Old 03-31-2010, 10:02 AM   #1
Utahgoldrup's Avatar
1991 25' Excella
Salt Lake City , Utah
Where to Mount Propane/CO Combination Detector?
We do not have a propane or CO detector in our 1991 25ft. Excella... as best I can tell, something was surface mounted right under the main closet in the hallway, towards the floor which I am thinking may have been a propane detector but I don't see where they would have had it hard wired.
I am thinking this would be a great place to put a combination propane/CO detector and then just hard-wire it using the power going to the water pump which is under the trap door in that closet... does anyone have any thoughts, good, bad, etc? If you have a similar trailer, do you know where the propane dector would have been mounted when the trailer was new?
Utahgoldrup is offline   Reply With Quote
Old 03-31-2010, 10:45 AM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
The location you pointed out is probably where the propane leak detector was located. The general rule is...
Propane Leak Detector - Mount Low (an inch or two from the floor)
Carbon Monoxide Detector - Mount High (about 5 ft from floor)
I have separate units.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
mello mike is offline   Reply With Quote
Old 03-31-2010, 06:25 PM   #3
1991 25' Excella
Thanks Mello Mike! Maybe I will do two separate detectors as you have done.
co detector, combination detector, propane detector
Propane detector curnes All Argosy Trailers 7 01-25-2010 06:17 PM
Propane detector mustang General Interior Topics 3 04-19-2009 07:36 PM
Propane Detector Install davidz71 LP Gas, Piping, Tanks & Regulators 0 08-14-2008 07:58 PM
Combination propane electric water heater Pecos Pete Water Heaters, Filters & Pumps 10 03-03-2007 08:40 PM
Propane Detector Jim Tyrney Airstream Motorhome Forums 10 08-02-2005 08:55 AM
