Old 03-24-2015, 01:58 PM   #1
Clutch1855's Avatar
2014 19' Flying Cloud
Vacaville , California
Weber Baby Q Mod
i want to delete the low psi fitting on my weber baby Q. What parts do i need to replace on the grill so i can use my trailers low psi external port quick disconnect?
Clutch1855 is offline   Reply With Quote
Old 03-24-2015, 03:48 PM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Here's a link to a shop in Texas that has more than you'll ever want to know about.
BBQ Pits by Tejas | Barbecue Pit Smoker | Barbecue Grill | Houston Texas tradition of wood smokers
That said, I did extensive an exploration into exactly what you're trying to do. I'm still using the Coleman 1lb. bottles.
There are a few threads in the forum that delve into this very subject, including one, I believe, I started.
Good luck!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 03-29-2015, 01:18 PM   #3
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Weber Q grill
I hate my weber Q grill for just that fact it stays at home. I bought an O-Grill it folds easy has a cast iron grill surface comes with canvas case was made by some guys that built propane torches. It cleans easy and works well with regular 20/30 lb tanks with the adaptor hose or any of the one lb cans. They have 2 sizes I got mine at Dicks on sale, camping world carries the small version. I can't say enough good things about it. Rand
grizbear is offline   Reply With Quote
Old 03-29-2015, 10:25 PM   #4
TahoeStream'n
subfan1's Avatar
2019 23' International
La Habra , California
I modified mine and use it on the low pressure out of the front of the trailer when we camp.
I removed the regulator and bought a 3/8 flared threaded nipple from my local True Value hardware store. Hooked up the hose and it stays with the Weber Q
2018 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Old 03-30-2015, 11:59 AM   #5
2017 30' Flying Cloud
Spotsylvania , Virginia
I had my local propane dealer make me up a hose that goes from the front of my AS 23FB quick disconnect to my gas grill which took the little one pound bottles. I think it cost me $35 - $40 and it is 10' long.
KWN306 is offline   Reply With Quote
Old 03-30-2015, 12:59 PM   #6
Zil
Curtis Wright
Eyren Haven , South Jersey
Has any one tried using the low pressure from the AS with the grill or stove regulator? I don't see how two low pressure regulators in series would do any more than pass low pressure gas. Higher pressures close the regulator while lower pressures open it.
Zil is offline   Reply With Quote
Old 03-30-2015, 02:55 PM   #7
2014 27' Flying Cloud
Willow street , Pennsylvania
Weber Q grills
Sorry, I can't tell you the names of the parts, but the process is quite simple. First, get a 10-12 ft propane hose with a female and male quick connect ends (obtained from my local RV dealer). Take off the regulator from the grill. Now, for the tricky part. Your local hardware store should have the brass connectors required to attach to the grill and end with a female quick connect end. Although pretty straight forward, I spent most of a day going back and forth to the hardware and RV store to accomplish my goal (3/8, 1/2 inch connections have to be right. Best advice, get a hardware store clerk who knows what he or she is doing when it comes to propane and let them guide you. Ace is the Place! Grill works great. Be sure to get a roll of plumber's tape for the connections.
Rgmhog1450 is offline   Reply With Quote
Old 03-31-2015, 05:19 AM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
There was a short hose included with both of our new Airstreams in a plastic bag that would connect to that auxiliary propane outlet near the hitch. I would see if I could splice that onto a longer propane hose that could connect to the baby Q.
Old 03-31-2015, 07:34 AM   #9
1976 31' Sovereign
Oswego , Illinois
Smile weber q
When buying teflon tape get yellow as it is for gas white for plumbing. Liitle off subject but my q220 would never get hot, phoned Weber yesterday, grill less than 2 yrs. old. No quest.asked when told them prob. next words from Weber tech I will send new valve regulator today no chge. this is service from good company. Bill
Old 04-06-2015, 04:09 PM   #10
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
I had a propane tech tell me that it takes 10 lbs of pressure to open the regulator. You only have 1/2 lb coming from the exterior LP port. I am modifying a Cuisinart CGG-220 grill by separating the regulator from the control valve and installing a male quick connect where the regulator was attached to the valve.
NWRVR is offline   Reply With Quote
Old 04-06-2015, 04:38 PM   #11
2015 25' Flying Cloud
Truckee , California
As murreywalker suggested, I contacted Tejas Smokers and spoke with Mr. Cheyenne Souza. He was more than helpful, referred me to the parts needed in his catalogue and told me to call with any additional questions. I had purchased an extension hose and what were sup[posed to be the proper fittings to connect my Q2000 to my Airstream. The result was a hodepodge of 4-5 fitting that still did not work. Mr. Souza sold me a hose and two simple fittings that were not only cleaner and less expensive, but actually worked and corrected the low pressure issue. I would highly recommend anyone with a Q 2000 series barbecue contact Tejas Smokers and Mr Souza.
tahobkr is offline   Reply With Quote
Old 04-06-2015, 04:59 PM   #12
TerraYacht's Avatar
2005 30' Land Yacht 30 SL
Castro Valley , California
I have an adapter I use at home, refill my 1# bottles from the 20#. Fortunately I didn't just toss empty ones so I have quite a few that I rotate in as needed. I'm not sure where I bought the adapter, either at my trailer parts store or my friendly Ace store.
Cliff & Andrea,
One 17 YO cat, but she stays home
TerraYacht is offline   Reply With Quote
Old 04-06-2015, 05:20 PM   #13
r carl's Avatar
Lin , Ne
Do you put the bottles in the freezer b4 you fill them? It will fill them more.
Old 04-06-2015, 10:59 PM   #14
2007 22' International CCD
Refilling disposable bottles is a) dangerous and b) illegal.
There are 1 pound bottles that are designed to refill safely but they are hard to find.
An even slightly overfilled disposable bottle is basically a bomb waiting to go off.
Please, please don't take the chance!
Anyone recommend a Weber Baby Q 100? Kistler Off Topic Forum 13 11-22-2006 09:53 AM
Weber Baby Q Griddle davidz71 Our Community 10 08-01-2006 12:15 PM
New Style Weber Baby Q 120 davidz71 Off Topic Forum 3 03-10-2006 08:33 PM
Weber grill Bambi sfixx Airstream "In the News" 3 06-02-2005 11:01 PM
