It could also be the thermocouple. If the thermocouple is bad the pilot will go out as soon as you release the "pilot" button.
Try cleaning around the thermocouple and if that doesn't work you will probably have to replace it.
Also verify that you have plenty of gas in the cylinder and that there isn't anything blocking the feed tube. Check the connection to the bottle for corrosion.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
