Old 06-02-2015, 08:33 PM   #1
2015 25' FB International
Oelrichs , South Dakota
Water heater only lights with outside door open
If the outside door is closed the water heater will not ignite, obviously a lack of oxygen, same results at sea level and 5000', is there anything that can be adjusted? It stays lit when I close the door, it's only the initial lighting that doesn't have enough air. Thanks!
davidkingham is offline   Reply With Quote
Old 06-02-2015, 08:47 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Misaligned igniter?
I'm guessing a misalignment of the igniter. With the door open, breezes carry the gas to the igniter. If it were insufficient air, it wouldn't keep running. If you have a manual, see if it tells how to align/install the igniter. Better yet, take it to the dealer for warranty repair.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-02-2015, 09:29 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
David, Welcome. Definetly not normal. I would guess a warranty covered issue.
MICHAEL
Old 06-03-2015, 06:43 PM   #4
Ray Eklund's Avatar
2019 27' International
2014 25' International
Boulder City , Nevada
We have no problems at 10,000 feet!
If you take your Airstream into the local AS shop... hope they know what they are doing.
If your water heater lacked oxygen... I cannot imagine the interior of the trailer.
Of all the components in our Airstreams, the water heater and furnace never gave us a problem.
The refrigerator ignitor, which was about 1/32nd of an inch off and by bending the sheet metal it was attached, to center the ignitor over the flame, did fix the problem and we lived happily ever after. Our water heater is sealed, so obviously something you cannot do yourself. Please tell us what the problem was and how they fixed it!
Human Bean
Ray Eklund is offline   Reply With Quote
Old 06-05-2015, 03:10 PM   #5
Thanks guys, I did a little more testing and I have found that it barely stays lit when I close the door. So I'm presuming too much gas vs. a lack of air. We're full timers so getting in for a warranty repair is no easy task, I guess we'll have to open the door until we get back to Denver this summer!
Old 06-06-2015, 07:07 AM   #6
1978 28' Ambassador
Columbia , Connecticut
Ck and see by using pipe cleaner in burner pipe sometime spiders make a parcel nest in it
Ducky2 is offline   Reply With Quote
Old 06-06-2015, 08:14 AM   #7
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Yes, and lighting it can result in toasted wiring (don't ask how I know). A plastic wire tie will also work.
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 04:47 PM
Outside fresh water door lock won't open willbrackman Exterior Storage Compartments & Access Doors 12 11-02-2011 01:27 AM
slow drip behind outside water heater door iHayley Water Heaters, Filters & Pumps 12 04-30-2009 07:10 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Door stop, door hold-open, whatever... bevman Doors & Locks 4 04-07-2007 01:27 PM
