Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > LP Gas, Piping, Tanks & Regulators
Old 09-01-2004, 03:45 PM   #1
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Vintage Thetford Conversion Question
I want to install a late model Thetford dump valve on my existing 1963 Overlander's black tank.
The bolt pattern is 6.5 in diagonal center to center, and 4 5/8in center to center if measured parallel.
I wonder if a modern Thetford valve would fit this pattern?
I have atached three pictures for clarification. One of the bottom of the tank, one of the bottom of the dum valve, and one of the top of the dump valve.
Andy at Inland says it might need a new flange on teh tank glassed in.
Did anyone do this recently?
ID:	8577   Click image for larger version
Uwe
www.area63productions.com
Old 09-02-2004, 05:26 AM   #2
The newer valve wont fit , you will have to glass in a new flange after grinding the old out . Under the dump valve I found a genova 3 inch fitting with two 1 1/2 inlets covered with dust at local hardware store which takes both drains so works like old bronze dump valve without adding grey tank . I used 1 1/2 to 1 1/4 rubber adapters to connect to old pipes . I dont know if the genova fitting is still made , its the only one I`ve ever seen ,in local hardwares ,home depot etc.
I`m going under trailer today , I`ll get # of genova fitting for you
Chris 63 cloud
Flyincloud is offline   Reply With Quote
Vintage sub-units? Midamrail WBCCI Forum 47 12-10-2006 08:53 AM
On the road again: Vintage travel trailers, owners ready to roll Andy R Airstream "In the News" 0 07-18-2004 10:55 PM
Vintage Airstream Question joshua32064 Our Community 7 10-01-2003 10:39 AM
How vintage is vintage? zamboni On The Road... 9 12-02-2002 03:30 PM
