Old 08-23-2010, 07:28 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
water/moisture in h/w heater regulator
Im working on a 64 safari w/ 30# alum tanks.About 3yrs ago they were filled.Recentley I went to light the atwood h/w heater(which is 3yrs old)& the pilot lit,but as soon as I turned the knob to the on pos. the pilot went out & the burner would not light.I loosened the propane line coming into the regulator while the propane was on ,water came out! I took the reg. for the h/w htr apart &blew the water out.After this the burner ignited& worked great for about a week,now im having the same prob.,any suggestions?
Cochese is offline   Reply With Quote
Regulator Low Pressure / Water Heater Burner 77Overlander LP Gas, Piping, Tanks & Regulators 1 10-26-2009 03:28 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Need regulator for Bowen G-110T hot water heater SJ1 Water Heaters, Filters & Pumps 5 04-20-2008 07:42 PM
Water Pressure Regulator & External Water Filter safarijim Off Topic Forum 7 02-01-2007 08:17 PM
Water regulator edmatlock Fresh Water Systems 1 05-01-2005 12:05 PM
