Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 05-01-2014, 03:36 AM   #1
Gaël's Avatar
1960 26' Overlander
Wervicq-Sud , FRANCE
Images: 12
Where's the best place to install water tanks
Hello everybody,
I'm restoring completely an 1960 Overlander and I also have to reconstruct all the conveniences as well as the inside etc....
My day request is where is the place to install clean water tanks ? Under the floor with the insulation ? I wish to install 200 liters of clean water, do you think that possible and a good idea ? if it's a bad idea...why ?
Thank you
Gaël is offline   Reply With Quote
Old 05-01-2014, 04:28 AM   #2
Baltimore , Maryland
Put the tank as close to the axles as possible. 200 liters is 53 gallons. I have heard of people putting in much more. That is roughly 412 pounds when full. Keep in mind that water will need to go somewhere once used.
I thought in Europe the water tank is portable and external to the trailer. Is that correct?
Old 05-01-2014, 04:50 AM   #3
Gaël's Avatar
1960 26' Overlander
Images: 12
Yes, near axle, it's correct, to avoid a chassis deformation. The tanks will be full only when the trailer is parked (of course),
For the used water tank, in France, we say "grey water tank" and I think to use portabe grey water tank (2 pieces with 10 gallons approx. for each) and you can use portable clean water tank but you have to tidy it in the trailer and I'm looking for the best practice way possible...
How many gallon max. do you think I can put near axle ?
What Holds The Tanks in Place? 195Pilot Repairing/Replacing Floor &/or Frame 42 10-17-2012 04:07 AM
Need a new black water tank on the 69'... best place? redreefet Waste Systems, Tanks & Totes 8 06-24-2012 09:07 AM
Best fresh/grey/black water tanks in peoples opinions? solarstream Waste Systems, Tanks & Totes 2 10-30-2010 07:42 PM
how are the black and gray storage tanks held in place? gmwelder86 1974 - 1979 Sovereign 2 05-26-2010 11:28 AM
the rod that holds my tanks in place .... PINKBIKE LP Gas, Piping, Tanks & Regulators 14 07-30-2009 04:15 AM
