Old 10-09-2014, 05:48 PM   #1
1988 34' Limited
1988 34.5' Airstream 345
Phoenix , Arizona
What octane to use
I recently bought a 1988 345 Airstream Motor Home with a ford engine. Should I use a higher octane gas? When I turn off the engine it tends to knock. When I bought the motor home the owner was using a gas additive. Wouldn't be better to use a higher octane?
Lafayette is offline   Reply With Quote
Old 10-09-2014, 05:59 PM   #2
Builder of Diesel Jeeps
westernjeep401's Avatar
2014 28' International
Sedona , Arizona
Hi,
So when you turn the ignition switch "off", the engine runs-on, like "k-knock, K-NOCK-KNOCK-KNOCK, sputter, swoosh? If so, what's happening is combustion is taking place after ignition ceases at the spark plug (gap). You can have such if there are "hot spots" in the combustion chamber, such as excessive carbon buildup, possibly combined with a larger than spec throttle opening or vacuum leaks, which would allow off-idle amounts of air to enter the engine, even though you're not on the throttle.
To answer your question, a higher octane fuel would, if anything, have no or a marginal effect on what's going on.
If any of this makes sense, you might want to discuss with your mechanic.
14 Serenity 28'
#5261
westernjeep401 is offline   Reply With Quote
Old 10-11-2014, 05:50 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The engine timing could be off. Have your mechanic check it.
Old 10-11-2014, 07:28 PM   #4
r carl's Avatar
Lin , Ne
Your idle speed could be too high also.
Old 05-04-2016, 04:57 PM   #5
Boxite's Avatar
2008 22' Sport
High idle, advanced timing are both the most common causes.
My racing buddies clean out their combustion chambers by running a hot engine at medium RPM and pouring water into the throttle body/carburetor inlet to steam-clean the chambers. (I don't know if that has any validity or not... I wouldn't do it to my vehicles.....and my racing buddies are already brain-damaged in my opinion.)
Gas additives are usually ethanol...which is already present in modern gasoline.
Wanna know if higher octane will cure the problem..??? All you have to do is buy a tankful to find out.
2012 Ram 1500 Crew Cab 4.7L 4X4
Rambox
WBCCI 14676 TX ALAMO UNIT
Old 05-04-2016, 05:19 PM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
Carbon 'hot spots' are causing the run-on, possibly made worse by bad timing.
Try spraying some Blue WW solvent into the carb/throttle body.
Water Injection has been use for years. It does work
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 05-04-2016, 06:00 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
What octane to use
http://www.misterfixit.com/diesling.htm
http://workshop-manuals.com/ford/f_3...itioner_(tsp)/
Superat stultitia.
Old 06-08-2016, 10:49 AM   #8
Boxite's Avatar
2008 22' Sport
Originally Posted by ROBERT CROSS View Post
^///Water Injection has been use for years. It does work
I'm quite familiar with water-injection systems on heavy aircraft, having flown a few of them. But that is not for the purpose of cleaning carbon from combustion chambers, as has been described.
Rambox
Old 06-08-2016, 10:58 AM   #9
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Oldsmobile and buick offered a rocket fuel injection system.... it was simply a water injector post carb. The "jet fuel" was nothing more than blue distilled water! The steam was actually a horsepower booster.
Old 06-13-2016, 08:32 PM   #10
Boxite's Avatar
2008 22' Sport
That's correct!... but it was used for the same reason as aircraft and it was a water-methanol injection system for increased power and cooling..... not for carbon removal or run-on.
http://blog.hemmings.com/index.php/2...obile-jetfire/
Rambox
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Fuel Octane to use tn2 General Motorhome Topics 11 01-13-2007 11:06 AM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 12:11 PM
How to use your own Avatar... PeterH-Airstreamer Forum Admin, News and Member Account Info 2 02-23-2002 07:19 PM
