09-23-2018, 04:11 PM
2001 30' Limited
Tucson
Water dripping from gray tank "cover"
Hello all! We've had our 2001 Classic Limited a year in July. Noticed a water drip in the outer corner of the belly pan of the gray water tank. The hole looks deliberate as if it was drilled there. Is this normal? Is our gray tank leaking and the water accumulating and draining through this hole?
Please see pic, it's a bit distorted due to the water...
We appreciate any thoughts as we have not been able to find any information on this issue.
Thank you!
09-23-2018, 05:56 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Does it drip if the gray tank is empty?
09-23-2018, 06:21 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
The metal pan is not the tank. The pan surrounds the plastic tanks, black and gray.. The metal is not designed to hold water.
The only way to know what is leaking (tank, adapters, valves, or pipe) is get access to the tank enclosure.
Two choices: cut an access hole or remove the pan.
This is what I did>
http://www.airforums.com/forums/f444...es-162941.html
Alan
09-23-2018, 06:27 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Yes, and is it one cover for both tanks?
What I did with ours,(one cover/both tanks), when I noticed it was leaking. Drain both, let it sit until it stops dripping.
Add 1-2 gal at a time waiting 5min or so until you notice the drip again. If it starts with 5gal or less it's most likely the dump valve.
I used 3m 5200 to seal the new valve to the tank...POI WAIT until it completely cures.
Small tubes available on Amazon.
"You don't know where you've been until you leave, enjoy life" RLC
09-23-2018, 08:37 PM
1995 25' Excella
xxxxx
, xxxxxx
Empty both the black and gray tanks. Put clean water in each. Add different color food coloring to each. Put a catch pan under drip. The water in the catch pan will tell you which is leaking.
09-23-2018, 11:15 PM
2007 22' International CCD
Corona
Stick a white paper towel in the catch pan to make it easy to determine the color
09-24-2018, 01:42 AM
2001 30' Limited
Tucson
Thank you for the information! I'm fairly confident that this leak is from the gray as the water is very clear. We are new full timers and are using potable water now and showering at the shower house, very little water is going into the gray tank. I'm more than likely going to have to take the Airstream in for this service. We will research and find a dealer with a good rep as I'm thinking this is too big a good for me!!!
09-24-2018, 05:05 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Be sure of the competence of the dealer you take it too...Airstream themselves screwed up ours.
They use a T-bolt clamp on the flange connection. It was overtightened which deformed the flange, eventually cracking it. 👎
I used 3m 5200 sealant on the flange which sealed w/o over tightening. 😂
09-24-2018, 06:03 AM
League City
I'm not sure if you are describing the same issue we had, but the first generation of the Airstream Interstate was notorious for having the gray tank connections either crack or shear off completely, resulting in exactly the symptoms you describe. The way to tell for sure is to drop the tank shield and inspect the connections (it's easy - the tank shield unbolts from the all-thread supports that attach it to the frame). This series of blog posts here describes that process in detail, with many pics.
I've heard anecdotal reports that this type of gray tank plumbing repair costs about $2,000 - $2,500 if done by a service center. It cost us less than $100 to DIY it (plus about 6 hours of labor). My husband and I actually completed the same repair for one of our friends because we didn't want to see him get gouged at a repair shop.
09-24-2018, 06:30 AM
Cedarcreek
, Missouri
We just got our '06 25'FB back from the dealer in Springfield, MO not a week ago. She had developed a leak in the black tank last spring (same description as yours, only nasty water dripping from the weep holes in the outer cowling). They confirmed the tank was cracked.
The repair was to remove old, purchase new "blank" tank and spinweld the proper fittings (evidently can't just buy a ready to install tank for an '06 AS), then replace and test. Quoted as a 16hr job at shop rate plus materials and incidentals.
Sounds easy, however they evidently received the first tank and spinwelded all the fittings only to find out the tank didn't fit in the space. Round 2: get new tank, measure for fit, then spinweld fittings. Got hung up on one fitting that didn't fit which they had to reorder 3 times, service tech was out with family issues, yadda, yadda, yadda...
Bottom line, it was fixed properly (best we can tell to date) and the work appears to be done cleanly and professionally. It did cost an arm and a leg, as all professional AS repairs will, and it was in their hands for 3 months. I was beginning to think I could have repaired the crack with some of that magic "flex seal tape" AS seen on TV, but in the end, glad we went with the dealer repair.The Mrs is happy so therefore, so am i.
Only criticism was the lack of communication and updates from the dealership insofar as prognosis, snafus, delays, etc. The final cost was right in line with original estimate (plus new tank sensor added) and they didn't charge me for the failed attempts.
09-24-2018, 12:40 PM
2000 30' Excella
Toledo
, Ohio
Thank you!
It's an easy fix if you have the tools and don't mind laying on your back to do the repair . Takes some time and your dump valves are no doubt ready to be replaced We have a 2000 and I did it last year
09-26-2018, 01:18 AM
2001 30' Limited
Tucson
I will be emptying the tank soon and will check. Thank you!
