Old 03-25-2010, 05:38 PM   #1
Why this hole in the tank cover?
After eleven years looking at the hole in the middle of our propane tank cover, I finally wondered why it is there. Hardly for ventilation, as the base is open. I suppose, if there was a resident rodent, the orifice would provide improved rural views for the incumbent. Answers on a postcard.....
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 03-25-2010, 06:34 PM   #2
on the hunt
osolow's Avatar
riverton , Kansas
Send a message via Skype™ to osolow
No clue
but i don't remember my 1990 29ft er having a hole in the cover.
osolow is offline   Reply With Quote
Old 03-25-2010, 07:42 PM   #3
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
It was so you could see the change over regulator.
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Old 03-25-2010, 07:57 PM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I have the same hole in my cover. Since the changeover regulator is at the top just under the lid, I seriously doubt that you are supposed to see it from there.
(But I will agree that decaffeinated coffee is just plain wrong, Bob.)
It looks a lot like the hole that was left in the front of vintage cars to insert the crank so you could hand-crank the engine to start it. I think it is left over from that.
I've wondered what that hole was for too.
Vaughan
Old 03-25-2010, 08:06 PM   #5
Yes Vaughan, I agree. The regulator needs to be at the top, so that liquids such as the odouriser run back into the tank, and don't contaminate the regulator, as explained to me by the Marshall tech people.
Hand-crank handle hole is an appealing idea.
Perhaps the hole was just an Optional Extra for "The owner who wants everything".
We need to know.
Nick.
Old 03-25-2010, 08:29 PM   #6
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
My original regulator (the original) could if I adjusted stuck through the hole. Bad design. After searching and searching for a small gas leak, I found that the plastic indicator cover had a crack for removing the cover.
Old 03-25-2010, 09:10 PM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
Thanks Bob,
I'll admit, I considered that my regulator could well be in a different location than original.
I just couldn't resist the crank idea.
Vaughan
Old 03-25-2010, 09:15 PM   #8
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Isn't that the portal to the blinker fluid fill neck? On second glance, I think it's actually the framus valve adjustment opening.
Great to see you back on here, Nick. REALLY glad. Susan and I are headed over the pond to visit with my nephew, also called Nick, in a year or so. He's about 75 miles NE of London in an area I think called WarBoy. It'll be the trip of a lifetime for us. Can't wait!
www.nesa.org
Air No. 6427
Old 03-25-2010, 10:27 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Nick.
Hi, is it possible that the hole was made for an accessory propane devise? [generator, camp stove, fire pit Etc.] Propane hose connected by quick connector or to a "T" fitting and run through that hole.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-25-2010, 10:51 PM   #10
1983 34' Excella
1967 24' Tradewind
Images: 32
Why run it through a hole when it could just run out the bottom?
Vaughan
Old 03-26-2010, 05:25 AM   #11
Jim, many thanks for your kind words. I'm leaning towards your blinker fluid fill-neck idea....... A few years ago a neighbour had the hood up on her car. She was a determinedly independent lady who ruled her husband with her strong personality, and always told all who would listen that she could do any job a man could do, and better. She told me she couldn't understand why every week she had to top up the cooling fluid reservoir for the radiator, but she could never find a leak. She showed me the low level in a reservoir. I then asked her if she had noticed that the fluid in the windscreen washer never seemed to need topping off, even though she used the washers everyday when driving on our muddy lanes. "Yes", she said, strange, isn't it. How did you know????"
Nick.
LP tank cover ARGOSYCAMPER LP Gas, Piping, Tanks & Regulators 0 02-04-2010 07:46 PM
Drilled a hole in water tank, HELP bmklawt Fresh Water Systems 18 07-12-2009 10:00 PM
Black tank to outhouse hole? davida Waste Systems, Tanks & Totes 22 12-06-2006 07:42 AM
freshwater tank hole.......material and plastic weld kits... leefields Fresh Water Systems 4 02-06-2006 06:44 AM
Weep Hole Cover$ Chaplain Kent Classic Motorhomes 2 11-02-2005 09:09 AM
