Old 09-15-2015, 11:49 PM   #1
1954 22' Flying Cloud
Kirkland , Washington
What Bracket Do I Use?
I'm at the point where I'm ready to order parts for the LP system. Need to get the copper items ordered still. I have the full securing arrangement for the tanks, pigtails, and everything to the regulator. What I can't find is an answer on what part to use between the flex line downstream of the regulator that transitions to copper or hard line near the base of the tanks. It seems like a bracket should be there to keep the line from flexing. Is the one in the photo what I need? Do others use nothing at all? It's labeled as a regulator bracket, but I have one of those already. Thanks!
54fuselage is offline   Reply With Quote
Old 09-16-2015, 02:44 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I would mount the bracket so that the brass fitting from trailer goes thru the bracket opening. The flex line mounts on the other side. No need for 'mounting' or snugging to the bracket as the bracket will keep the fitting aligned. If you want a 'thru-bulkhead' fitting can be used and this is how you can 'secure' to the bracket.
Here is one expensive type.. http://www.mcmaster.com/#tank-pipe-fittings/=yyu59a
but there are other options...
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-16-2015, 06:10 PM   #3
What I'm trying to determine is, if the bracket in the picture is what's used when transitioning from brass line to the flex line. I've never seen any pictures of how other trailers are set up, and can't find anything on the Internet to show a standard setup. It's labeled as a regulator bracket, but based on what you have posted perhaps I'm on the right path using this to hold the brass connection firmly in place, then running a flex line up to the regulator?
Ground bracket solution for awning yukionna Awnings 3 10-05-2003 09:09 AM
Awning Bracket Question? JoeW Awnings 13 09-17-2003 11:24 AM
awning bracket manley Awnings 2 08-22-2002 06:16 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 04:40 PM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 12:11 PM
