Old 05-15-2006, 12:53 PM   #1
1987 29' Sovereign
JAMESPORT , New York
Worthington lp tanks
Here is question about getting the lp tanks recertified. I have two 40 lb. Worthington lp tanks that need to be refitted with OPD valves. I took them to my local gas company and they said they would refit the tanks with the new valves and certify them for 5 years, but this was the last time the tanks could be recertified since they were recertified 2 times before. I left without having the tanks worked on thinking what good is having to pay to have the valves replaced if I can use the tanks only a another 5 years. From what I can tell one tank is original to the trailer built in 1987, the other one has factory date stamped on it 1977. I was under the impression that alum. tanks could be used indefinitely. What is the is the real deal?
LEAKY29 is offline   Reply With Quote
Old 05-15-2006, 01:06 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Leaky29,
Try another propane dealer, this site states that the tanks can be recertified for an additional 5 years indefinately: http://rvbasics.com/techtips/propanevalves.html
or at least until the tank is determined to be unsafe.
Bill
Just my personal opinion
Old 05-15-2006, 01:42 PM   #3
1987 29' Sovereign
From one Bill to another,thanks for the advice,I just priced new Worthingtons and at $180.00 each plus shipping! I will definitely check out other propane dealers.
Old 05-15-2006, 02:23 PM   #4
Frank S
peoria , Illinois
Hi LEAKY29--I have two 30lb Worthington aluminum tanks with originial dates of 3-73. Had original certification in 7-93. Installed OPV and recertified one tank 9-99, the other 6-00. Recertified both tanks (which already had OPV) 8-05, so they are good till 8-10. Serviceman told me that as long as the tanks didn't leak, or have serious dings, or other apparent distress, they could be recertified every 5-years.--Frank S
Frank S is offline   Reply With Quote
Old 05-15-2006, 02:34 PM   #5
Frank S
peoria , Illinois
Hi LEAKY29--Forgot to mention. When OPV's were installed on my tanks I paid about $18 each which included the recertification, plus a propane fill. When I recertified in 8-05 I was only charged for propane for the empty tank, and a top off for the partially filled tank.--Frank S
Old 05-15-2006, 05:17 PM   #6
1994 30' Excella
Mississauga , Ontario
Can someone tell me what the weight difference is between the Worthington 30lb tank and a steel 30lb tank?
Al
Old 05-15-2006, 06:14 PM   #7
1976 25' Caravanner
Campton , New Hampshire
The tare weight (empty) of alum 30#is 16.5# , for steel it is 25.4#. Note , the new Worthington alum is listed at 18#
ticki2 is offline   Reply With Quote
Old 05-15-2006, 07:33 PM   #8
1994 30' Excella
thanks for the numbers.
Al
where to buy new aluminum lp tanks.. JohnGalt48 LP Gas, Piping, Tanks & Regulators 3 09-14-2002 10:36 PM
LP Tanks Craig LP Gas, Piping, Tanks & Regulators 6 08-22-2002 08:43 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Aluminum Tanks uwe 1970-79 Tradewind 2 07-17-2002 01:56 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
