Old 09-02-2003, 06:52 PM   #1
Davydd's Avatar
Tonka Bay
Images: 13
What to do with these 40 lb LPG Tanks
I have two two 40 lb aluminum Worthington LPG tanks on my vintage '71 Airstream with a 1976 date stamped on them. They most likely need to be updated. I haven't a clue as to where to begin. Most seem to have 30 lb tanks. Is this overkill for a most likely weekend trekker? Any comments and advice?
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 09-02-2003, 06:59 PM   #2
Send a message via Yahoo to Fun-Lovin
Your choice.
Sell on e-bay or keep them.
I have a set of those tanks also and I had the valves changed to the new valves and put them back on my a/s. Those are very expensive. Gas place told me today when I took my second one in they cost about $200 if he can even get them.
Lets see replace the valve $20 each.
Good thing is they won't rust but lock them down they will grow legs.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 09-02-2003, 07:04 PM   #3
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Davydd
Someone most have used the trailer at a park where they didn't tow it too often. They are quite large...
I recently updated my 30# aluminum tanks. I went to that propane place that's just north of Dowling on Washington Ave. N
They had the new valves in stock and changed them out while I waited.
Valves, labor and fills were about $85 for the both of them I think.
Keep in mind that yours are aluminum. A 40# aluminum tank wont weigh much more than a 30# steel tank.
Ultradog is offline   Reply With Quote
Old 09-02-2003, 07:12 PM   #4
Your not far wrong Ultradog an empty 40# aluminum weighs less than an empty 30# steel sure you will have 10# difference in the weight of gas but its offset by the bottle. When I pick up my 40# and dads 30#'s I will weigh them at the gas place and post the results. Will pick them up friday but it will be next monday before I can post the results.
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-02-2003, 07:45 PM   #5
Davydd's Avatar
Tonka Bay
Images: 13
Thanks for the help
Ultradog,
I'll have to check out that propane place on Washington Ave. There are a couple of fill places out in our western suburbs I can check out as well. The price to convert to OPD seems reasonable. One of my co-workers insisted my tanks would weigh over 200 lbs. filled. That got me a tad panicky. No way could I lift and transport that kind of weight by myself. I'm guessing 50-60 lbs? That's about the weight of my kayak. Truthfully my strength is ebbing with age. I used to carry my 70 lb aluminum canoe three blocks to Cedar Lake 30 years ago with little effort. 20 years ago I was routinely lifting 200 lb heavy timbers. Now my kayak is an effort and some boulders I lifted and placed by hand 20 years ago on my property I could not budge today.
Davydd
Old 09-02-2003, 08:13 PM   #6
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Anyone know for sure if there is a "different" OPD for aluminum tanks vers steel ??
I think to 50 / 60 lbs guess is close my 30 # feels like 30/40 lbs. When last filled the guy said to hang onto the tanks as they are very expensive compared to the steel tanks.
Garry
Old 09-02-2003, 08:48 PM   #7
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Garry!
Yes, the valves are different for aluminum tanks when compared to steel tanks of the same size - - the "dip rod" as it is called is a different length. There was an article on the WBCCI website at one time that outlined the specific valves that were required for the aluminum tanks, but the last time I checked the article seems to have been removed from the site.
My Airstream dealer handled having my tanks refitted and re-certified as part of my Winterization last year so I didn't have to locate an outside source. If I were looking for a vendor to do the work, I would ask to be certain that they were aware of the difference between the aluminum and steel tank "dip rods", and if they weren't I would look elsewhere - - especially if they weren't willing to do the necessary research to obtain the correct part. A friend who recently retired from the LP Gas service business advised me that there is a uniform reference book that LP Gas dealers should have on-site that covers issues of valving for the aluminum and steel tanks typically used on RVs.
Refitting, re-certifying, and refilling the 20 pound tanks on my Argosy Minuet ran just short of $75.00. The 40 pound tanks on my Overlander were purchased new to replace rusty steel tanks that had been with the trailer for more than a decade.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 09-02-2003, 08:49 PM   #8
Images: 59
propane
There's a place at Hwy 7 and Shady Oak that does a good job on tanks.
-Minnetonka
Old 09-02-2003, 10:17 PM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
WBCCI's "Propane Alert"
Kevin -- I save text files of the WBCCI Tips in case useful info does evaporate over time. A word search on 'OPD' led me to find one reference from last December. Their longer explanation can be found at: http://www.wbcci.org/html/december_2002.html
5 meter Langford Nahanni
Old 09-03-2003, 05:59 AM   #10
Tomy Dean Noah's Avatar
davydd
Hello !
If they were mine I would not discard the tanks. You can take the to a propane dealer ans they will replace the valves to agree with the existing new code . The mew valve handles have cornes on he knob instead of the old round knows. I have had mine done and it cost about $60/ tank plus filling them . You will be glade you kept the tanks , especially with it being airstream. When the tanks are polishied ,you can see your reflection on them. Blue Moon
Blue Moon
Tomy Dean Noah is offline   Reply With Quote
Old 09-07-2003, 04:45 PM   #11
Ok I picked up my 40# aluminum tank and my dad's 30# steel tanks the other day. We weighed them at the Propane fill station and came up with this. The 40# aluminum weighed 59# with gas and the 30# steel weighed in at 53# full. With a 6-8 pound average difference between the two filled I suggest as before getting them updated and keep using them.
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-07-2003, 05:11 PM   #12
Davydd's Avatar
Tonka Bay
Images: 13
Thumbs up Just 59 lbs.
OK, thanks for the information. I can handle 59 lbs. I think I will get them converted. Then if all I do is weekend camp they could last several years until retirement unless I use them to also brew beer.
Davydd
Old 09-07-2003, 05:25 PM   #13
You can also boil peanuts or hook up your grill, fish frier, ect.
I took a drill and on the bottom ring I drilled a hole, if you decide to do this you may need a dremel with a metal removal bit to get the hole to work correctly at the bottom because of the rounded lower ring. I also drilled through the steel on the trailer where this lower tank ring fits into. They can be locked up this way with a pair of padlocks. Just looking at them you cant tell they are locked up.
Greg
1976 Soveriegn 31'
WBCCI # 3516
Old 09-08-2003, 08:24 AM   #14
dtbw's Avatar
1999 34' Limited
2002 19' Bambi
Allen , Texas
And they can be polished
You might also look into polishing those diamonds-in-the-rough. Aluminum tanks can be polished to a mirror finish that looks great. Worthington still makes both 30# and 40# aluminum tanks and they run about $200 each (unpolished).
david & bret
'02 Bambi LS
'99 34' Limited
Air Forums # 2159
Past President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Propane Tanks: 30# or 40#? Navigator LP Gas, Piping, Tanks & Regulators 11 12-14-2003 03:08 PM
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 06:47 AM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 09:54 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 05:49 PM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
