Old 11-23-2009, 08:46 PM   #1
Central , Mississippi
Worthington tanks with gauge guts
Since we are a 'knowledge sharing' group, here's the innerds of a Worthington tank readout gauge.
My 40 lb tanks needed new opd valves and as bad as I hated to loose the level sensor that was part of one of them, they had to go. The gauge was mounted on top of the valve and hooks to the interior panel for a neat way of knowing how much propane was left (or so I thought).
What's inside kinda surprised me. A really cute level sensor that has a float, turns a magnetic rod that twists and moves the external gauge. The only problem is where the float IS.
Basically the float can only start moving down once the level is below 1/2 a tank.
Reminds me of an old chevy I had, the thing would go forever on the first 1/2 a tank but the 2nd 1/2 was only good for a few miles.
ID:	91439   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-23-2009, 08:56 PM   #2
That was good engineering.
The gauges told you when the tank was half empty, instead of half full.
But there are strip gauges that you can use, ......well sort of.
After you have been using a little LPG, which changes the internal temperature of the liquid, you throw some hot water on the strip gauge. You look at the strip, for the color change, and that tells you how much LPG you have left...........as well as how much is gone.
They are cheap and actually, work pretty good.
Old 11-23-2009, 09:04 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You could always add one of these gauges. Not original but at least some type of indication before the tank runs empty....
The Original GasWatch | Propane Gauges | Propane Level Indicator | Propane Tank Gauge | Gas Gauge | Gas Grill Gauge | > propane gauge, propane tank gauge, grill gauge, grilling gadget
Old 11-23-2009, 09:09 PM   #4
Gary.
I tried a couple of those, and they are not worth a hoot.
All they do is measure pressure.
Both of mine failed within a couple of months, and would show nothing.
That's not a good thing for the BBQ grill.
Old 11-23-2009, 09:33 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Use a bathroom scale. You'll get a very exact feel for amount of propane, provided your scale is reasonably accurate. Of course, you have to dismount your cylinder in order to do it.
And, of course, if you lift propane cylinders with varying amounts about a gazillion times, you don't even need a scale to tell more or less what's left inside. (I still use the scale to fill, though.)
Lynn
WBCCI 21043
Old 11-23-2009, 10:04 PM   #6
cameront120's Avatar
1972 25' Tradewind
I just dump a pot of hot water onto the side of the tank and then feel for the cold spot where the propane starts. The metal will be warm where there is air in the tank.
North Vancouver, BC
Old 11-24-2009, 03:01 PM   #7
_
good info hiho!
it looks like this design could be easily adjusted for ALL size tanks and horizontal tanks too.
i wonder what they are using on the newer tanks?
the 40s on my trayla have round analog tank gauges AND electrically connected indoor reads.
but the first 1/4 tank still seems to last longer than the last 1/4.
did you contact worthington for replacement options?
cheers
2air'
Old 11-24-2009, 05:13 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
2air'
The ones like yours with a separate tap for the gauge - the gauge has it's own float.
I just snagged a set of those from an 06 for a very good price - can't use the inside wiring but the gauge is a good addition - I hoped. Have you found it to be reasonably accurate at all....
I don't see anything on Worthington's site about gauges at all for consumer products.
Old 11-24-2009, 05:58 PM   #9
_
...Have you found it to be reasonably accurate at all....
yeah i scanned the W' website and struck out too.
the tank mounted gauge and wired connection are consistent with each other over the long term
and EMPTY/FULL are accurate
the 1st quarter of a full tank seems to last longer than the last quarter, every tank full and in all seasons.
and i always open the 2nd tank about that time the primary hits 1/4.
so they are pretty reliable (especially compared to the holding tank sensors)
cheers
2air'
Old 11-24-2009, 06:55 PM   #10
I have a second tank with a gauge bung welded to the top, not as a part of the valve like this one, it still has the gauge functional after the opd retro. I also saw the welded bung style available on the worthington site, no option for an opd/valve/gauge. The valve in the photo was made in italy.
I plan on using the non-gauge tank as the primary and when I see the gauge drop, I know that the change over regulator has swapped. Time to refill.
It's kinda hard to use the hot water method with the tanks in a cover.
Old 11-24-2009, 10:20 PM   #11
1972 25' Tradewind
I have no cover for mine, so I hadn't thought of that.
North Vancouver, BC
Old 11-25-2009, 09:12 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Wink
I find that Honey Brown works better than Sam Adams....
but Im the Husband, so we went to Cleveland. 😘
RLC
Its a crooked piece of time that we live in.
John Prine
free 40 lb 1997 worthington horizontal tanks redstart LP Gas, Piping, Tanks & Regulators 13 08-22-2009 10:51 AM
Worthington lp tanks LEAKY29 LP Gas, Piping, Tanks & Regulators 7 05-15-2006 07:33 PM
Polishing the Worthington Tanks? Charcigar Cleaning, Stripping & Polishing 2 07-26-2005 08:30 PM
Getting to the Guts gbrentsmith Waste Systems, Tanks & Totes 4 05-30-2005 11:39 AM
Ordering tanks - remote read gauge? ClassicRides LP Gas, Piping, Tanks & Regulators 3 01-04-2005 06:56 PM
