect from them (because of the size) but bought the other fittings I needed from a local hardware store. I also got extra disconnects so I can use my BBQ off the same hose.
Old 03-19-2008, 02:07 PM   #3
Where does the hose connect in? At your tank? Or after the switch-over regulator?
Old 03-19-2008, 02:40 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Hosers
They only needed to know what length supply hose I wanted. I got the
longest available. I usually run my 2000 Honda in a two man tent to keep it
out of the weather (and out of sight), the longer the supply line the the
further the tank.
I use two quick dis-connects, one at the tank regulator and the other at
the low pressure regulator.
As for the size of the line going to the carb, I use surgical tubing, very
flexible and easy to route inside the generator. Just a quick pinch and it
shuts down the unit instantly. Plus it seals well over the barb fittings they supply with the carb and its easy to remove.
One feature I wasn't crazy about was the size of the low pressure regulator
that supplies the carb. No room to conceal it inside the unit. I mounted it
on the outside of the removable service panel. I remove the regulator and install a spare panel
for transport and storage, and carry all hoses etc. in a separate bag.
If it wasn't pouring rain today I'd take some pics to post so
you could get an idea of how it goes together. Maybe later.
Consider getting a combination tach/hour meter. It will help you tune the carb and can be used
for service intervals. Once you've got an idea of how long you can run on a tank you can
anticipate your next refill. Both Honda and Yamaha offer them.
Hope this helps.
Are you using the petrol/propane conversion??
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-19-2008, 06:24 PM   #5
Tank regulator = exit of tank ???
or at the trailer side of the double tank switch-over control?
Where is the low pressure regulator? On the yamaha generator?
Old 03-20-2008, 04:20 PM   #6
Our Approach Was A Little Different
Neil
Don't really know if the sequence of these might be a little confusing.
The first shows the 11lb tank and supply hose, Iv'e found that it is important to keep the supply hose as straight and flat as possiple.
Seems that if the quick disconnects get twisted or not straight they will restrict gas supply. I don't use the A/S tanks at all.
Second shows the 11lb tank and high pressure regulator with the quick disconnect attached.
Third shows the low pressure regulator mounted to the service panel of the Honda with the quick disconnect attached on the inlet side.
The Black screw with lock nut you see on top left is the mixture adjustment. The green surgical tubing is what I use for the shut off valve.
The foam ring behind the regulator is to protect the primer button.
Forth Pinching the tube to shut it down>
ID:	56606   Click image for larger version
ID:	56608   Click image for larger version
PFC
"Tahawus"
RLC
Old 03-21-2008, 11:22 AM   #7
Nice pictures. Thanks.......
Old 03-23-2008, 03:28 PM   #8
Has anyone connected a propane generator to their airstream trailer propane tanks?
I took a picture today of my double tank setup, but the picture did not take. Bummer.
My two tanks feed into a switchover valve and then into a regulator, and then on to the trailer. That trailer side of the regulator is located about mid tank high and almost between the tanks (2005 Safari). It doesn't appear there is enough space in there to place a tee (and a quick disconnect) to feed the 12 foot hose to the propane generator (Yamaha 1000).
I really need your help.
Please???
Old 03-23-2008, 04:04 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
HI Neil,
I use my LP-Yamaha 1000 directly from my CCD'a LP tanks. You will need an additional access 'T' like a Camco model 59133, or the 'T' and 12' hose model 59143. I use the latter and it works fine for either the genny or my gas grill.
Old 03-24-2008, 04:57 PM   #10
Robert Cross......
In your pictures, it looke to me like you have a regulator at your stand alone tank and also one at the generator. Are both needed?
Old 03-24-2008, 05:01 PM   #11
Originally Posted by lewster
HI Neil,
Lewster, You say you attach your hose directly to the tank with the Camco 59133 tee. Do you have a high pressure regulator at the tank as shown in Robert Cross' pictures?
Old 03-24-2008, 08:09 PM   #12
Robert Cross......
In your pictures, it looks to me like you have a regulator at your stand alone tank and also one at the generator. Are both needed?
Neil
The one you see on the LP tank is the same you have on your trailer tanks,
the one at the generator is a low pressure demand regulator, the more
vacuum applied from the carb venturi the more the more gas delivered.
PFC
"Tahawus"
RLC
Old 03-25-2008, 09:41 AM   #13
Robert Cross
So then there MUST be a high pressure regulator in the line. In addition to the generator attached low pressure regulator.
Cannot feed directly from tank to the generator's low pressure regulator?
Correct?
Old 03-25-2008, 11:27 AM   #14
Wayne&Sam's Avatar
Images: 21
Yes, you want to take pressure regulated gas from the tanks to the generator. The generator's regulator won't have to do any work. But the same hose can then be used on something else- say a BBQ that doesn't have a regulator on it.
Yamaha ef2400is propane powered gen Boondocker Generators & Solar Power 43 01-13-2015 08:57 AM
My propane Yamaha Generator from US Carburetion TitusLivy Generators & Solar Power 87 12-26-2011 11:01 AM
An urgent issue wacnstac Wheels, Hubs & Bearings 7 03-31-2006 06:48 AM
Urgent...Jacking trailer hhuber Jacks, Stabilizers, Lifting and Leveling 20 10-06-2003 10:47 PM
