Old 03-17-2012, 04:37 PM   #1
2012 25' International
Los Olivos , California
Water heater is not working
Hello,
The water heater in our 06 25ft International stopped working suddenly. Do not hear lighter, verified propane. Any easy fixes! Thanks so much!
Dennis
Densin E. is offline   Reply With Quote
Old 03-17-2012, 05:07 PM   #2
tpi
Trabuco Canyon , California
One thing you may want to check is the thermal cutoff. It looks like a fuse, with a plastic sleeve. You may google "atwood thermal cutoff" for a better description.
I've had it fail on mine when spider web clogged burner tube causing the flame to burn in the outer housing of the water heater. This overheated it and caused the cutoff to blow. If it is blown the water heater will be dead.
tpi is offline   Reply With Quote
Old 03-17-2012, 05:16 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
Sometimes, the water heater contacts become intermittent. Try this. Open the outside water heater access door. There are four wires going into the main body of the water heater. Remove the one on your left, clean the contact, an replace it . Try the water heater again. If it still doesn't work, move the wire back and forth on the contact to help clean it. Try it again. Hopefully, this will work. Let us know if it works.
It's the wire closest to the shield with the two red wires going into it in the picture.
Brian
SuEllyn & Brian McCabe
Old 03-17-2012, 05:49 PM   #4
cameront120's Avatar
1972 25' Tradewind
Could be you lost the air gap in your tank. Try releasing the water pressure.
North Vancouver, BC
Old 03-18-2012, 05:24 PM   #5
2007 25' International CCD
Tanks so much Brian! Contacts were all very dirty. Cleaned them up and I now have hot water!! Thanks to all for comments.
Dennis
Dennis E is offline   Reply With Quote
Old 08-26-2012, 08:53 AM   #6
Happy Trails
1987 32' Excella
Zavalla , Texas
Brian
Thanks Brian....including the picture really helped. I have cleaned my contacts and blown out the area. My light comes on, stays on, no ignition sound. Is there an in-line fuse? I'm tired of my hot water showers being from the hot water in the long water hose I connected.
k5uuu is offline   Reply With Quote
My next project is a basket case... InsideOut Vintage Kin 142 10-19-2013 09:18 PM
Fresh water Drain Plug??? CeloNC Plumbing - Systems & Fixtures 8 03-18-2012 04:36 PM
What is fair sales price for 2012 Sport 16' lubelg Dollars & Cents 10 03-17-2012 07:47 AM
Anybody know if there is a TV inspection service or a good mechanic in Philly? Rob&Julie Tow Vehicles 0 03-16-2012 09:18 PM
Is this original tlcbuilder Refrigerators 1 03-16-2012 05:17 PM
