Old 04-13-2010, 02:42 PM   #1
1970 31' Sovereign
danville , California
What size line to run for LP?
I am redoing all the lp lines in our jewel trailer and I am unsure of what sized lines to run, the existing HW heater that was electric only is being replaced by a propane heater. The only appliances in the trailer that are propane are the stove/oven, panel ray heater, hot water heater and a propane light. I was planning on running everything 1/4 type k tubing, but now I am not sure if I should have the main line in 3/8"s and branch off in 1/4 to each fixture. I am just worried about under-sizing the system.
gmwelder86 is offline   Reply With Quote
Old 04-13-2010, 02:52 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Most trailers have 3/4 line coming off the tanks and branching off with 3/8 to stove, water heater, and refg. 1/4 seams a bit small. I ran 3/8 to my small Olympic heater.
2004 Excursion 4x4
Old 04-13-2010, 04:18 PM   #3
1970 31' Sovereign
That sounds about right, It just seems weird all the original lines were 1/4 from the regulator back. Mybe a 1/2" main and 3/8" branches might be better.
Old 04-13-2010, 05:21 PM   #4
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Most trailers I've seen start with a 5/8" line to a junction, then 3/8" from there to each individual appliance. An exception would be, say, a gas lamp, which would be 1/4".
Old 04-13-2010, 06:02 PM   #5
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
OK we are doing gas, not air conditioning,Gas lamp takes 1/8 inch. water heater is 1/4 ",yes your flares are outside pipe sizes,but the pipe is ID. Plumber Dave
easyride is offline   Reply With Quote
Old 04-13-2010, 08:30 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Your original lines were as Terry mentions according to the early 70's diagram. 5/8 OD main line. 3/8 OD to oven, range, water heater and furnace. 1/4 OD to refrigerator and gas light.
Old 04-29-2010, 08:23 AM   #7
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
We replaced the furnace, fridge, and range in our '72 Argosy 20. (Terry's old trailer) Since we spent all that cash on new appliances, I felt it kinda important that we go ahead and run all new copper tubing - not a fun job. Our trailer has a 5/8" line coming off the regulator with 3/8" tees that feed runs to each appliance. In addition to the new tubing, I installed new gas cocks so each branch can be shut off independantly. The original configuration didn't include a shut off for the range! It was a bit of a challenge running the line for the new fridge, but that was the only difficult hurdle.
BTW - for those who have problems making a good flare connection, this tool from Yellow Jacket makes the job REAL simple. A little spendy compared to the models in the home centers, but worth the price of admission.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 07-14-2010, 03:54 PM   #8
I want 1
1962 16' Bambi
victoria , British Columbia
I'am restoring a 62 bambi and are repairing a leak in my main line
1/2 is to big and 5/8 to small for the two flairing tools I have tried what gives!
Bob Sheridan is offline   Reply With Quote
Old 07-26-2010, 08:04 PM   #9
1976 Argosy 26
Blandon , Pennsylvania
Here's the deal with propane line...
Propane line is measured in O.D. (outside diameter) Most trailers, including my Argosy 24, have a 5/8 OD (or 1/2 ID for plumbers) main line with 3/8 OD branching off to each appliance. In most cases that is fine. I have a water heater, range, furnace, and refrigerator all on propane on my trailer. The key to gas line sizing the is load on the system and the length of the run. If you are unsure about line sizing and how to install, please seek out a propane tech for help. Undersized line can be dangerous because if there is not enough pressure you will not get an efficient burn which can produce excess carbon monoxide. Also, the appliances will soot and can cause damage, especially in the furnace where you can't see it without taking it apart.
Hope that helps everyone.
lpgasguy is offline   Reply With Quote
Old 07-27-2010, 08:10 AM   #10
easyride's Avatar
1977 27' Overlander
Naples , Florida
Propane size
Don`t know where you are getting your info,it doesn`t really make much difference,but the National Fuel Gas code book refers to all sizes in I.D.,wouldn`t think a trailer would be any different. Dave
Old 10-20-2010, 06:19 PM   #11
Rivet Master In Training
Kevo's Avatar
1965 22' Safari
Mount Airy , Georgia
Send a message via AIM to Kevo Send a message via MSN to Kevo Send a message via Yahoo to Kevo
FWIW, I just ran all new lines in my 65, Ran 1/2 rolled copper everywhere, but it did branch down to the original 3/8 inch for the Fridge and Water Heater. Pics on my page.
Kevo is offline   Reply With Quote
Old 10-20-2010, 06:31 PM   #12
Splitrock's Avatar
Sioux Falls , South Dakota
Mine is 5/8 to 3/8.
Old 04-02-2011, 07:17 AM   #13
Ottawa , ON
Looking to get agreement on the correct gasline standard
I'm wondering if we can all agree on what the size should be?
Does this sound right?
5/8" OD main line (including off the tanks?) and 3/8" OD after the regulator, going to each appliance
Or do we need to use ID measurements, and if so, what would they be?
Thanks. I am replacing my furnace this year, and did my water heater last year, and I want to make sure that I put the proper size in.
Thanks!
Old 04-02-2011, 08:18 AM   #14
Splitrock's Avatar
This is what mine is.
A/C Wont Run sherrylynne Furnaces, Heaters, Fireplaces & Air Conditioning 19 10-15-2009 05:20 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
my new dog run funkill The Pet Forum 2 08-05-2009 06:44 PM
Shakedown Run keylime 1959-69 Tradewind 5 12-05-2002 12:35 PM
