Old 02-01-2015, 08:01 AM   #1
1975 25' Tradewind
Aunsin , Texas
Working with LP ( newbie) safety question...
I have installed a new water heater, stove as well as added a feed for a space heater ( installed additional shutoff valves for the stove and heater lines.) I'm testing the gas lines and it appears all connections are solid ( no bubbles ) I see suds collecting where the liquid settles in the connection, but no bubbles being formed. Is there another step or should I consider this a thorough enough test?
Bwilson11 is offline   Reply With Quote
Old 02-01-2015, 08:16 AM   #2
Argosy 7728's Avatar
1977 Argosy 28
Irrigon , Oregon
That's all the propane supplier used as a test for our residential hook up.
Rod
AIR# 60278
Argosy 7728 is offline   Reply With Quote
Old 02-01-2015, 09:51 AM   #3
1974 Argosy 20
Kooskia , Idaho
You can use a product called "snoop" which is available sometimes at the HD or Lowe's but all it is is a soap solution. Might be slightly better but just detergent and water in a spray bottle is all I use.
Old 02-01-2015, 10:28 AM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
One of the annual tests that I do is to pressurize the system. Light a burner and then turn it off. Then I turn off the gas bottles. I come back in a couple of hours and with the bottles still turned off, I relight the burner. If it starts with a good flame, I know the system is holding pressure. If you had a leak, the burner may not light or just barely light.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-02-2015, 11:22 AM   #5
2010 22' Sport
Boise , Idaho
I use windex sprayed on all connections. I know it works because it REALLY foamed up once when I had a leak.
baldwin6601 is offline   Reply With Quote
Old 02-05-2015, 07:40 PM   #6
Poolman's Avatar
1983 31' Excella
Seabrook , Texas
My plumbers always use some fluorescent dye that bubbles, I'm guessing for visibility. But I would think no bubbles = no leaks.
Poolman is offline   Reply With Quote
Old 02-05-2015, 07:43 PM   #7
Kevin245's Avatar
A snoop test is the standard test method. Much better than using a cigarette lighter.
Eleanor Roosevelt
Old 02-05-2015, 08:38 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Just rinse off the 'soapy' stuff when done.. not absolutely necessary, but that way you shouldn't have it streaking down the side of the AS..
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-05-2015, 08:59 PM   #9
ottawa (greely) , Ontario
After doing the soap test you can also use a propane level gauge (it works by pressure) such as in the picture sold at costco, I take mine off my BBQ , and it mounts no tools needed on your propane tank between the tank and supply line for the trailer (inline) all you have to do is make sure all appliances are off and mount the gauge open your propane tank for a few seconds and watch the gauge go up then turn off the valve on the propane tank and the gauge should read steady ,note the reading and recheck it 1 hour later and it should read about the same not drop ( that means you have no major leak pressure held you can do the same test longer if you want to check for smaller leaks ,but remember it's a pressure gauge and if temperature goes up pressure goes up if temperature drops pressure will drop so it's best to do this test when temperature is constant for a more accurate test.
Don
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Help newbie - hot water stopped working...tried both electric and LP Arnoldjeff Water Heaters, Filters & Pumps 4 09-06-2014 04:56 PM
Newbie question: can't get hot working Sro Water Heaters, Filters & Pumps 16 04-04-2014 08:28 PM
Safety question about battery located under the bed bkahler General Motorhome Topics 47 01-24-2013 10:22 AM
GAS safety question steven2themax Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-07-2010 09:58 AM
Disposable Propane Bottle Safety JaceBeck Our Community 6 07-02-2002 01:15 PM
