Old 08-26-2015, 06:58 AM   #1
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Water leak -from fridge or somewhere else?
I have a mysterious water leak. second time this trip.
Water - maybe a cup or so, seems to leak from fridge to floor, getting behind the dinette which this picture is of. When I check the exterior fridge compartment, the drain hose is dry - obviously! the drip pan in the fridge does not seem excessively full.
What is odd is that the floor was dry this morning, I opened the fridge and putzed around the kitchen. 30 minutes later the water was on the floor. It was like a faucet was turned on.
Which gets me to thinking - is the fridge as the culprit here a red herring? Should I be concerned that my leak is from some other source - like a plumbing leak? I am not connected to shore water, using FW tank instead.
Any advice from others who have search for source of leak? Thanks!
RAH is offline   Reply With Quote
Old 08-26-2015, 07:17 AM   #2
dznf0g's Avatar
Oswego , Illinois
Since it only happens when the fridge door is open for awhile, I would still suspect the drain hose. Even if it is dry at the rear fridge compartment floor, try and gain access to the drain line from the compartment floor down through the trailer floor and see if there is a leak in that section...or if it doesn't even exit through the floor and belly pan.
-Rich-
Old 08-26-2015, 08:26 AM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
The drain hose usually has a cap on the bottom end with small holes to allow water to drain but blocks insects from crawling up the tube. Is your cap missing? If so something may have built a nest near the nipple on the back of the fridge where the tube presses on. The drip tray under the fins may be out of position so that the condensation doesn't funnel into the tube. That should be easy to verify. If the drip tray is holding water, that is an indication of a blockage. While looking, try to probe the opening with a thin screw driver or a wire to be sure the path is clear.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 08-26-2015, 08:35 AM   #4
dznf0g's Avatar
Oswego , Illinois
On my fridge, if the drip pan is out of place, the water will only leak our through the bottom of the door, as the inner panels of the fridge are one piece and watertight....except at the bottom door gasket. Could be a source though.
-Rich-
Old 08-26-2015, 10:39 AM   #5
2016 28' Flying Cloud
Frostproof , Florida
Read my post on water leak,,,,,can be from pressurre from water heater, re do the air bubble.
jczednick is offline   Reply With Quote
Old 08-26-2015, 10:40 AM   #6
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Rather than using a wire to poke in the drain tube, you might consider using a length of string from a weedeater. Much less likely to punch a hole in the tube.
Cannonball is offline   Reply With Quote
Old 08-26-2015, 11:58 AM   #7
Amsterdamer's Avatar
2015 27' Flying Cloud
Caledonia , Michigan
Solution to my similar issue:
In my new 2015 model, I found that the condensation collection in the refrigerator was not draining down the drain tube. The collection tray was directing the water into the tube, but it was pouring back out into the fridge. I never had this issue in the 2005 model that I owned previously.
The trailer was level and the tube was not restricted, so I concluded that the issue had to be due to a design flaw. I went to the hardware store and purchased some clear plastic tubing that fit over the drain tube from the water collection tray. I used about 1 inches, as much as I could push into the drain hole, with a small taper added to the top edge of the tube to make if go in a little further.
Upon testing this solution, I validated that any water collected in the tray would now flow out of the drain tube to the outside of the trailer.
My conclusion is that the leading edge of the drain hole is level, rather than canted toward the back of the fridge.
Amsterdamer is offline   Reply With Quote
Old 08-26-2015, 12:34 PM   #8
Home of Vortex tuning
CDONA's Avatar
2013 27' FB Eddie Bauer
Spearfish , South Dakota
My drain hose was in a knot/pinched off. I didn't have a leak but straightening out the wires and hoses from the exterior hatch. I was looking for a power reset when my batteries died, and needed to restart my fridge
"Chip Tank" is in Flagstaff Az.
CDONA is offline   Reply With Quote
Old 08-26-2015, 01:13 PM   #9
dznf0g's Avatar
Oswego , Illinois
When I got mine, there was a black corrugated line SLIPPED OVER (without sealer of any type) the white pipe which exits the AS. This connection was about 2" off the fridge rear compartment floor. As it was slipped over, water would just flow on the outside of the lower white tube and onto the compartment floor. I caught it during my shake down inspection and sealed it with poly urethane. End of story.
-Rich-
Old 08-26-2015, 02:04 PM   #10
GammaDog's Avatar
2014 25' FB Eddie Bauer
Vero Beach , Florida
Images: 26
If my trailer is not level side-to-side and the fridge is on the high side, water in the pan under the fridge (which could comes rom the drain) will come into the living space, not out the exterior compartment hatch drain slot. Even 2" out of level can allow that. If that's happening to you, you can confirm by opening the exterior hatch and looking for water tracks from the drain toward the living space.
GammaDog is offline   Reply With Quote
Old 08-26-2015, 02:37 PM   #11
Fernandina Beach , Florida
I have a 2015 FC 30 and had the same experience, I found the culprit was down in the compartment where the water heater is. I had to unscrew the plywood from the dinette to access it but the way the pvc was placed in there, it had pressure from weight of the water heater tank. I tightened up all the joints and moved it over so it does not have direct downward pressure. I think I solved mine. Hope this helps!
Mldun is offline   Reply With Quote
Old 08-27-2015, 07:52 AM   #12
RAH
Cincinnati , Ohio
update on my water leak
Update: I looked at the routing of the fridge drain hose, moved it a little to give an extra inch towards the outside. I poured a cup of water into the drain pan using a nifty L funnel that I carry around for just these occasions. There seemed to be about a cup that came out the other end of the hose. So all of that seems to be working....
And last night, the paper towel I put between the dinette and the fridge was a little damp.
This morning, the water was back - half a cup or a cup?
I will look more at the plumbing and/or hot water heater later today.
Thanks for all of the suggestions!
Old 08-27-2015, 08:51 AM   #13
dznf0g's Avatar
Oswego , Illinois
I guess, too, that we all have a tendency to picture our own AS configuration when offering advice.....sooo...from your pic, do I assume I am looking at a storage compartment and the wall with the water "wick" is the wall at the side of your fridge? What's under the fridge as far as components and plumbing?
What is the exact routing of your drain for the fridge?
Last night, was water pump pressure on the lines all night? was the water heater (if under, or adjacent to, fridge) on all night?
Any other water noted as pooling or trail or wicking on other wood components?
-Rich-
Old 08-27-2015, 09:43 AM   #14
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
We had water seepage on floor in front of hall closet, next to refrigerator also on our 2014 RB FC this past weekend while at Placid Lake, MT....has only happened a couple of times, but I am stumped. I will look at the suggestions and see if this is the problem...I was thinking it was perhaps coming from the fresh water fill tube since we had just filled up. Appreciate the suggestions.
Leak somewhere in top section- B190 Van Luckydog Sprinter and B-van Forum 5 04-09-2010 05:09 PM
Water leak somewhere BLUEBELL Plumbing - Systems & Fixtures 4 09-29-2008 07:55 PM
Help Please I Know Its Here Somewhere davidh Our Community 3 02-11-2006 03:17 PM
Looking for somewhere to park our coach for 2 months in the Los Angeles area!! HELP!! williamhenshall Our Community 5 10-22-2003 08:58 PM
From a Movie Somewhere JodynJeep On The Road... 11 10-19-2002 08:45 AM
