Old 10-04-2010, 11:04 AM   #29
Wise Elder
Jammer's Avatar
2010 30' Classic
There are still some campgrounds that sell propane and some smaller service-oriented propane dealers. Portable tanks do have to be removed from the vehicle to be filled, because they have to be weighed, but the right place will do that for you.
Old 10-04-2010, 11:42 AM   #30
_
Originally Posted by wheel interested View Post
Went out to see if I could remove the tank for refill and I couldn't even raise the tank cover...
use a step stool or 3 step ladder.
open the top, remove the wingnut, disconnect the wire sensors.
close and RElatch the cover.
now lift the cover with both hands straight up.
once the cover is off the empty tank is much easier to handle.
but you may not be able to put a full tank back/UP on the A frame.
hopefully only 1 is empty and your man-handler will be around soon.
cheers
2air'
Old 10-04-2010, 12:07 PM   #31
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Being vericially challenged...that's a good reminder too, the ladder goes out next. I'll give it another go trying to be on top of things. I already begged help so it's off for now. Let's see if I can get it into the Burb empty behind the front seat. Thanks for the tips. If I only empty one at a time I should be able to locate "manhandler" some where before time becomes critical. Must I carry beer?
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 10-04-2010, 12:28 PM   #32
aftermath's Avatar
Spokane , Washington
Carol,
FWIW, in Washington State you have to remove the tanks before filling, at least that is what I have been told by more than one propane filler upper guy at the stations I use.
I have yet to purchase propane by weight as a previous poster mentioned. We buy by the gallon. When I asked why I had to remove the tanks the response had something to do with some safety regulation. I have been doing this for more than 20 years now and the requirement to remove the tanks is a relatively new one.
I have two 30 pounders and I wouldn't want to man handle anything larger. Remember.......it isn't always about the size of things.
aftermath is offline   Reply With Quote
Old 10-04-2010, 01:04 PM   #33
_
slide the passenger seat full forward.
place empty UPright in the foot space.
slide passenger seat back till snug.
cover tank with plastic bucket, open window for venting.
a 40 lb aluminum tank weighs LESS than a 30 lb steel tank empty...
so they'll be about the same weight full (3-5# difference)
...Must I carry beer?
and YES carry beer, lifting tanks or calling for help leads to thirst.
cheers
2air'
Old 10-04-2010, 01:10 PM   #34
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by aftermath View Post
Carol,
They charge by the gallon but fill by weight using the tare stamped on the ring. At least they're supposed to. Shortcuts are often taken.
Old 10-04-2010, 01:43 PM   #35
Lapeer , Michigan
Thanks all, Bill and Jammer and Aftermath and 2Air. I plan on trying to refill one as soon as possible, as I suppose they were intended to be used. We are still opertaing on the same tank that was full in March and now I want to fill both before the extended trip. The smaller ones would be slightly more managable for me but this is what we have so I will work around. I will have paid electric but will still be running the propane for two months in winter to keep the tanks from freezing.
Caroljb
photography
Old 10-04-2010, 03:45 PM   #36
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
out of touch
I think I have been out of touch too long. Trip??? Extended trip?? Where are you headed, Carol?
Lou
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 10-04-2010, 04:53 PM   #37
Lapeer , Michigan
I'm going to go help Santa at Amazon.com in Kentucky Lou.
Caroljb
photography
propane tanks roguebrun LP Gas, Piping, Tanks & Regulators 12 11-18-2008 09:17 AM
Aluminum Propane Tanks vajeep LP Gas, Piping, Tanks & Regulators 14 03-18-2004 06:58 AM
Propane Tanks: 30# or 40#? Navigator LP Gas, Piping, Tanks & Regulators 11 12-14-2003 03:08 PM
Aluminum Propane Tanks-Sources? boltos LP Gas, Piping, Tanks & Regulators 2 10-21-2003 05:33 PM
propane tanks david h Our Community 5 01-12-2003 07:49 PM
