Old 08-24-2014, 05:26 PM   #1
1999 28' Excella
New Orleans , Louisiana
Winter comes later!
On fresh water tank..if our water is hooked up..what to do? What level should the water inside the tank be for the winter which comes in Campbellsville Ky in late November and December?
badkat is offline   Reply With Quote
Old 08-24-2014, 05:36 PM   #2
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
I would empty the fresh water tank the minute I didn't need it full anymore. Which in your case sounds like now!
Bob Martel
WBCCI# 5766
Old 08-25-2014, 10:57 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Empty.... Pour in correct amount of RV antifreeze. Shut off city supply, run closest cold tap ONLY till line is flushed. Turn off pump and turn on city supply. Run same cold faucet until running clear. Flush remaining cold lines. Should be good.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-26-2014, 08:23 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey BadKat. If you have an air compressor you can buy or make a fitting that will fit the water inlet port and let you attach a quick connect fitting. If you lower the pressure to 35-50 psi or so you can let it flow as you go through the trailer and blow your lines. Each faucet making sure to get the toilet and low point drains, don't forget the outside faucet if you have it. I disconnect the shower flex line. I also, but need to do it separately, do the black tank flush if you have one. Pull the plug on the water heater tank too. With the compressor running I go around and do this 2 or 3 times to be sure. After doing this I remove any water filter elements you may have either under the counter or in the faucet stem. Have new filter on hand to install in the spring. When all done take a gallon jug of RV antifreeze and put some in each drain trap and the toilet bowl as well to keep the seals lubricated. That's pretty much it and you're set when the spring travel bug arrives. NOW, if you're lucky enough to have a heated barn ??????
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
The winter comes.... cruiser54 Winter Living 10 08-31-2010 03:40 PM
57 Olympic Rivets later... wahoonc Ribs, Skins & Rivets 9 09-05-2004 09:22 AM
Historians: Explain why later Excella/Classics are heavier Trailertroll Our Community 2 01-24-2004 02:38 PM
Univolt stop running and start later brunoffrance Electrical - Systems, Generators, Batteries & Solar 6 07-04-2003 12:33 PM
