Old 08-06-2014, 12:26 PM   #1
1969 23' Safari
fairfield , Pennsylvania
water heaters
I have a newer water heater I have to light the pilot light it is not an auto start. My question is whenthe water is heated up does the flame lower itself or will it stay on a continuous burn.
Russ
russellsue is offline   Reply With Quote
Old 08-06-2014, 12:52 PM   #2
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
The 'pilot' light will stay on the entire time, but it should be a very small flame, just enough to light the main burner. Just like the pilot light in your gas water heater at home.
Damon
#4827
damonbeals is offline   Reply With Quote
Old 08-06-2014, 12:53 PM   #3
Zil
egg harbor city , South Jersey
the pilot lights the main flame to heat the water then the main flame cuts off. If the pilot is burning the cycle repeats as needed.
Zil is offline   Reply With Quote
Old 08-06-2014, 01:39 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Make sure the water heater is full of water before lighting the pilot/burner. The heater will be damaged if it is empty.
TG Twinkie is online now   Reply With Quote
Old 08-06-2014, 07:08 PM   #5
1969 23' Safari
water heater
How do I tell when the water heater is full?
Old 08-06-2014, 07:14 PM   #6
2013 25' FB International
Carrboro , North Carolina
How do you know the water heater is filled with water and how do you fill it?
NCstreamer is offline   Reply With Quote
Old 08-06-2014, 07:14 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
When you have it in the summer mode (if applicable) and you have either the house tank full and the pump running, or you are on city water. Open the hot water faucet on the bath and galley sinks. Let the water run until no air comes out, just water. You can also check by opening the pressure relief valve on the water heater momentarily. Water should come out. Don't leave it open too long or you will lose the air head.
The air head makes room for the water to expand as it heats up.
Old 08-07-2014, 04:15 AM   #8
1969 23' Safari
water heater
Thanks for your help. Taking her out on her first road trip to ocean city MD next week really looking forward to it I need a vacation!!!
Old 08-29-2014, 04:46 PM   #9
1969 23' Safari
water heater problem
the main control module and the piolet line were bad. both replaced problem solved. I will tell you that this was not a cheap fix!
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
ebay and water heaters. harestream Water Heaters, Filters & Pumps 8 08-03-2007 10:08 AM
Atwood Water heaters covers LEAKY29 Water Heaters, Filters & Pumps 2 05-23-2006 06:08 AM
for those interested in electric water heaters icedcacti Water Heaters, Filters & Pumps 0 01-05-2006 09:33 PM
Tankless water heaters dmadam Water Heaters, Filters & Pumps 15 05-13-2004 09:22 AM
