Join Airstream Forums Today
Old 09-21-2011, 06:01 PM   #1
Orland Dewey's Avatar
Water Heater gas valve repair
Need help...Gas valve on my GC6A7E Atwood)water heater has stopped working. One solenoid is defective. I am looking for a used unit. part number would be #93870 old no. and 93844 new number. If you have replaced your water heater and have the old one laying around check to see if would work for me. Perhaps you know of a dealer that deals in used parts. This is for my 1985 325 unit MH.
New solenoid is 160.00 so am trying to find used.
Thanks for your help.
ODD
Orland Dewey is offline   Reply With Quote
Old 10-04-2011, 05:35 AM   #2
1969 27' Overlander
Albuquerque , New Mexico
Orland, I just replaced my water heater, it finally rusted out. The PO had replaced the temp sensor and solenoid. It's fairly new. I can look at the unit and see if I can locate part numbers, etc.
I'll try to post a pic, too.
If you can use it, that would be great!
edglenn is offline   Reply With Quote
Old 10-06-2011, 09:57 AM   #3
1969 27' Overlander
Orland, the part number on the water heater valve assembly is: 27C55U 658
This is a pilot light, not electronic, gas valve. It has the temperature dial, and heat-bulb thermocouple. It was a replacement for the original gas valve, on the OEM water heater from a '69 Overlander.
Please let me know if that would work.
Ed
Old 10-15-2011, 05:33 PM   #4
attn Edglenn: My unit is all electronic so that
probably wouldn't work. I did go to Camping World
last week and bought the part that I needed so I am
back in business. Thanks for the offer to help!!
ODD
Replacing Water Heater in Argosy 24ft '75 HELP!! eyelashsoup Water Heaters, Filters & Pumps 10 08-23-2011 07:56 PM
Revisit water heater relief valve leaking Silver Otter Water Heaters, Filters & Pumps 18 05-23-2011 08:52 AM
Water Heater Calcium Deposits -- What to do? Wilmington Water Heaters, Filters & Pumps 7 05-18-2011 03:11 PM
Gas line to water heater '73 International cuyd Water Heaters, Filters & Pumps 13 04-04-2011 09:47 AM
