Old 09-23-2013, 07:31 AM   #1
2018 23' Flying Cloud
Eagle Creek , OR
Send a message via Skype™ to almcate
Wandering hot water tank
Second shakedown turned out to be just that... traveling dry the first day through (at rush hour in speeding traffic in construction zone) Stockton CA the rough road seems to have everso slightly moved the hot water tank about 1/2 inch toward the front of the cabinet housing it. problem is that one of the open valves is now just over the lip of the door opening and so can't be turned.
Thoughts are to maybe try to lever it back, but with 50# of water and the tightness of the piping around the tank, that seems to have the potential to make new, worse problems. Assume however, that with valve open, when I winterize, the empty tank will shift more easily and I can find something to wedge between the tank and cabinet frame to prevent recurrence.
Sound about right? Or better to leave as is and figure to replace the valve handle with maybe an ad hoc vice grip when needed?
Thanks, Al McAtee
almcate is offline   Reply With Quote
Old 09-23-2013, 07:40 AM   #2
Ottawa , ON
Can you tell what's stopping it from moving even further?
Old 09-23-2013, 08:28 AM   #3
1977 Argosy 24
Milltown , Wisconsin
I always put some plumbers strapping over the top and down the sides and screwed to the floor when I install a hot water heater. Remember to put a block under it if it is not tight to the floor. I would not leave it as is. If it moved forward it can move back also. With enough movement it may break the skin or the pipes.
ventport is offline   Reply With Quote
Old 09-23-2013, 08:30 AM   #4
Eagle Creek , OR
Guessing 50# of water... ?
Old 09-23-2013, 08:45 AM   #5
Full Time Alumaloafer
louaxtjr's Avatar
1966 24' Tradewind
Livingston , Texas
Images: 12
8 pounds per gallon water.
Lou Axt, Jr.
1966 Tradewind
1969 Chevy C10
_____________
Phillipians 4:13
louaxtjr is offline   Reply With Quote
